Old Oct 30, 2012, 05:37 PM
viggen65 is offline
Find More Posts by viggen65
Sweden, Gothenburg
Joined Aug 2005
Build Log
Seaking Project
Hi Guys
Beside the Tiger project im now starting to build mine Century Seaking, for many years this one has been on my mind until now when I finally got the tum out of my a** and purhased it.
The plan is to make it fly with the Tf model Non tail mech and also the Imds system on the tail, since the seaking has a small fin and the stabilizator is fitted on the same height as the tailoutput it probable gone be hard to fit it directly in the tailfin, Kin has suggested to put in the fuse and run it with a flexcable which sounds interesting
The neat size of the mech is giving me a idea to put it as far as possibble in the doghouse of the fuse, since theres no tail to take in consider this shouldt be a problem, atleast at the planning stage..
The mech gone be powered with a Sk 3 competition series motor from Hobbyking alternative a scorpion motor on 6-8 cells,
Please feel free to to give me inputs along the building
Cheers
Jack
viggen65 is offline Find More Posts by viggen65
Old Nov 01, 2012, 03:51 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
The progress goes slowly on,yesterday i was to mine local hobbyshop and got
Some brassrails so the cabindoor could be openable.
It looking good with the mechanic but have to get a suitable 5 blade head,on this one the monsterhead dont gone fit well since its just to big,gone check up other brands soon...was looking on heli scale in france,they selling a penta head which looks nice but after some research i i got splitted..
The funkey quality is very satisfying and everything lines up real good.
Cheers
Jack
Old Nov 01, 2012, 08:43 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Got the motormount glued in place,wanted to find a place that in case of demounting wouldnt be to hard to reach,now both motor and cable adapter are accesible without issue,nest step is to made bulkheads for the tailpart of the fuse,since there wasnt any provided with the kit,it doesnt feel good just to glue the tailpart and leave it without any reinforcement,since theres not gone be any tailbom supporting the torque from the sixbladed tailrotor it feels comfortable
To secure whole tailpart with bulkheads to prevent it from twisting when putting loads on it.
Cheers
Jack
Old Nov 02, 2012, 05:38 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Some yeras ago i bought struts to a smaller jet which never got built,since the provided struts of the seaking wasnt much to hang in the christmas tree i managed to adapt them to the fuse,theres som parts that arent mounted yet which gone be fixed in some days,gone paint the struts in white colour when they are ready,sorry for the bad quality o the pics but its kind of handy to use the
Ipad instead of the systemcamera and a computer.
Cheers
Jack
Old Nov 02, 2012, 01:02 PM
rotoraddict is online now
Find More Posts by rotoraddict
Joined Jul 2008
This is really starting to look like a great scale heli. Two thumbs up!!
rotoraddict is online now Find More Posts by rotoraddict
Old Nov 02, 2012, 01:29 PM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
appreciated,thanks...this is really a pleasure building
Today i have decided on which colourscheme it should be at the end
http://www.scale-rotors.com/galerie/...k5-revell.html
Choosed this since its not the hardest to do with mine skills and it also pleases my eye, also have ordered the graphics from Callie graphics, they have outstanding and fast service, also a very fair price for custom orders, I payed 27$ for a complete set of decals seeing in the provided link, and the price also includes shipping to sweden.
Cheers
Jack
Old Nov 02, 2012, 01:31 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Just a remind the tail drive cable i think is one rotation direction , some of the flixable cable in market is onlt for one direction , so you must check you are using the (twist to tight) , it structur like a spring , you must use the direction is (tight ) . if you twist a spring you will understand the different .Must check it .i see the motor mount position , it is the best idea . if you have choice a scale tail rotor head direction (L or R) it effect you choice the tail rotor spin direction , but you must keep the tail cable is only one direction . if i have no wrong memory . your motor must be rotate CCW if you stand in the tail to see the motor , so the tail cable is ccw too . but after the tit should Left side tail rotor ! So the tail rotor is (Run to backward ) . so you have the right direction in whole drive set . but never try to empty spin the cable even no loading . tit is so easy damage the cable .you disconct the cable to check the motor direction it must be CCW !
kin is offline Find More Posts by kin
Old Nov 02, 2012, 01:37 PM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Thanks Kin
First of all, I shouldnt take credit for the motorplacing, it was yours idea from the
beginning, I thank you for that..
