Old Nov 02, 2012, 03:15 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
My big problem with the spear's aerodynamics was the abrupt change of the center section. Inbetween the two sides, the rear of the fuse area just dumps the air right before the fan. If that was filled in, and a splitter added that lead directly up to the fan, I think you'd eliminate alot of drag.
Also, on the rear end, the fuse doesn't taper back nicely. There's a nice big step before the end of the fuse and the EDF unit. If you fill that in, and taper it back softly, you'd pickup some speed aswell.
Are the spear's still available? I haven't flown an EDF in a while, and it would be fun to pick one up again. I'd probably only shoot for 120-130 though.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Nov 02, 2012, 03:17 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
fh64ucky is that CAT powered? :-))
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 02, 2012, 03:18 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
After looking at Steves, thats exactly what we are going to do and that should be the piece that puts us over the 200mph mark...I knew it needed to be done I just never got around to trying it.....
LOL Stone...you know it! =)
fh64_lucky is offline Find More Posts by fh64_lucky
Old Nov 02, 2012, 04:08 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Two more spears coming??! JOY!!!
Can't wait!!
Joe'll be over 200. I'll be a little over that.
murdnunoc is offline Find More Posts by murdnunoc
Old Nov 02, 2012, 04:50 PM
fh64_lucky's Avatar
Joined May 2005
LOL!!!!!! this will turn into full contact, I can see it now.....
Spears are a lucky find here and there...I seem to have decent luck getting them from private sales somehow.
Its not the takeoff or flights that hurt them,its the dang touch n go on landings that kill them with wing overs.
Old Nov 02, 2012, 07:14 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Is this what you're saying, Pete?
That chunk bothered me too, so I just went to town with some foam and a heated up pushrod. Still needs some cleanup but I think I'm on the right track.
I'll finish filling and smoothing around the intake at the sides, as there's a pretty good step there between the body glass and the fan mounting ring.
As a note, my Spear is actually a clone, so it may have a few details different from an Ultrafly Spear.
I've also cut up a slushie cup (small size from Sonic is perfect) to fair in the gap from the aft body to the thrust tube's end.
It'll be pretty "slickened" up when I'm done
The more airframe talk we get going in here, the better I see the Spear is for a high speed ship. (yep Joe, you told me...)
Old Nov 03, 2012, 11:48 AM
Team White Llama!
To a certain extent, yes that's what I meant.
Try to draw to two sides together, so that they keep the left and right sides of the incoming air from mixing before hitting the fan. Basically, you want to keep the left side, and the right side separated until just before the fan.
Also, some extra rounding on the outside intake lips never hurts. As round and as smooth as possible.
The sharp edges of fighters make people think that sharp=fast, but that's not really true when we are talking sub sonic. Subsonic likes smooth and round. So get that bird and smooth as you can! I'm talking tape over seams, servo covers, the whole nine yards. The small details count at these speeds!
Old Nov 03, 2012, 11:56 AM
Team White Llama!
Basically, run your finger across the side of the fuse, heading toward the fan. Notice right as the intake stops, there's that sharp lip? Run your finger across it, it's hard and jagged. When the air hits there, it's gonna breakup right there before the fan. And since that's on both sides, you're gonna have some nasty mixing going on there.
That's the area I would extend back, and taylor it right into the fan, keeping both sides separate until the fan. That should help out ALOT.
Old Nov 03, 2012, 03:23 PM
High Dynamic Thrust
Joined Feb 2007
that middle divider should be super smooth, going as close to the rotor as you can get it.
Old Nov 03, 2012, 08:25 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Grrr... That's going to interfere with my plans to do a bunch of rotor and motor swapping
I'm able to get to the rotor and pull it out through the front, and then release the motor out the rear as it is right now. Won't be able to remove the rotor with the divider going all the way up to the fan. I hate to dismount the whole fan when I want to make a change. And I fiddle a lot with swapping out components.
Guess you can't have everything.
...unless I make the divider removable with a couple of pins... Will work on that!
I'll for sure at least get the transition super smooth with microballoons and sanding.
Old Nov 26, 2012, 01:37 PM
boxster is offline
Find More Posts by boxster
Joined Nov 2012
200mph in a tiny jet like that .dont forget your carrier bag 4 the bits....thats if you can find them
boxster is offline Find More Posts by boxster
Old Nov 26, 2012, 02:05 PM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
This one did 152 before a 2.4 gHz lockout (early AR6100) turned it into the "bits" .
The next one built, did 173.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 26, 2012, 02:32 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Gary, thats fixable!!!
capt soap is online now Find More Posts by capt soap
Old Nov 26, 2012, 04:11 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Jet like what?
Spear?
This is no foamie pulled from the box with 4kW strapped to it.
Old Nov 26, 2012, 05:34 PM
efflux RC's Avatar
Joined Aug 2009
Cory will tell ya, I'll repair almost anything. But not that black one. This one (my first) was repaired 6 times. Either pilot error, (me) or lockouts. It was saved a cuople of times from reboots. with that early rx. I finally went to the AR6200 and never a problem since at our field that's know for having a "devils triangle" area for 2.4 noise. (nearly 5 years ago)
Site Sponsor
Discussion $99 200MPH radar gun. Koo Hot Online Deals 3 Sep 21, 2012 10:19 PM
Build Log Quest for 200mph EDF carbon dart kingkyle Scratchbuilt EDFs 23 Jul 07, 2012 06:30 AM
Cool HD Video: 200mph DS Acro with Wizard at Weldon Daemon Slope 71 Feb 22, 2011 12:13 PM
Discussion My first 200mph FPV plane with video! gundamnitpete FPV Aircraft 29 Oct 14, 2009 08:44 PM
Discussion 200MPH with 200W possible? 1atlas Pusher Prop Jet Models 15 Aug 16, 2007 12:21 PM
