Old Apr 13, 2013, 09:16 AM
MFR is offline
MFR
Find More Posts by MFR
MFR
just a ordinairy guy
Netherlands
Joined Sep 2008
Ken,
You're getting close,
I think we have the same approach, but slightly different,
I use a circular motion to pivot the pins, and builded two layers of PCB, each one for a door.
With my design i can choose which door will be opened, depending on which servo i activade.
Manfred.
MFR is offline Find More Posts by MFR
Old Apr 13, 2013, 10:47 AM
redboat219 is offline
Find More Posts by redboat219
Philippines
Joined Jan 2005
Why not cut 2 grooves through the PCB like this, ( ). Much simpler...
redboat219 is offline Find More Posts by redboat219
Old Apr 13, 2013, 02:14 PM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
Romel,
It seems simpler, but it's not going to work that way, there is not enough travel to open the doors completely across the centerline, the problem with the Bronco XXIII is, they placed the tubes near the centerline, more ideal would be a position against the outer hull parts, i've build it this way at my type VII and type XVIIb, giving me more clearance for the torpedo's, and lesser motion at the doors.
Modyfing the Bronco in such way would create more work than it's worth the time, even when you've done that, you still have to solve the mechanics to open the doors.
Manfred.
Old May 17, 2013, 12:15 PM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
As a reaction to the remark of Dave (Subdave) i dived into the shop and came out with this solution, pictures
The boat put together without using glue.
To get her apart you start by "breaking" the backbone.
Then you remove the planking from the upperdeck in one move.
I glued down a few stainless steel rods of 1mm underneath, giving more strenght to those planking things, they are really flimsy straight out of the box.
The single one near the tower goes off the same.
Once the planking is gone you can reach the little brass screws which are hidden underneath the planking.
All visible one's will be sealed with filler and can be made free with little effort.
Once the planking is gone i can take of the exhaustcover by unscrewing it, a small brass hook keeps it tight at the hull, used the same method for my conningtower.
Now all components are removed i can start untightening the little brass screws.
Once this is done you can split both halves, you can see the brass lips which keep both halves together.
The only place where i have to cut will be the bow, want to use simple CA to glue it tight, which can be broken open easely without much damage.
Once finished you end up with this pile of styrene, for putting her together follow the reverse order.
I hope this answers your question Dave, for me it's back to the shop for preparing my boats for next Monday, the annual submeet in Holland
Manfred.
Old May 20, 2013, 06:45 AM
DDG 51 is offline
Find More Posts by DDG 51
DDG 51's Avatar
EUrope
Joined Apr 2008
Is on the market WTC for this size of sub??
DDG 51 is offline Find More Posts by DDG 51
Old May 20, 2013, 07:37 AM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
I like it.
Very nice job! Dave.
Subdave is offline Find More Posts by Subdave
Old May 20, 2013, 12:28 PM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
Peter,
You've got a personal message from me.
Dave,
Your remark about still getting in after completion, stirred the gerbill inside my head, i decided to use little conical screws, when the model is finished i can cover them by using filler, if needed i can scratch away the filler and open up the boat without major damage to the hull.
Manfred.
Old Jun 04, 2013, 06:58 PM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
How is your build coming Manfred?
I started my Bronco build on the SC site.
I am using a similar design to your rear assembly.
I really liked that idea. Thanks for the inspiration. Dave.
Old Jun 05, 2013, 02:09 PM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
Dave,
I'm working my way at the conningtower, found some nice pics of the XXIII without the standard railings around the tower, the added extra steps into the tower for climbing in.
Since there will be more type XXIII's in the build, i wanted to make mine different, pictures.
Glad you could use my rudder/ propulsion module system, this is the way a forum should work.
Sticked some tape on the tower and started to draw the new floodholes accourding to my pictures, they added some bars inside those holes to replace the railings.
The steps going up the tower are the replacement for the standard ladder on front of the boat.
Those floodholes made by Bronco inside the exhaustcover i've redone to get a better shape, also added the bars for prefenting stuff entering the exhaustcover.
Right now i'm building on the deck, this picture shows the strange railings added to the deck, i was wondering why they added those.
Got my answer on this picture, those rails are part of the system to keep the wooden plank modules at their place when in harbour, notice that there is also planking around the bollards.
Used those plank modules to align the railings on my deck.
