Old Dec 07, 2012, 06:40 PM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
I worked on the fuselage, tonight; mounting the rudder and elevator servos and rough sheeting the fuselage back to the wing trailing edge. I need to:
-- add the cutout sections at the canopy's fore and aft ends
-- build and mount the canopy
-- add the final ring to the cowling
-- add the sub rudder and the tail wheel
-- make arrangements for attaching the wing
-- determine the firewall offset for the motor and prop combination
-- install the motor and its mounting
-- install the Rx
I'm still wondering if I need to provide a hatch, if I can remove the forward canopy to add and remove the battery.
davidterrell80 is offline Find More Posts by davidterrell80
Latest blog entry: The last 55 airworthy Spitfires
Old Dec 09, 2012, 03:21 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Looking great Dave.
Oh I have a cat too. However it s I who is the assistant most times...
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Dec 09, 2012, 09:05 PM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
David,
How are you going to make the canopy? Everything is looking great!
Conrad
conrad907 is offline Find More Posts by conrad907
Old Dec 09, 2012, 09:30 PM
Joined Apr 2012
Thanks, Gents!
It's good of you to complement the build so. I know that I'm nowhere the craftsmen status of the two of you but, I do OK in a slapdash, "make it fly and look OK at 30 meters" manner of building. And I take great pleasure out of doing so. I'm enjoying watching your respective builds come along, very much.
Regarding the canopy.
I can easily divide it into three sections: Forward, Central and Aft.
Forward: I've been thinking about trying the "Poor Man's" method of making a plug and brute force shrinking a section of soft drink bottle around it, using a paint stripping heat gun, without vacuum. But I have a shop vacuum and this may be the excuse I need to make a very simple, reasonably sized, vacuum box.
Central: These are simply planar sections. I plan to frame up some plastic pieces.
Aft: The Skua had a quarter-cylinder section that the gunner could revolve over his head to expose himself when plying the aft machine gun. I'm thinking of omitting it entirely, giving me a very ample exit for cooling air coming in through the cowling. I am thinking of making a simple aft machine gun and some profile occupants for the cockpit.
David
Old Dec 14, 2012, 02:16 PM
conrad907's Avatar
Joined Feb 2012
I like your idea for the rear canopy being open with a gunner. As you say, the ventilation is a good idea. I must try to make allowance for some ventilation in my own build as well.
Conrad
Old Dec 14, 2012, 07:56 PM
Joined Apr 2012
I've been fighting that Norovirus that is ravaging the schools in Virginia. The last three days have been miserable... except for the hour before dusk on Wednesday, when I took the UM Mosquito, UM MiG-15, Slowly and UM T-28 out for two flights each, before the sun set.
Tonight, I started covering tail surfaces. I need to retrieve the heat gun tomorrow, and tighten them up. Then I will be hinging the surfaces and attaching the control horns.
Old Dec 17, 2012, 10:59 PM
Joined Apr 2012
I covered the wing and tightened it up with the heat gun.
Things to do list:
-- connect and hinge the split elevators to the horizontal stab.
-- make and install the elevator control horn.
-- hinge the rudder to the vertical stab.
-- make and install the rudder control horn
-- make, cover and install the strip ailerons.
-- install the aileron pushrods.
-- cut and install the aft cockpit sheeting
-- make the plug for the forward canopy.
-- fabricate the forward canopy
-- fabricate the fwd cockpit sheeting
-- fabricate the pilot
-- assemble the fwd canopy, pilot and cockpit sheeting into a hatch
-- install wing attach fittings in the fuselage
-- install the leading edge fairings in the fuselage
-- fabricate and install the vertical sub-stab and tail wheel
-- fabricate and install the cowling ring
-- install the motor, ESC and Rx
-- bind to Tx
-- conduct systems test
-- mock up, measure and adjust preliminary CG location
-- cover the fuselage
-- fabricate and install the central windows
-- fabricate and install the aft gunner and gun
-- attach the tail surfaces
-- rig the rudder and elevator controls
-- add national markings
-- verify CG location
-- set preliminary dual rates and expo
-- conduct preflight inspection
-- take commemorative photos
Old Dec 18, 2012, 04:38 AM
Joined Apr 2012
I weighed the components, as they stand now:
Rudder (covered) - 4.0 g
Vertical stab (cov) - 4.7 g
Elevator left - 1.9 g
Elevator right - 1.7 g
Horizontal Stab - 8.3
Tail group (without hinges) - 20.6 g
Wing (with servos and covering but without ailerons or pushrods) - 61.5 g
Fuselage (no motor, covering, ESC, RX but with 2 x 9g servos) - 58.4 g
All up weight at this point is 140.5 g
So far, so good.
Old Dec 18, 2012, 04:58 PM
conrad907's Avatar
Joined Feb 2012
My plane is a lead sled compared to your numbers David. Those are very good weight numbers. Well done.
Conrad
Old Dec 18, 2012, 09:00 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
So far, so good.
Makes me feel like I am trying to fly a cow @ 907.19 grams....
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Dec 19, 2012, 02:06 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Weight numbers sound good!
gupi is offline Find More Posts by gupi
Old Dec 19, 2012, 10:35 AM
Joined Apr 2012
I keep reminding myself about keeping the weight down.
In a "10G" terminal velocity dive, high-rate, 100% servo throw pull up the loads will only be about 2000 g. I've static tested the wing to twice that load. In a "20G" crash (yes, I want my Skua to be a repairable pile of sticks), I'm only facing loads that are under 5500 g.
My instincts tell me to carve the plane from solid balsa; and, I'm not even including the strength in tension provided by the covering.
Must. Breathe. Slowly.
Old Dec 20, 2012, 01:50 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Just don't crash.
And remember: the lighter you build, the less mass you have - which means that the drag will slow you down enough that you won't experience 20G crashes with planes that small. At least when you remember to cut the power and pull the elevator when things go south.
Old Dec 21, 2012, 07:23 AM
Joined Apr 2012
The "quick and cheap" hinge material I chose is already cracking in fatigue. I'm going to have to cut them out and replace them.
The build is showing signs of "slapdash" construction I attribute to anxieties at work. I support troops in distant battlefields with information and instruction and some of the long hours (to accommodate time zone differences) and stresses communicated through the reporting and electronic communications rub off. I care about my "customers" and when they face danger, I worry that the information I provided is sufficient, and when they are hurt or killed, I grieve.
Whatever your nationality, please remember such people in your devotions.
Time for me to take a breath, go get some decent, pinned hinges down at the LHS and clean up the mess,
David
Old Dec 21, 2012, 09:11 AM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Your construction looks fine to me, Dave. Those of us who go down range appreciate guys like you who make it possible. God bless you.
Steve
Steve85 is offline Find More Posts by Steve85
Build Log BBCC 3 Guillow's B-29 Superfortress Conversion Smokin' Beaver Smokin' Beaver Scale Kit/Scratch Built 189 Apr 04, 2014 06:06 PM
Build Log #9 West wings Topaz Free Flight to RC Flight Kitbash Contest >>3DDFHobbies<< Keenan smith Balsa Builders 5 Feb 13, 2013 01:26 AM
Contest Free Flight to RC Flight Kitbash Contest >> Starts 17 Nov Murocflyer Balsa Builders 153 Dec 06, 2012 08:49 AM
Build Log #2 Free Flight to RC Flight Kitbash Contest >> AndyKunz << AndyKunz Balsa Builders 0 Oct 24, 2012 11:17 AM