Regarding the cable, im gone check it up, Im not gone use the provided century cable
since all people are advicing not to since poor quality and that its also to thin, I have bought the more rigid flexcable from Approach engineering which are used by many scalers with great response.
Cheers
Jack
Old Nov 02, 2012, 01:50 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Just share a litte bit experience , but really check the cable using direction .especial in is not from hobby market . , normal market racing boat flixable is 80% CCW , but if your soucing is from other , . you must see the direction first , and Left tail rotor . you need change the tail blade grip holder 180 degree , let the tail rudder control rod pull to be Left rudder .
Old Nov 02, 2012, 02:51 PM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Just share atlwe bit experience , but really check the cable using direction .especial in is not from hobby market . , normal market racing boat flixable is 80% CCW , but if your soucing is from other , . you must see the direction first , and Left tail rotor . you need change the tail blade grip holder 180 degree , let the tail rudder control rod pull to be Left rudder .
Kin, I got an answer from Dr.tim at approach engineering
he says it doesnt matter which direction, this is due the cable is tripple wounded, not like the older speedos cable which wasnt, good news I think
Cheers
Jack
Old Nov 02, 2012, 03:32 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
The Seaking is looking good. Since the Century body is so large, most of the 5 blade heads should look good on top of it. A majority of the mechanism will be inside the body to keep things very scale. From many pictures of it, only the last couple of feet of the main shaft are above the doghouse so from a scale perspective, only 25mm of the mainshaft plus the rotor head will be exposed. Keep up the good work.
Don
Here is a link to a picture of one of ours on a very wet day.
http://www.djkennedy.com/Aircraft/Mi...SABd&lb=1&s=X3
Keyrigger is offline Find More Posts by Keyrigger
Old Nov 02, 2012, 04:39 PM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Don
Thanks Don,looking on yours picture i now see i have to do som adjustments on
The lenght of the tailwheel.
You absolutly right about the mainhead,should barely stick up of the doghouse,in the beginning my thought was to get another monsterhead same as on mine tiger,the problem with that head is that the linkage going down to swashplate is the same diameter as the swashplate resulting in that the hole in the doghouse has to be very big,mine tiger is 1,7 meter long and even there i had to enlarge
The tophole so it would fit,if to do that on the seaking i would have to go outside the doghouse..
So today i ordered the tf model 5 blade plug and play head,some year ago i built a 500 sized black hawk with that head ( 4 bladed) and i was very satisfied with the quality and it also performed very well in the air
Cheers
Jack
Old Nov 02, 2012, 05:14 PM
Keyrigger's Avatar
Joined Sep 2009
There are literally hundreds of photos of the Seaking online but this one shows the rear gear in flying condition. Is the gear on the model capable of collapsing so that it can be good in both conditions? Here is the other picture in fairly high res. Take care.
Don
http://upload.wikimedia.org/wikipedi...4_Sea_King.jpg
Old Nov 03, 2012, 02:30 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Don
No, they are actually not, but i now see that i got to redo the tailwheel completely, it has to be moved backwards, also if judging to the picture whole gearsystem has to be lovered, this is not a problem since its easy to adjust the lenght of the mainstruts
Ps...very nice picture, thanks Don
Cheers
Jack
Old Nov 03, 2012, 05:43 AM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Nice project Jack,
I will follow this one.
Jan,
Horseman is offline Find More Posts by Horseman
Discussion What timing should I set my Seaking 120A ESC MassiveOverkill Racing Boats - Electric 9 Jun 22, 2012 07:48 AM
Discussion Seaking 180? shovelnoserc Racing Boats - Electric 5 May 06, 2012 06:43 PM
Discussion seaking 180a esc questions igotit Racing Boats - Electric 9 Apr 29, 2012 07:26 AM
Question Hobbywing Seaking 2848sl 3900KV rmartin00 Racing Boats - Electric 15 Mar 24, 2012 05:24 AM
Question Tacon 3674 1300kv and seaking 120a frankykae Racing Boats - Electric 6 Mar 16, 2012 09:25 PM
