Old Oct 31, 2012, 05:11 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Question
Gyro for ELEVON mix
Hi pilots, wondering if there is a gyro that can be used to stabilize "only AIL." function for Elevon/Delta mix computurized controls where you use only ch2 as AIL. and ch3 as EL. Joe.
jofro is offline Find More Posts by jofro
Old Nov 01, 2012, 09:25 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
I'm not sure I understand your question entirely, but I think the Eagle Tree Guardian can do what you want. You can reduce the elevator gain to zero, and it will only stabilize ailerons. It does the elevon mixing on-board
"The Guardian controls a total of 4 servos, and is flexible enough to support elevons, dual ailerons, and other configurations."
http://eagletreesystems.com/guardian/
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 01, 2012, 10:09 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Hobby King has a new very inexpensive 3 channel gyro assist which fits between rx and servos .
We have been using the small gyro assists from Horizon (AS3X) in a few models and this is extremely worthwhile - done correctly. The Hobby King is 14 bucks - other setups cost more - depends on what you want --
You have to orient the gyros such that trimmed -normal flight attitude is "center" of usable gyro travel correction.
It will take some fussing to get it right.
IF you have a small model - the AS3X system can be used - requires you use Spektrum radio setup
These AS3X are great.
richard hanson is offline Find More Posts by richard hanson
Old Nov 07, 2012, 08:49 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
The problem with that Hobbyking Gyro is that it neither supports dual ailerons nor Delta mix.
If it had these features, they could make it cost 2 times as much and would still sell much more than they do now.
Julez is offline Find More Posts by Julez
Old Nov 07, 2012, 01:40 PM
Brandano is offline
Find More Posts by Brandano
I might be wrong, but it ought to be possible to use two standard gyros in line with the taileron servos, both aligned to the roll axis. The same approach should work also with a V tail to discriminate between pitch and yaw.
Brandano is offline Find More Posts by Brandano
Old Nov 07, 2012, 02:15 PM
TheAeronut is offline
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
Brandano, you are correct. You could use two gyros as suggested. I was just thinking the same thing and was going to post such a suggestion but you beat me to it.
You could tune the gyro command anywhere from roll only through roll and pitch to pitch only by suitably aligning the gyro's axes. Easy enough to buy a couple of cheap gyros and try it. Of course, start with ground testing just to visually verify the proper direction of control feedback to pitch and roll perturbations.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Discussion Is it possible to do Elevon Mixing with a radio that does not support Elevon mixing? lbm323 Radios 7 Aug 03, 2012 06:25 AM
Discussion Spektrum DX7 mix instructions needed for elevon/elevator Jim Petro Radios 11 May 15, 2012 10:58 PM
Help! Eurgle 9X elevon mixing Teamsherman Radios 3 Mar 19, 2012 01:50 AM
Help! Older Futaba heli radio question...need to mix for elevons Jimmy JFlyer Radios 2 Mar 06, 2012 08:11 AM
Discussion Using gyros with DX7 elevon mixing Mtn_Commando Radios 5 Mar 08, 2010 12:05 PM
