Old Nov 14, 2012, 08:48 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
My wings have been in the 150° to 155° on the leading edge, granted this wing is less angle, here's the data
Pro's:
Reduced drag across the whole wing.
Reduced tip stalling even further than the original
increased Lift to drag ratio. The Wing (starts) stall at 9-11* AoA at 240 mph, and approx 11-14* at 180mph. Meaning it is a crank and bank machine....
PS: Its a wing and a fin only nothing else to drag around
ApexAero is online now Find More Posts by ApexAero
Old Nov 14, 2012, 09:02 PM
Steve C is online now
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Sometimes we just like doing stuff different. It doesn't always have to be better.
I designed mine in math class in high school.
Steve C is online now Find More Posts by Steve C
Old Nov 15, 2012, 06:42 AM
vic welland is offline
Find More Posts by vic welland
vic welland's Avatar
Valdese NC
Joined May 2004
Nice job Steve, I like the look of that.
I must say this has been the most interesting read here in a while.
Good job to all.
The wave spar and forward swept wing for speed are intriguing
vic welland is offline Find More Posts by vic welland
Old Nov 17, 2012, 05:40 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Would someone take the time to tell me the weight restrictions on F3S airframes?
meaning the weight to square inches rule. I know a kilo is 2.24 lbs and a square meter is 1550 sq in....
thanks
Old Nov 17, 2012, 06:10 PM
Tzeentech is offline
Find More Posts by Tzeentech
Inglish Nub
Tzeentech's Avatar
Joined May 2012
75g/dmē is the current restriction.
Tzeentech is offline Find More Posts by Tzeentech
Old Nov 18, 2012, 02:31 AM
M. Koch is offline
Find More Posts by M. Koch
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Some other restrictions!
Maximum is 72V (16S), maximum flying weight of 5 kg and as Tzeentech said maximum of 75g/dmē wing loading!
Ciao, Marcus
M. Koch is offline Find More Posts by M. Koch
Old Nov 18, 2012, 09:17 AM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Hey Marcus is SW Composites still in business? I've emailed them twice with no responce.
arcticflyer is online now Find More Posts by arcticflyer
Old Nov 20, 2012, 04:20 PM
bigcatdairy is offline
Find More Posts by bigcatdairy
speed is always addictive lol
Joined Mar 2009
Originally Posted by ApexAero View Post
Just a rough layout, I was trying to leave room to cut in a servo pocket toward the rear. I would think this and a center layup should keep things stiff.
is that the wave spar you called?
and can you tell the advantage of this spar by the way? thx~
cyr
bigcatdairy is offline Find More Posts by bigcatdairy
Old Nov 21, 2012, 07:24 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
BigCat, this picture is worth a thousand words!
this was a wave spar pic
Hi guys, I think I got it figured out, how about if I made split templates like feather cut, make a third template with the wave, do the bench setup for cutting the core and cut the wave first into the foam block for the wing core, ad pre preg cloth/resin, bag. Now I have a core block of foam with the wave in it ready to cut the wing core out for sheeting etc. I believe if one goes about it methodically and with care the whole process could be done without loading up the trash can!
Tom
Ps: When Duralite first came out in the 90"s their first Rx packs were 2 cell lithium 'AA' size packs that were supposed to be mill spec. They produced 600ma@6v and would last a weekend of pylon race heats before needing charged. Anything out like them now?
I still have a dead pack and their 'special' charger!
here's another SFW to gander at!
Old Nov 22, 2012, 05:08 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Hey guys, love that wave spar picture. Seen Jaro Muller do that before.
Regarding foam core and wave spar combination, I guess you would have trouble cutting the foam and hitting the carbon with the hot wire.
Perhaps better would be to make a set of cheap moulds by using the foam off cuts rather then the core. Laminate a thin sheet of premade composite to the off cuts. I've seen Stumax do it that way with great results. Same for the 3de mould half with the wave form, however this time you just lay up some thin glass on it and fill, sand, PVA as the finish is not important on this part. Then build the wing hollow as in the picture. No need for a CNC machine and just a single set of good cores (get them done by a pro).
Just an idea.
jjmouris is offline Find More Posts by jjmouris
Old Nov 22, 2012, 03:11 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Pro,,, gee wizz thanks J. I'm humbled today and thankful as its a day to reminisce of our prosperity,, after taxes, and before black Friday anyway.
You have given me a better idea, thanks!
Old Dec 15, 2012, 04:34 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Another question for those whom know!
Are V tail fins counted as flying surface area?
Old Dec 15, 2012, 04:51 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
yes, but only their projection to the ground.
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jan 04, 2013, 03:18 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
CC160 hv question,
Ok, there are on both sides of the pcb what appears to be heavy buss bar material spaced about .015 apart, on each side of the esc. Question is can I attach a heat sink across? And, should I worry about shorting between their prospective gaps?
I want to machine a T shape heat sink, hollow the trunk, glue it to the rails, using the sinks for mounting. at the same time protecting the exposed components
Tom
Old Jan 06, 2013, 12:53 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Ok! How about does anyone know where to get 2 to 3 oz Kevlar tape for hinge lines when bagging??
Discussion New Speed (F3S) record, 400 kph+ at last... WimH High Performance 16 Oct 17, 2009 01:48 PM
Discussion German F3S Speedcup – info, pics, videos ... I-Love-Jets Pylon Racing 1 Jan 16, 2009 05:36 AM
