Old Oct 31, 2012, 09:59 PM
Reehoe is offline
Find More Posts by Reehoe
Reehoe's Avatar
United States, IL, Bloomington
Joined Sep 2004
Build Log
GA Fun Foamies/plans -Foamanza F33/V35, A36, B58, C172, M20
EDIT:
Foamooney Exclaim (free plan), 35" span. See post #172.
I have changed the title to more accurately reflect my desire to expand this thread to include all designs currently in the works. Some will be kits, some will be free plans... I also added a couple pictures up front to show what's been done so far.
Designs completed:
Foamanza 33, 33" span
Foamanza 35, 33" span
Foamanza 36, 33" span
Foamanza 55, 38" span
Foamanza 58, 38" span
Next: Foam-Air 90/ 200, Foamanche, Foamy Mixmaster, ???
Original post:
I have been toying around with designing some nice knock-around foamy General Aviation machines to be made with MPF, something with an "undercambered" wing or KF2 airfoil. I think a Bonanza will be first! it won't exactly be a full fuselage, at least at first, but more of a thick plate or a box, similar to the SEMFF combat planes. If there is any interest I will maintain a modest thread.
Initial design will be around 31", with a slightly enlarged tail and wing planform. I will also design a set of removable landing gear for the "Foamanza"... no self respecting foamy GA aircraft will always have to resort to a belly landing. I want to do touch and goes sometimes! Later I may do a few other GA planes if I like the result, such a a Comanche(or Foamanche!), Cherokee, 152, or a Baron. We'll see. My evenings are pretty busy right now on the work front- I might however be able to work on this project on my lunch hour & breaks.
Reehoe is offline Find More Posts by Reehoe
Old Oct 31, 2012, 10:07 PM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
Here is a screen capture from CAD.
Old Oct 31, 2012, 10:24 PM
jonesymj is offline
Find More Posts by jonesymj
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Always loved that V tail...
jonesymj is offline Find More Posts by jonesymj
Old Nov 01, 2012, 07:23 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Nice application of the VLF concept. Should be a very attractive plane.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Nov 01, 2012, 01:11 PM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Chicopee
Joined Jul 2004
Ken
i agree...subbed
snolord1 is offline Find More Posts by snolord1
Old Nov 01, 2012, 05:26 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
What's the "VLF concept"? Vectored lift?
djacob7 is offline Find More Posts by djacob7
Old Nov 02, 2012, 10:25 PM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
I believe it is Vertically Laminated Foam. I have made some progress on the design, having laid out the initial design on a 24"x 48" rectangle (1 sheet of MPF). I will start cutting this weekend, then no doubt make some changes to the parts. I am also working up an F33 tail and some fancy vac-formed parts just for fun, in order to give a choice on the version of Bonanza. I will snap some photos during the fit up.
Old Nov 02, 2012, 10:36 PM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
Latest:
Old Nov 03, 2012, 09:02 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Vertically Laminated Fuselage
Ken
Old Nov 03, 2012, 09:16 PM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
Thx Ken
Old Nov 04, 2012, 03:32 AM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
More progress... I have started cutting foam, starting with the tail surfaces. The horizontal for the F33 version can be cut in half to make the V-tailed 35 version. I will be making 2 interchangable tails for testing. All tail surfaces were enlarged a little further to enhance stability & to facilitate having enough stabilizer area when making the V-tail out of the straight-tail parts. I hope to have an airframe for glide tests by tomorrow or the day after.
The F33 version looks pretty nice... see pic below.
Question: I am planning on ailerons, but I was curious about trying out a version without them. Does a KFm2 airfoil work with a no aileron configuration? Dihedral would be around 6 degrees I think.
Oh, in the last picture I was playing around a bit.
Old Nov 04, 2012, 03:34 PM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
Here are a few shots of today's progress. I'm starting to get excited! Had to quit before I wanted to- darn.
Old Nov 04, 2012, 06:48 PM
TheAeronut is online now
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
I am watching closely as I like the V-tail Banana... One comment here. The way that you are doing it, using the same parts for the horizontal of the + tail version and the whole tail of the V tail version is going to make it an apples to beans comparison. Either your + tail will be significantly larger than necessary, or your V tail will be smaller than necessary. Larger is fine, but smaller than necessary is very bad. To make it a reasonable comparison, the total V tail area should be the same as the TOTAL horizontal PLUS vertical area of the + tail.
Just hoping to avoid having a poor design give the V tail a bad rap.
J.P.
TheAeronut is online now Find More Posts by TheAeronut
Old Nov 04, 2012, 07:03 PM
Reehoe is offline
Reehoe's Avatar
Joined Sep 2004
Oh don't worry, I am considering those factors. The standard horizontal is indeed enlarged so that there will be enough area when converting to the V tail. Yes, that does mean that the standard horizontal stab is bigger than it needs to be, but that's ok for me. It could be trimmed down if necessary.
I will make sure that the V tail will fly nicely, as that is the version I like the most. As long as I give it enough area & have the V angle correct (I went with 33 degrees from horizontal), I am fairly certain it will fly well.
Thanks for the input, and feel free to chime in anytime.
Old Nov 05, 2012, 06:23 PM
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
Sure. I am not trying to step on any toes here. I just figured that it is better to speak up if you already know rather than say nothing and find out too late that you didn't know. I am watching with interest.
J.P.
Discussion A-26 INVADER!!! 60" WS for 6mm (MPF) by SNice SNice Foamies (Scratchbuilt) 84 Feb 15, 2013 12:00 AM
Data Post your Model Plane Foam (MPF) Test & Build Data Here! Freddie B Foamies (Scratchbuilt) 15 Dec 15, 2012 11:23 AM
Beechcraft Bonanza V35 3-views? Hannu Vuorinen Scale Kit/Scratch Built 6 Oct 19, 2005 12:55 PM
