Canada, BC, Kelowna
Joined Aug 2010
more hot air
Old hang glider pilots, Gary? I thought they were ALL old... around here anyway. Anyone under 40 flies paraglider. I have given up hang gliding but I do miss it.
Actually, I have found that the presence of gusts near the ground away from any obvious wind shadowing object probably indicates some form of thermal lift. It sure feels cold though sometimes. |
A couple of observations made yesterday. We've had a huge run of very light tumble weed seed heads from grasses around work, and they've proved to be an excellent visual aid for lift as they are picked up easily, and there are thousands of them and are big enough to be seen clearly at a fair height (though I wouldn't go so far as to guess, but certainly 100's of meters up). Each is probably about 1 foot/30cm in diam.
1. First thermal was a very large (200m+ diam) slowly clockwise rotating and rising mass of air, in which there was a central core of very fast rotation and high vertical speed air. This was clearly visible from the grass pods. Across ground speed was moderate, and once the lift had passed on, everything fell out of the sky quite quickly. 2. Same conditions, day and near exact same path of 2nd thermal. A very large (200m+) mass of slowly counter clockwise rotating mass of air with no core, but with slower ground speed and less sink once it had passed on. Interestingly, neither thermal attracted bird attention despite the fact that there are large numbers of soaring birds around (raptors as well as others). 3. Same day, different thermal path, soaring raptor. The kestrel thermaled up from just above tree height to out of sight circling both directions freely in what appeared to be the same thermal. 4. I need to take my DLG to work so I can take advantage of these well defined and often big areas of lift ![]() Steve |
Xc is often flown from ground height up to a mile high. Higher up the thermals can be huge. On the scale of miles. Often I skirt the edge of cloud formations. At that altitude I don't think there is much rotation and I usually don't circle because it is a race and I want some forward component towards the end at all times. Likewise sink can go for miles. I often find good lift at the edge of a cloud where there is a lot of activity meaning cloud formation and destruction. I usually don't see rotation in these areas. Pick a spot away from the sun some day and watch the cloudshow. It is very interesting.
Interesting question...my observation is most right handed people prefer to thermal CCW and left handed people like to thermal CW. Left handed people are usually better at going either CW or CCW.
When you are the first to initiate a thermal, you will probably have a tactical advantage if you can thermal well CW because you will out climb those who follow you into the thermal. This is also very true in full scale soaring. I am more coordinated when I "push" with my hand than when I "pull" with it . For this reason, there are right handed pilots that have learned to thermal CW with their left hand. |
Canada, BC, Kelowna
Joined Aug 2010
Left hand turns/cicuits
I think it goes deeper than hand coordination... I mentioned a little experiment with a bolt and a mirror.. no don't break the mirror! Take a regular right hand thread bolt and view it in a mirror while comparing it to it's "natural" appearance. Look at the pitch of the threads! Our perception is not symmetric! We aren't all the same either.. even left-handed people aren't all equally left handed. I write with my left hand but I throw with my right and turn left best. Our field made right hand circuits safer so I learned them as a beginner... but the expert always came in left-handed.
| Thread Tools | |
| Whoops! What happens when you turn out of the channel way too soon! | Rmay | Dock Talk | 6 | Feb 29, 2012 03:58 PM |
| Overlord - which way should motor turn? | borgs | Flying Wings | 2 | Sep 15, 2005 05:48 PM |
| Which way should my prop turn? | Mr.Dickles | Power Systems | 2 | Apr 19, 2003 12:35 AM |
| which way should prop turn | Rugerman | Power Systems | 7 | Dec 22, 2002 09:23 PM |
| which way ..if any do thermals turn?? | namder | Thermal | 14 | Jul 05, 2002 07:49 PM |
