Old Nov 13, 2012, 01:34 AM
nkalex is offline
Find More Posts by nkalex
Joined Oct 2012
Bmatthews:
Your comments are welcome but you are insulting everyones intellegence with your constant ramblings about basic engineering concepts. I understand that an angled structure is more stable and that a wing must handle forces other than a shoe acting directly ontop of it. And I understand your g-force to sandbag loading experiment, not that I agree its a good measure of what forces a plane will actually experiance during flight.
nkalex is offline Find More Posts by nkalex
Old Nov 13, 2012, 01:39 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Priceless.
Piece is online now Find More Posts by Piece
Old Nov 13, 2012, 06:09 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Hold on there- B matthews is a highly respected member here.His 'engineering principles' are never in doubt- his credentials have been checked.
Your request for information has been answered,and we can do without the attitude....We don't think your structure will work....and we're trying to keep you from wasting your time. We don't care it you waste YOUR time,but if you can't take information and evaluate it,you're wasting ours.
Getting back to your question of covering,if your structure will support flight,then a good fabric covering will do the job..It's extremely difficult to get fabric to stick to metal frameworks,so they are usually applied with adhesives that bond the covering to itself,then shrunk with heat before finishing with paint.
Once more- the sag between ribs has been with us since the Wright Brothers,and by gosh,we've learned to cope with it by now.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Nov 13, 2012, 09:49 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
In the end your structure might just work. But if it does fly and doesn't fold under light loads it'll be more due to good luck than good engineering.
And just for a little FYI the distributed sandbag wing loading is another time honored "engineering trick" to evaluate the strength of wings. I didn't just make that up. It's something you can do easily and see if the structure will hold or fold before you go any farther with this project.
As I said in a post above. I DO comend you on trying something different. But you can't simply ignore proper engineering. Although you seem to be doing a good job of trying. So with that I'll simply bid you best of luck and bow away.
BMatthews is offline Find More Posts by BMatthews
Yippee! Check out my 22% Clipped-Wing Taylorcraft !!! shooboy Scale Fuel Planes 41 Oct 06, 2012 07:08 PM
Discussion Check out these frames I'm looking for some feedback LHMDrones Multirotor Talk 4 Oct 03, 2012 02:48 PM
Discussion scratch built 64mm edf the (BAT- WING) (^v^) check it out.http://youtu.be/5N2Uko8sEHs crispy1074 Foamies (Scratchbuilt) 0 May 18, 2012 02:20 AM
Help! Check out frame, oh and help with multiwii nabiul Multirotor Talk 6 Apr 10, 2012 02:39 PM
Discussion One more bug to iron out on my wing badlands Flying Wings 0 Feb 22, 2012 12:07 PM