Used some H shaped styrene, which allows me to "click" in my modules, since i also need planking around the bollards, i have to scratch me a extra module.
Manfred.
Old Jun 08, 2013, 07:08 AM
ken_nj is offline
Find More Posts by ken_nj
GSMB Member
ken_nj's Avatar
United States, NJ, Howell
Joined Mar 2008
Looking good Manfred. Your very detail oriented. That certainly slows the build down, but as long as it does not matter, the end result will look great!
ken_nj is offline Find More Posts by ken_nj
Old Jun 09, 2013, 11:44 AM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
Ken,
It surely slows me down, but when done properly you're boat will be standing out in the crowd, just like you, i like details also, to my opinion they add so much to your boat,
Unlike most people think, there is much more detail present as expected.
I'll also will give you guys a update about my build, made a new planking module from scratch and added the stanchions and needed antennawire,pictures
First i made a copy from the Bronco part, not as good as theirs, but once painted and weathered it will be hard to see.
Also had to make the front planking module removable.
Took some copper rods and replicated the one's Bronco added to the kit, the tricky part was, drilling the 1 mm holes.
Made a little ring on the tower where i can hook up the line.
Dryfitting the line to see where i've had to place the ring on the deck, i always use elastick rubber cord, no springs needed, and easy to replace when needed.
Making the antennawire was a bit of a battle, it took two attempts, but i'm pleased with the result, most work was making the insulators the original way, you have to wrap your wires around both sides on the insulator, a bit tricky and time consuming, i went for the three insulator one, i've also seen pics with four insulators, but this way there will be some lengthy antennawire left.
This is where i stand now, stanchions and antennawire placed, the stanchions are removable, will only be used at the static display.
For now i'm working on the hatch where they storaged their dingy, have to add some more accurate parts.
Manfred.
Old Jun 17, 2013, 03:32 AM
profesorul is offline
Find More Posts by profesorul
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI MANFRED,
Not get enough to watch what comes out of your hands ...... watching breathless every post to see what you've done!.
THANK YOU for THAT.
MARIUS
profesorul is offline Find More Posts by profesorul
Old Jun 18, 2013, 10:11 AM
fuwen0202 is offline
Find More Posts by fuwen0202
Joined Jun 2013
Im a chinese,goods seems good, cloud you tell us where you have buy can shipping to foreign?
fuwen0202 is offline Find More Posts by fuwen0202
Old Jun 18, 2013, 10:30 AM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
MANFRED! you are a true modeling CRAFTSMAN sir! Beautiful work!
fuwen0202 Bronco models, the source of the plastic model IS a Chinese company:
http://www.bronco-model.com/cn/index.php
You can buy them at home!
Majortomski is offline Find More Posts by Majortomski
Old Jun 19, 2013, 01:26 PM
MFR is offline
MFR
MFR
Netherlands
Joined Sep 2008
Thanks Guys,
Made some more progress on this boat, detailed the resqueboat hatch, added some detail to the mainhatch of the tower and made me a resquebouy from scratch, pictures.
This is where i stand now, i'll show you guys some details.
The lockingmechanism is in general the same as they used on their watertight ammo containers, just more beefy.
When you unturn the bolt it's possible to swiffle the lockingbar away, then the hatch can be opened.
The mainhatch on the tower is a bit standard.
Remade the hinges and added some handels, now it's possible to open up the hatch when needed, instead being glued tight open or closed.
Don't know why they didn't add the safetybouy, but i wanted one, most pictures i have showed them on the boats.
Took some 3 mm plexiglass and copper plate to make these items.
Placed at the peroscope protecter, the bouy itself can be taken from the holder when i will drive the boat, at static display it will be added.
Right now i'm working on the snorkeldevice, the guys from Bronco gave me a good start to begin with, i will turn it inside out and give it some working details, be patient.
Manfred.
For Sale 32nd PARALLEL TYPE XXIII U-boat kit propofol1965 Boats (FS/W) 8 Feb 02, 2014 01:40 PM
Sold what are these worth??sell or trade(6cell nicads) helizrnew2me Aircraft - Electric - Batteries & Chargers (FS/W) 7 Nov 16, 2012 04:55 PM
Discussion What type of battery connectors are these? qwerty11 Batteries and Chargers 2 Apr 17, 2012 10:10 PM
Special Navy 1/72 Type XXIII redboat219 Submarines 5 Mar 12, 2006 12:12 AM
