Old Oct 30, 2012, 11:45 PM
swolrath is offline
Find More Posts by swolrath
Joined Jan 2011
Help!
Eagle tree pro rth
Thank you for any help..
New to the osd. So far have it all working well apart from the rth...
Fail safe works, trim the throttle back works to actervate. It say it is in return to home mode but no servos move no throttle.
It just falls from the sky till it is 100 meters under ground.
(in sim mode)..
I don't have a flight stabilizer yet, dose it need one? I know it helps but i don't think its a must. Its on order anyway
swolrath is offline Find More Posts by swolrath
Old Nov 02, 2012, 07:00 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, in the simulator (as well as in actual use) you need to be at least approx 60' above the home point for the throttle aspect of RTH to work. Also note that you'll need to have run the "safety wizard" for RTH to work correctly.
Regarding using the stabilizer, it is strongly recommended. But, in the simulator, it does not really affect things, so the simulated model should fly around correctly if RTH is configured correctly.
If you still have problems, can you post your OSD Pro config file (.TXT) and we can check your configuration. This is saved by clicking "Save configuration" on the OSD Pro setup screen.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 18, 2012, 11:22 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
swolrath,
If you need further assistance, there are many qualified people who frequent this thread.
http://www.rcgroups.com/forums/showt...24018&page=657
m_beeson is offline Find More Posts by m_beeson
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11416 May 30, 2016 07:04 AM
Discussion Wind and the Eagle Tree RTH hornant FPV Talk 21 Apr 08, 2013 08:24 AM
Help! Eagle Tree RTH ZII issue ? hotdog1 FPV Talk 9 Oct 24, 2012 10:59 PM
Discussion Where can I find RTH Manual Eagle Tree OSD pro? rapghsi FPV Talk 3 Oct 04, 2010 02:11 PM
Discussion Need help with Eagle Tree OSD RTH! Ellis108 FPV Talk 2 Nov 30, 2009 10:28 PM
