Old Oct 30, 2012, 12:14 PM
vernon7026 is offline
Find More Posts by vernon7026
Return of the Warlord
vernon7026's Avatar
United Kingdom, England, Wallington
Joined Aug 2009
Water pick up
Hey all
I have bought this part : http://www.horracing.com/product_inf...roducts_id=304
Where is the best place to stick it on a Genesis cat ?? I was thinking on the Strut ??
vernon7026 is offline Find More Posts by vernon7026
Old Oct 30, 2012, 02:15 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
If it were me i'd put it on the transom
rotorkilla is offline Find More Posts by rotorkilla
Old Oct 30, 2012, 03:23 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
I would go to the transome also. But myself I mounted a flush mount pickup to the bottom of my boat that I got at OSE.
HR
hotrodder is offline Find More Posts by hotrodder
Old Oct 30, 2012, 04:24 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
These are also very good;
or the dual flush;
Both types are available in the UK at Performance Models
Old Oct 30, 2012, 04:36 PM
fissio is offline
Find More Posts by fissio
Suomi, HKI
Joined Oct 2011
Btw, which one is more efficient? advantages and disadvantages?
edit: meaning normal pick up vs flush one
fissio is offline Find More Posts by fissio
Old Oct 30, 2012, 04:58 PM
paultbg is offline
Find More Posts by paultbg
paultbg's Avatar
United Kingdom, England, Birmingham
Joined Jul 2012
This one looks good too:
http://www.ebay.co.uk/itm/281004740226
Regards
paultbg is offline Find More Posts by paultbg
Old Nov 01, 2012, 11:38 AM
ANIMAL03 is offline
Find More Posts by ANIMAL03
Joined Oct 2012
If you are looking to have an extra line so your motor and ESC each have their own can you not just get a dual pickup rudder. Just a thought .
ANIMAL03 is offline Find More Posts by ANIMAL03
Old Nov 01, 2012, 02:33 PM
hotrodder's Avatar
Joined Jan 2007
The flush mount is less drag than a bolt on water pickup and the water tube is inside the boat giving it a cleaner look. On my king of shaves I have two dual water pickup's one for each motor and one for each ecs.
Old Nov 04, 2012, 02:13 PM
vernon7026's Avatar
Joined Aug 2009
How are these Pickups fitted ??
Old Nov 04, 2012, 03:47 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Vernon,
These are gued in place with epoxy resin and glasscloth.
As a side note; the angle the hose pillar makes with the intake doesn't make it a very efficient inlet.
My flush inlet on my Arowana are far more efficient and can therefore be smaller, giving the same flow even at low speed.
They are made from 4 mm aluminum pipe pointing towards the bow, with no 90 angle in the tubing....
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Nov 05, 2012, 01:35 PM
vernon7026's Avatar
Joined Aug 2009
Can you give me a link for these
baai Dankie
Old Nov 06, 2012, 02:59 AM
Sneek, Netherlands.
Joined May 2004
baai Dankie
Hi Vernon,
Are you from South Africa originally?
There is not much to link to, as I made these in- outlets from 4 mm thin walled aluminum tubing from the K&S stand in my local hobbyshop.
This is how it looks like on my Arowana, inlet and outlet next to each other in the bottom:
Inside the boat:
The straight pipe is the outlet, creating suction when the boat moves forward, the curved pipe runs forward to the ESC, where a small piece of silicon tubing is used to make the connection.
All long tubing is made out of aluminum, less internal drag compared to silicon tubing.
Due to the sucktion of the outlet, there is no pressure builup in the cooling system and the flow keeps going even when you're crawling along, once the system has been filled with water (with a burst of throttle).
Mind you, crawling along isn't wise with a fast electric, running partial throttle will overheat both motor and ESC!
Regards, Jan.
Old Nov 06, 2012, 11:03 AM
vernon7026's Avatar
Joined Aug 2009
Jan
Yes i am originally from SA, durban in fact,, although i am english speaking, i can praat a bitjie afrikaans, lol
Old Nov 07, 2012, 05:17 AM
acuamie is offline
Find More Posts by acuamie
acuamie's Avatar
Malaysia, Federal Territory of Putrajaya, Putrajaya
Joined Apr 2009
The twin water pickup at rudder work the best for me.
acuamie is offline Find More Posts by acuamie
For Sale Stern mount water pick up $12.00 thermal chaser Boats (FS/W) 0 Nov 17, 2011 12:10 PM
Question Water Pick-Up Tube Location A-37 Racing Boats - Electric 5 May 13, 2009 05:13 PM
Question Water Pick-Up Location A-37 Scale Boats 6 May 09, 2009 08:41 PM
Help! Proper placement of water pick-up tube? Jcopter Dock Talk 9 Aug 30, 2008 04:37 PM
Help! Balance, Water Pick UP unclecrash Dock Talk 9 Jul 10, 2006 09:46 AM
