Old Oct 31, 2012, 09:13 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
GMFC problems
Hi all,
Am having troubles using the "trim after cutting"......
Everything is fine cutting with "no trimming", "trim only" but
when using "trim after cutting" it goes "willy-nilly". The trim cuts are
way out of where they should be. Also the cuts are way out
of where they should be. It's like it forgets where the sweep is.
Has anyone seen this???
It's been a while since I've cut anything, I get "melted foam" when
cutting. Especially around L.E.. Can't remember if I add heat or slow
down.By the way I'm using ver 3.89.15.
John
jcyr1 is offline Find More Posts by jcyr1
Discussion GMFC with Profili and CAD Advice ALEX HEWSON CAD/CAM 2 Jun 13, 2012 04:22 AM
Discussion GMFC Problem with Windows 7 cpc625 Hand Launch 0 Apr 04, 2011 10:08 PM
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Help! "GMFC" PROBLEMS CUTTING TAPERED WING Dale W The Builders Workshop 3 Jul 22, 2007 01:56 AM
Discussion GMFC problem on tapered wing skankpile The Builders Workshop 7 Aug 20, 2006 05:35 AM
