Old Dec 01, 2012, 11:53 AM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Think i diagnosed my performance problem. Was looking at back end of all my edfs today. Looking at the 15 i saw the motor was way off center. So took the fan off and sure enough the back end of motor was rubbing on housing. The blade tips too were rubbing. How this fan didnt explode idk. Finallt got the rotor out and saw the motor mount section was partially melted and no longer straight. Took the motor out and the backside of the mount had a melted in outline of front of motor. This shroud is done. Im thinking that when i had originally extended the wrong side of the wires and it melted wires the motor prolly got real hot too.
Edit. Had a cs shroud laying around. Filed down the dynam rotor to get it to fit. No rubbing this time. Plane back together and will test fly in a bit.
Edit. F15 flies again. I did a little intake work while it was opened up. Im sure the fan rubbing was main problem but its faster now. Will vid later today on 5s.
f15 (0 min 0 sec)
stingeragents is offline Find More Posts by stingeragents
Old Dec 02, 2012, 10:28 AM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
You build nice birds!!
RogueAce is offline Find More Posts by RogueAce
Sold Tekoa shadow 118 inch onefield Aircraft - Sailplanes (FS/W) 4 Mar 03, 2012 12:18 PM
Discussion DC-6/C-118 lighting configuration payne9999 Scale Kit/Scratch Built 3 Feb 24, 2012 03:17 PM
For Sale Airfield 64mm F15 and 70mm F16 kkurtz Aircraft - Electric - Jets (FS/W) 5 Dec 29, 2010 12:50 PM
Discussion HobbyKing 70mm EDF EPO F15 KCV6 Foamy EDFs 2 Dec 15, 2009 06:30 PM
Discussion New 70mm F15 from StarMax marcelo3d Foamy EDFs 1 Jul 28, 2009 05:10 PM
