Old Oct 30, 2012, 01:39 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
Where would the CG fall on this Dimorphodon?
I estimate the CG at around 2 7/8" from center LE. Grid is 1" squares.I am assuming it will balance like a flying wing. Airfoil klinefolglemanM3. Span 6 feet. Controls ailerons and v-tail
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Oct 30, 2012, 02:30 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
The basic airfoil shape can effect the center of lift and therefore the CG. It is re-flexed? Airfoil number?
Gary Warner is offline Find More Posts by Gary Warner
Old Oct 30, 2012, 03:13 PM
Joined Aug 2000
Gary the reflex is going to have to come from the ailerons.
Old Oct 30, 2012, 04:13 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
Hi Joel!! I didn't catch your user name 'till just now. Good to see you and your work - our paths don't cross as much as they used to.
Honestly, you got me with that airfoil.
It is very short-coupled with respect to pitch, suggesting that the CG range is going to to be very narrow. I'd hate to suggest something that's not even close to being flyable. Maybe someone else has experience with that airfoil on either a flying wing design or at least something that's very short-coupled.
Not to leave you without any input, my thoughts for a regular, slightly re-flexed airfoil are that it should be in the 4" range (+/- 1/2")... but I don't want you to use that number without someone's experience saying so.
Have you considered the 'ol trial/error method of a small foam replica to experiment with?
BTW, wild design... It's got Joel written all over it!
Great project!
Looking forward to following your progress on this one.
Old Oct 30, 2012, 04:50 PM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
It is going to behave like a plank flying wing. The CG should be at about 22% MAC, and the flyable range will be very small as Gary said: too far forward and you won't have enough elevator power to slow it down to a reasonable trim speed; too far aft and it will be too pitch sensitive.
The airfoil does not make a difference to the CG location or stability (except for second order effects), only the trim.
Kevin
Edit: The second order effects can become important when you are flying with very small static stability margins (22% MAC would be about 3% SM, which is pretty small). Re effects, etc, can cause shifts in the neutral point on the order of a few percent. Normally these small changes don't make much difference, but when you have a very small static margin, they can cause significant changes in pitch stability with speed and AoA.
kcaldwel is offline Find More Posts by kcaldwel
Old Oct 30, 2012, 06:44 PM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
+1 Kcaldwel!
Curtis Suter is offline Find More Posts by Curtis Suter
Old Oct 30, 2012, 08:12 PM
Joined Aug 2000
+1 ? can you be more specific?
Old Oct 31, 2012, 03:40 AM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Your pictures of the model don't seem to match the sketch you showed in your first post.
From the sketch I'd suggest that the 20'ish% chord location would be about at the finger tips of the "hands". But your pictures suggest that the finger tips are far more back than that on the final model.
I suspect that the airfoil you chose is going to require a pretty good dose of aileron reflex since the ailerons are not very wide. And I don't see anything that is going to act like a V tail. At most you've got what appears to be some slight angle in the center section elevator. Or that could be just wishful thinking.
BMatthews is online now Find More Posts by BMatthews
Old Oct 31, 2012, 07:04 AM
Brandano is offline
Find More Posts by Brandano
I'd make a small chuck glider to test things out before testing the full size ship. Looks cool, it would be a shame to get a dent in it before it's fine tuned.
Brandano is offline Find More Posts by Brandano
Old Oct 31, 2012, 07:35 AM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
why not start by lightly throwing it while kneeling on the ground? this way it won't have far to fall, or just glancing impact with the ground. If things are looking right, give it a harder toss and hopefully it will go 40 ft. (from 4ft, 10:1 glide ratio).
greg
ciurpita is offline Find More Posts by ciurpita
Old Nov 01, 2012, 08:17 AM
Red Merle ALES
Joined Apr 2002
Joel,
That just means I agree with Kcaldwel
Curtis
Old Nov 01, 2012, 10:04 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
The KF airfoil is sturdy enough and easy to build but make larger ailerons -if you can.
and if possible make some w shaped bracing - (CF strips CA in place on bottom of aileron ) to stiffen em.
These all foam setups tend to bend easily and positive control can become vague.as speed changes
Most of the reason for the airfoil shape is to gain some rigidity.
airfoils are a compromise - strength first - shape next .
Your setup is a good compromise - but more variable -in undercamber - for slow flying may help.
richard hanson is offline Find More Posts by richard hanson
Old Nov 01, 2012, 10:16 AM
Joined Aug 2000
Richard, I used a technigue I found in the foamiies forum to stiffen the foam. You use newspaper/and or tissue. and titebond glue to layer with. It works incredibly well and is vey light. I have no worries about this wing or ailerons warping in flight.
RTF at present without paint is 7.2 oz psf
Old Nov 01, 2012, 10:26 AM
Joined Oct 2007
Good technique -- I did a few models which were covered in silkspan and painted with Titebond- stif and strong - easy to do
I now have a box of carbon bits n pieces - rods /strips etc.- so I just stick those in the surface using a sharp knife to install.
for my teeny tiny models - lighter .
Old Nov 01, 2012, 02:41 PM
MSelig is offline
Find More Posts by MSelig
FS One
MSelig's Avatar
United States, IL, Champaign
Joined Sep 2005
Brandano's got the right idea! So many times I see people skip this simple step w/ novel configurations. It works very well as a test w/o all the math.
MSelig is offline Find More Posts by MSelig
Discussion Fuel's affect on plane's CG; where will the fuel predominantly reside? Ian Davidson Fuel Plane Talk 35 Nov 28, 2014 04:41 AM
Discussion Where does this Camera fall between the #16 and #18 richkphoto Aerial Photography 1 Sep 09, 2012 05:20 PM
Discussion I would think that even this would fall under the 1st Amendment logan5 Life, The Universe, and Politics 15 Nov 04, 2010 02:02 PM
Cool This looks cool, but where would the CG be? Dancy Modeling Science 2 May 24, 2004 07:58 PM
Cool This looks cool, but where would the CG be? Dancy Modeling Science 1 May 23, 2004 11:43 AM
