This thread is privately moderated by Green Fuel Boy, who may elect to delete unwanted replies.
Old Oct 30, 2012, 12:17 PM
Green Fuel Boy is offline
Find More Posts by Green Fuel Boy
Trader Rating: 30
Green Fuel Boy
United States, OR, Newberg
Joined Sep 2009
Trader Rating: 30
Sold
Two RCEXL Optical Kill Switches Free Shipping
RCEXL Optical Kill Switch ""NEW"" Two switches $26 dollars shipped USPS CON USA. Paid with paypal. Free shipping!!
These can be used as a remote switch to turn on/off a RC Airplane Gasoline engine ignition system. They can also be used to power lighting systems. The Rcexl Optical Kill Switch V2 uses a separate battery for power when not using a separate bec. The Rcexl Optical Kill Switch V2 does not use power from the receiver and this has no bec so the voltage going in from the accessory battery is the same voltage going to the item you want to turn on and off. The accessory battery can be up to 20 volt and 16 amp output for lighting or other devices.
This unit has no bec.
NEW Version 2.0
Remotely mounted bright LED ON/OFF indicator light
Fiber Optic Coupled Input/Output
Li-Pol/Li-Ion/A123/Ni-Mh/NiCad Input and compatible
Up to 20 volt 16amp output
100% surface mount technology
Heavy Gauge wire with Universal Connectors
Automatic Shut Down Feature when Transmitter or Receiver is Turned Off
Easy Installation
Light Weight
Green Fuel Boy is offline Find More Posts by Green Fuel Boy
Old Oct 31, 2012, 11:28 AM
Trader Rating: 30
Green Fuel Boy
Joined Sep 2009
Trader Rating: 30
Rcexl
I have 2 more.
Help! RCEXL opto kill switch does not work tried three of them Go4it Engines 48 Jan 31, 2015 01:15 PM
Sold Rcexl kill switch new NORSMAN Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 22, 2012 07:44 PM
Sold RCEXL optical kill switches Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 5 Oct 17, 2012 12:26 PM
Question Where to purchase Optical Kill Switch Mikep0011 Engines 6 Sep 28, 2012 05:52 PM
For Sale 3ea Smart Fly optical kill switch Lappster Aircraft - General - Radio Equipment (FS/W) 0 Jul 26, 2012 09:24 PM
