You turn both right AND left.
A competent pilot is equally adept at turning in either direction. Ya kind hafta be. When a thermal lifts your wing, you steer into it, not away. Some thermals pop up on your right, some are your left. You adapt to the conditions.
"Ya play the cards what Mother Nature deals ya." |
Windsor, Canada, near Detroit
Joined Jul 2007
back to the point
ok guys, let's get back to the point.
when i started this thread i said (see post 1) : i will appreciate if any of you could tell me which way you turn to get into a thermal, and then which way you do to stay in it. or if you change direction for a reason. so far i have got enough evidence that thermals don't turn left or right, and that experienced pilots turn the way the thermal tells them it's located. if any1 has input that will add to the point, please bring it. comments on your experience in certain situations too. thanks |
Steve |
On the road I usually fly all the way through a thermal and out the other side before starting the turn. The way I turn to go back into it often depends on the terrain, the location of the sun, and how far off the road it is. I will take another pass all the way through the thermal at a different angle and try to mentally mark which side is stronger. Using this info I will then start the circle from where I ended up. The direction depends only on which way the perceived core is and the shortest path to it. I will only alter the direction if there is another plane in the space.
Closer to the ground I tend to fly the plane more like a dlg and keep it going the direction I start but adjust the location for drift by loosening and tightening the circle on the sides. |
Not to derail this thread but a more interesting question might be, "What do you do to quickly center and stay centered?"
My GPS triangle practice sessions revolve around (no pun intended) entering the thermal, centering as quickly as possible and maximizing climb rate. Leave the thermal, approach it from another angle and repeat. I'm w/ tkallev on this, for what it's worth. If you are favoring one direction over the other, you're handicapping yourself. For me, it was hard work to break that habit but I feel much more proficient knowing that I can wrap it up in either direction -- especially close to the ground -- when the need arises. This becomes especially critical as the wing loading goes up. Mike Quote:
Joined Jul 2007
great input
Michigan's Upper Peninsula
Joined Sep 2007
Phil,
Although I'm an e-sailplaner, I always learn in these forums so was visiting and saw your thread on turning. This topic has interested me for a long time. I have searched the web for an article I once read about a left-hand (counterclockwise) preference for most people in turning. I was not able to find the article I was looking for but I did find this from the National Institute of Health http://www.ncbi.nlm.nih.gov/pubmed/9104552 This indicates that there may well be a preference wired into us. A single, small study but thought provoking. Fascinating. I prefer left-handed or counterclockwise turns while soaring. Although I work hard on practicing right-hand turns, I seem to be much smoother going to the left. That said, I'll enter a thermal either way, turning into the thermal. A question that comes to mind for me is the following: Is there rotation in a thermal? If there is, I believe in the Northern Hemisphere the rotation would be counterclockwise (anti-cyclonic I think). If so I it may be an advantage to move with the rotation. Hope my musings are not too far off the topic. I'm sure we have a wizard or two out there who may comment. Thanks for starting this thread. Good mental exercise I think. Regards, Dave |
Joined Jul 2007
post 26
great input, Dave. and the link confirms what most of us do. i think it has something to do with the fact that, as we get more blood on the left side, the left leg is stronger-and heavier-so we lean on it to turn. it feels easier.
and your comments are welcome and very much to the point. regarding if there is rotation on thermals, i was under that impression, but lately i am beginning to doubt it. now i think that they just go up, like a cumulus does. just look at them (cumulus) how they grow up. |
Canada, BC, Kelowna
Joined Aug 2010
Although we are probably "hard wired" to be more coordinated turning to the left, we pilots probably vary as the thermals do. I believe the thermals are much more variable as an earlier post presented examples of different dust devils turning in each direction. A simple experiment showing bias in mirror image perception involves viewing a large bolt and it's image in a mirror simultaneously. Try to judge the pitch of the thread: you will be surprised.
Joined Jul 2007
regarding thermals...
this brings us into a subject that we have been discussing here:
http://www.rcgroups.com/forums/showt...64#post4966743 http://www.rcgroups.com/forums/showt...64#post4966743 the 1st is the forum, and the 2nd brings us to post 11, where he shows an illustration of his perception of thermals. see. if you want to elaborate on the subject, perhaps you could contribute there too? |
Joined Sep 2007
Now, you've done it! Woke up, looked at my planes early this morning and started thinking about the turning and thermal discussion. Found my gray matter (remaining gray matter) in an agitated state.
Do not be alarmed <smile>, but I did some more searching on the subject. I have no intention of finding a bunch of "odd bits" on the web and posting them here, but I found the following, very short article supportive of several of the ideas in previous postings. http://www.soartech-aero.com/Thermals.htm Dave (Note to self: Soaring might possibly be addictive. I don't have a problem. I can fight this, fight this, fight this...) |
| Thread Tools | |
| Whoops! What happens when you turn out of the channel way too soon! | Rmay | Dock Talk | 6 | Feb 29, 2012 03:58 PM |
| Overlord - which way should motor turn? | borgs | Flying Wings | 2 | Sep 15, 2005 05:48 PM |
| Which way should my prop turn? | Mr.Dickles | Power Systems | 2 | Apr 19, 2003 12:35 AM |
| which way should prop turn | Rugerman | Power Systems | 7 | Dec 22, 2002 09:23 PM |
| which way ..if any do thermals turn?? | namder | Thermal | 14 | Jul 05, 2002 07:49 PM |
