Old Nov 14, 2012, 02:43 PM
stingeragents is online now
Find More Posts by stingeragents
Joined Jan 2011
Well finally was able to take it for a flight after redoing the wire lengths. Flies great now, with no motor cutout. The sorta duct work I did improved the speed a bit. Think I will try it with 5s next and also need to get a paint job on this thing
stingeragents is online now Find More Posts by stingeragents
Old Nov 14, 2012, 03:21 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
stingeragents, Whats the WS and length of the 118%?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 14, 2012, 04:45 PM
Joined Jan 2011
Cant seem to find tape measure. Believe its around 50 or so length. Is at least a foot longer than my tomhe f22 and schumate f22
Old Nov 28, 2012, 07:41 AM
Joined Jan 2011
Well started to paint this last night with krylon fusion. Its been a while since ive spray painted a bird and i was thinking thats the right stuff. Already a few beers in i thought about spraying a test on scrap foam and said nah its good. Whoops.
Old Nov 30, 2012, 11:16 AM
Joined Jan 2011
Im the only person following this plane i suppose,lol. I reduced the intakes by half and this plane is still slow as a dog
Old Nov 30, 2012, 12:32 PM
Joined Dec 2008
Now you have reduced them to proper size. Question-- Are you maintaining that "size " and/or volumn from intakes to the fan? The pic you posted looks like they change in size as they go back to meet the fan. Must be the same all the way.
Old Nov 30, 2012, 03:33 PM
Joined Jan 2011
Hmm. Yea they arent 100% but i figured something would be better than nothing. One day ill get it down to a t making custom ducts. I knew the intake was way too big thats why i lessened. Probably didnt do it the best way but i just angled the top intake cover on each side down more. Im about to go fly it on a 5s 3000 to see how that does. Was only getting 500 watts out of the 4s. Think i will stick with single intake planes for a while as ducting is much easier. Im sure if i could figure out cad i could just make some ribs for the intake and then just skin it.
Edit. Back from flying. Flies notably faster and has much better sound. Still not yet where i want it but think ill leave it as is. I might add ailerons though cause my small elevons arent giving it much authority
Old Nov 30, 2012, 05:43 PM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
Stinger..Have you ever tried the Krylon Short -Cuts?? They worked great on the Meteor (EPO I think)and on the test pieces for the Bandit.($Tree ) I know that they will eat the softer foams..like packing stuff, even the stiffer packing stuff, unless covered. $4 a can at JoAnn Fabrics.
RogueAce is offline Find More Posts by RogueAce
Old Nov 30, 2012, 06:46 PM
Joined Jan 2011
I usually use testors but its 5 bucks a can for half the size of a normal can. Krylon used to make one called h20 and its been a while so i was thinking it was fusion but then i remembered. Ill have a vid of this bird in morning. Now that i tested the 5s i have enough batts to fly my 3 edfs at same time
Old Nov 30, 2012, 11:13 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Cool build, I have Schumate F18 plans blown up to about 150% for twin 70's. Yet to be built, to many other projects I run the Detrum 70mm combos on 5s, they really come alive! over 900 watts @ 56 amps. and they have held up well. You could cover the plane with a coat of water based poly and talc prior to paint. It sands super smooth, it seals the foam so you wont have any problems with non water based paints eating the foam. Would love to see a flight video
Lt599 is offline Find More Posts by Lt599
Old Dec 01, 2012, 12:12 AM
Joined Jan 2011
Will do a flight vid in morning
Old Dec 01, 2012, 07:10 AM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
How does the talc and water poly work??? Are you coating plane w/talcum powder then poly over it???? Never seen before. Sounds better than my masking paper and white elmers glue.
Old Dec 01, 2012, 08:04 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
you put the talc in the poly. it sorta acts like micro ballons does for resin. fills the small holes/weave,/etc....
This method is great for a quick smooth surface to get ready for paint, it has 0 structural qualities, where as your glue with paper/silk span/cloth adds some bit of structural qualities and benefits.
But like i said cant beat it for quick, light wieght, smooth finish to your bare foam
D_FAST is offline Find More Posts by D_FAST
Old Dec 01, 2012, 08:41 AM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Thank you D...1 more question please. What is the ratio of talc to poly on a per Qt?
Old Dec 01, 2012, 10:12 AM
Joined Jan 2011
Ive done this before. I just kept adding until it thickened up a bit. Im sure someone has posted an exact ratio but im more of an eyeball type of guy.
Sold Tekoa shadow 118 inch onefield Aircraft - Sailplanes (FS/W) 4 Mar 03, 2012 12:18 PM
Discussion DC-6/C-118 lighting configuration payne9999 Scale Kit/Scratch Built 3 Feb 24, 2012 03:17 PM
For Sale Airfield 64mm F15 and 70mm F16 kkurtz Aircraft - Electric - Jets (FS/W) 5 Dec 29, 2010 12:50 PM
Discussion HobbyKing 70mm EDF EPO F15 KCV6 Foamy EDFs 2 Dec 15, 2009 06:30 PM
Discussion New 70mm F15 from StarMax marcelo3d Foamy EDFs 1 Jul 28, 2009 05:10 PM
