Old Nov 05, 2012, 08:34 PM
nkalex is offline
Find More Posts by nkalex
Joined Oct 2012
So any advice in the coating department or do you guys only want to talk about what a non-traditional design it is?
nkalex is offline Find More Posts by nkalex
Old Nov 05, 2012, 08:37 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Why go to all the trouble of using Lexan and all that jazz? Go buy some light cloth and stitch it over the frames like they once did for full-scale planes.
Or is that too traditional?
Piece is offline Find More Posts by Piece
Old Nov 05, 2012, 10:21 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Guys, does the troll have to hit you over the head with his steel framed, canvas and lexan coated wings to get you to realize what's going on here? Good grief!
Harry D is offline Find More Posts by Harry D
Old Nov 06, 2012, 09:27 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
We've been stretching fabric over 13" spans between ribs on full size ,man-carrying airplanes for 100 years-that part you don't scare me with.
I have some spaces on 1/3 scale models that are 5" and they fly fine,with rag covering properly installed.
Just listen when we speak ! your steel plans are not so good.....and you're most likely wasting your time...more weight needs more power,which translates to more weight,which you don't need.
Forgetaboutit ! Use wood...
epoxyearl is online now Find More Posts by epoxyearl
Old Nov 06, 2012, 09:31 AM
epoxyearl's Avatar
Joined Oct 2011
Report# 16
That did it for me! You ask for input,then drop a bomb....Please post a video of the crash.
Old Nov 09, 2012, 03:08 PM
nkalex is offline
Joined Oct 2012
Thank you, this is the kind of thing I was looking for.
I don't understand why you guys are acting like my wing is such a terrible idea, if it stays together in flight does it matter what the size/weight ratio is?
Sure it might be heavier than a wing with similar size made out of composite but who cares? I will make up for it with thrust.
Wings don't just spontaneously combust if they are a pound heavier than composite, or do they? Am I missing something here? Should I spill some blood to the god of flight so my plane doesnt get struck by lightning?
But I understand, the strongest human drive is to do what is familiar.
And to c4h10: the attitude of "if it worked why hasn't it been done" is crazy, if everyone had this attitude there would be no technological innovation. Also, I believe the word you are looking for is "litmus test" not "acid test", an acid test is a much different thing. Im suprised you overlooked this with your chemistry themed name.
Old Nov 09, 2012, 04:46 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I've been following this thread a bit.
Wood has always been a "standard" in wing building. It has worked well for many years.
You want to try a "non traditional" material. Go for it and see what happens. If it fails, you will have learned something in the process. If it succeeds you have learned something in the process. Either way you will learn something.
ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Nov 09, 2012, 08:40 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I actually commend your desire to do something different. But you seem intent on not only doing something different but at the same time doing it badly. Namely the "spars" for the wing. They won't combust but at the first steep turn or dive pullout the unsupported thin blades will simply turn into a "concertina" and the wing will collapse or radically deform.
All it would take would be the addition of two runs of L section steel fixed to the webs you've shown. One on the top and one on the bottom to turn the poor design into a good one.
Try it for yourself to see what we mean. Take a strip of pop can metal that is flat and push from each end. Crumples pretty quickly, right? Now bend the second same size strip into an L shape and try it again. It's a LOT more stiff and resists the compression failure.
BMatthews is offline Find More Posts by BMatthews
Old Nov 09, 2012, 08:47 PM
Balsabird is offline
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
Unfortunately, there is no way to prevent the fabric covering from sagging between the ribs, no matter how tightly it is stretched. The problem is not so much the spanwise distance of the ribs from each other but the leading and trailing edges being "lower" than the rib tops and bottoms, that causes the sag to occur.
And don't worry about the nay-sayers. Google "Fleetwings Sea Bird" for a really well-designed full-size seaplane made entirely of stainless steel...spot-welded throughout the entire airframe! I've seen it--it's a work of art.
Also, I'd advise not using actual covering fabric for full-size airplanes, as you mentioned Poly-Fiber. I'd go with one of the non-woven polyester fabrics such as sold by BP Hobbies or FAI Model supply. Don't over-shrink the covering as it might deform the structure.
Balsabird is offline Find More Posts by Balsabird
Old Nov 09, 2012, 08:54 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Why not have the wings machined from a billet? That will save all the extra work of covering. Then you can hit it with a quick coat of Rustoleum and be done. It'll be almost as practical.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 10, 2012, 02:29 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
Post up the weight of the wing before you assemble it along with the rest of the airframe. If this does fail get some very good pics and see how it could be improved. That's if there is any real advantages in the end.
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 11, 2012, 05:40 PM
nkalex is offline
Joined Oct 2012
Man look how flimsy this snapped together wing is , not even brazed together yet and it held 160lbs where I stood.
You guys are right, it will probably explode mid-flight because it isnt made using traditional methods.
Old Nov 11, 2012, 06:02 PM
Joined Sep 2012
Can you camp one rib in the vice and stand on another rib maybe three out or so? If it holds then this may just work. Is it going on a balsa fuse?
Old Nov 12, 2012, 08:48 AM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
So far so good. Keep us updated!
ken
Old Nov 12, 2012, 12:36 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Big deal.... I can balance my 200 lbs on an empty pop can with a bit of care. And it's a darn sight lighter than your steel parts.
And again you are assuming that strength in one way means that it will be strong in every way. But the structure will be loaded up in an entirely different manner when in flight and during high G turns and dive recovery than it is with you standing on one of the X's form by the rib and spar pieces.
Braze the bits together then clamp the root end in a vise and then hang bags of sand along the spar evenly. It's not uncommon for a model to need to withstand 10G's during an aggresive dive pullout. And if we can assume a 14 to 18 lb model from the size of your ribs that means each side will need to hold up pretty much 8 x 10 = 80 lbs based on a 16 lb model.
Yippee! Check out my 22% Clipped-Wing Taylorcraft !!! shooboy Scale Fuel Planes 41 Oct 06, 2012 07:08 PM
Discussion Check out these frames I'm looking for some feedback LHMDrones Multirotor Talk 4 Oct 03, 2012 02:48 PM
Discussion scratch built 64mm edf the (BAT- WING) (^v^) check it out.http://youtu.be/5N2Uko8sEHs crispy1074 Foamies (Scratchbuilt) 0 May 18, 2012 02:20 AM
Help! Check out frame, oh and help with multiwii nabiul Multirotor Talk 6 Apr 10, 2012 02:39 PM
Discussion One more bug to iron out on my wing badlands Flying Wings 0 Feb 22, 2012 12:07 PM
