Old Oct 31, 2012, 02:19 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by murdnunoc View Post
Those are more realistic speeds
I like when people take the effort and decency to post what the plane can actually do when it's not pushed by a 30kt. wind!
Great to hear about the 16/45/1 motors becoming available.
These give the opportunity to run the high power without being on the edge.
...or maybe ULTRA high power and still be on the edge!
Gary, what do you think would be the best use for the 5mm shaft motor? That's what I've got and I would LOVE to run it in the Mach alloy fan.
Any chance there could be a 5mm shaft adapter for the fan?
I'm waiting to hear back about the Mach 70, with a 5mm shaft adaptor. It's probably going to need a rotor which means, all new 3.17 and 4mm shaft adaptors as well. I feel the requirement for 5mm shaft versions will be very low though.
You guys might also consider a cut down Shubie DS-51 rotor.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Oct 31, 2012, 02:21 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
It has been said the the CS fan is a thrust fan with lower velocity, I don't agree with that. You can calculate the airspeed (m/s) from the thrust (Kg) and the exhaust areal. So if two fan push the same amount it is the exhaust areal that decide the airspeed. Here is a nice link that explain how the physics works. http://www.scribd.com/doc/102868763/Thrust-Calc
The exhaust areal on my mod. Fan with a 40mm motor is 28% less than a 70mm fan mounted with a 28mm motor. This means that the airspeed is 28% higher on my fan if you compare the fans at the same thrust.
I did some calculations on my fan and reach 519Km/t at 3.6 Kg of thrust.
Also I think a cut down CS90 has a better chance of survival at high rpm's. First by cutting it down you will loss some weight giving less load on the blades. Another ting is that you will have a reduced centrifugal force due to the small length of the blades and one more thing, it is stronger build than any other 70mm fan that I seen, exept for alloy and carbon fans.
frank40 is offline Find More Posts by frank40
Old Oct 31, 2012, 02:33 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
I am going to have to agree with Efflux. A carbon or aluminum 4 or 5 blade higher pitch rotor, spinning slightly faster.
However again... It is more a matter of aerodynamics than power. In the real world it takes many more HP for a couple knots, than it does to improve somethign aerodynamically. For instance on my Uncle's Lancair Legacy, simply wheel pants or even a more efficient cowling can improve over 10knots for the cost of 2 knots in engine work....
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Oct 31, 2012, 02:44 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
4 or 5 blade fan is best for the high rpm range. these are also called high dynamic blades for a reason. once you reach the high rpm range a higher blade count will not cut clean air. ( air between blades ) a CS fan doesnt hold a candle.
a perfect example. my 110 mm fan with 4 blade high pitch rotor is giving approx 14.5 lbs of thrust with high efflux. now the same power set up on a 110mm fan with a 12 blade rotor is a couple POUNDS less thrust with lower efflux. and if you were to spin it even faster the 12 blade efficiency simply drops more. high blade count rotors are best for mid range thrust and if you have a noise ordinance in your hood.
stoneenforcer is offline Find More Posts by stoneenforcer
Old Oct 31, 2012, 05:03 PM
Mark is offline
Find More Posts by Mark
My dremel tool has no fear
Mark's Avatar
Reston, VA
Joined Dec 1999
I am not building this to go 200,but this probably the right idea
Het 6904 4S @1000 watts
MH33 airfoil
Mark is offline Find More Posts by Mark
Old Oct 31, 2012, 06:37 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Would a het f-104 make a good high speed airframe. That's what it was in real life, short distance sprinter!
capt soap is online now Find More Posts by capt soap
Old Oct 31, 2012, 07:26 PM
Joined Nov 2010
Sorry... This was a bit of a harsh post.
Essentially I was just stating how hard that 200mph barrier is. Over in the high performance thread this is well understood. However over there the airframes are more efficient and the prop power systems are more efficient. I simply think this is a difficult challenge and that standard jet airframes will be extremely hard!
Old Oct 31, 2012, 07:38 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
There are some great minds here. You're not the only one who has understanding of power systems and airframes.
The EDF hotliner is a good idea. It may even be the best as far as the least watts for the most speed.
That's not what everyone goes for, though. Some may want a 200mph F-16, and are willing to do what it takes to get it.
If 177mph can happen on, say, 2500W, then 200mph will undoubtedly happen on 3607W. Just a matter of getting the motor and fan that can handle the power, with no other airframe changes other than strengthening required.
If it were down to efficiency alone, no one would even be running an EDF. But here we are..
murdnunoc is offline Find More Posts by murdnunoc
Old Oct 31, 2012, 10:12 PM
Joined Nov 2010
Very true, and after reading my response I see I was slightly rude. I do appologize and hope that others can see past that.
I was simply thinking it will be really hard fitting that amount of power into these smallish airframes.
At some point we have to think about efficiency it will probably need to have a bungee assisted launch or 3 wheel trolley as I have seen some do (Gary, aka efflux as well as another guy.) More efficient airframe means less power, less weight, less launching and landing complications.
Old Oct 31, 2012, 10:29 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
200 will happen!
We have all the right ingredients. Just have to do some theorizing, testing, and refining to get it to happen.
High power density batteries and efficient motors make the 200 barrier very achievable on several of the airframes we've discussed. Sure, it takes power. But we have the power...
...least it won't take 5000W like it does on my Stryker.
...I hope
Old Oct 31, 2012, 11:06 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I think the Chimera delta that we designed will be more than capable of 200+MPH with the right setup in it. it's been designed with minimal drag and frontal area as the key features.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 31, 2012, 11:11 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
my all composite 70mm F-20 might could do it the fan location can slide about 2 inches and the batt area is close to 12" long ,the F-20 has a pretty far fwd C/G so who knows what could be stuffed into it .
did'nt knifeliddle try this a few years ago ...i think he got close.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 31, 2012, 11:12 PM
Joined Jan 2009
plus, the F-20 is just all kinds of cool.
Old Nov 01, 2012, 01:12 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
I am working on a new design, the plan is to use two of my cut down CS90... I just hope this is a project at I actually complete.
Old Nov 01, 2012, 03:11 AM
Joined Jan 2009
kinda looks like that twin tail version of the F-5. very cool, just like all your designs Frank.
Discussion $99 200MPH radar gun. Koo Hot Online Deals 3 Sep 21, 2012 10:19 PM
Build Log Quest for 200mph EDF carbon dart kingkyle Scratchbuilt EDFs 23 Jul 07, 2012 06:30 AM
Cool HD Video: 200mph DS Acro with Wizard at Weldon Daemon Slope 71 Feb 22, 2011 12:13 PM
Discussion My first 200mph FPV plane with video! gundamnitpete FPV Aircraft 29 Oct 14, 2009 08:44 PM
Discussion 200MPH with 200W possible? 1atlas Pusher Prop Jet Models 15 Aug 16, 2007 12:21 PM
