Old Dec 04, 2012, 09:02 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
looks fast Lee.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 04, 2012, 09:07 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by LuvEvolution7 View Post
looks fast Lee.
It will be. The prototype was capable of doing 90mph. I think this one will break 100mph. So just multiply everything by 2, and you get a 70mm edf that will break 200, right?
Knife Liddle is online now Find More Posts by Knife Liddle
Old Dec 04, 2012, 09:24 PM
johnny_0 is offline
Find More Posts by johnny_0
Canada
Joined Dec 2005
Originally Posted by murdnunoc View Post
So the 90mm CS rotor cut down to 70 would blow up at 60K?
Has anyone tried? Isn't that what Knife Liddle has on his super fan??
Ive cut down a CS 90mm to fit a 70mm fan, ran it at 60K and it was fine. The thrust wasnt there though even on 8cells. I havent tried it at a higher RPM.
johnny_0 is offline Find More Posts by johnny_0
Old Dec 04, 2012, 09:50 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Them's some good math there, Lee.
Double the diameter, double wingspan and battery, and you should double the speed.
FOOLPROOF!!
...that thing looks a little Spear-ish
Nice airfoil?
That's something that's haunting me about the Spear. It's pretty flat-bottomed which is not what we need for straight line speed.
Though it may prove a little beneficial for pulling out of the dives, giving up a little less induced drag for the huge lift that's created by the high G pullout.
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 04, 2012, 09:53 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Was that static test??
Open pipe or thrust tube?
I'd expect that with the cut down blades and associated high pitch, static thrust would be low but efflux would be through the roof.
Any data points on watts/rpm you can share?
Old Dec 04, 2012, 11:13 PM
Joined Jan 2009
if only it were that easy, eh!? LOL.
Old Dec 04, 2012, 11:59 PM
johnny_0 is offline
Canada
Joined Dec 2005
Sorry I wish I had the numbers for you but Im very basic with my testing.
I mounted the fan in my 70mm HK viperjet, using the Eflite delta 32 motor. Did the static test and it wasnt lifting its own weight , maybe 0.7:1 weight ratio that was enough for me. If I dont have at least 1:1 thrust in any of my EDF jets. Im not flying it
I dont think Im emotionally equipped to shave down a 90mm wemo a 90mm or shubie fan to fit a 70mm housing
Old Dec 05, 2012, 03:22 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
FOOLPROOF!!
Nice airfoil?
At only 4oz auw it doesn't need much airfoil, just a little shaping here and there. I agree on the Spear. It looks to me like the Spear is fast in spite of it's airfoil, not because of it.
Old Dec 05, 2012, 03:33 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Oh, I forgot to mention....the 70mm version will have 20 x the Watts, No, seriously, get your ready boys.
Old Dec 05, 2012, 10:29 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Why do I get the feeling I'm not the only one who's walked around the grocery store with a caliper in my back pocket, closely eyeing all the drink bottles and cleaning products?
My Habu32 is flying on a Fosters beer can sized shroud I'm probably lazy, but it seemed like a better idea than spending all day making a round plug, plus these have a treat inside
The Spear root airfoil is probably ok, but it needs a bit more twist or a change in airfoils at the tip because mine needs the elevons up all the time and that's draggy. These high lift airfoils look wrong for a speed plane, but if it ends up weighing a bunch like mine does, then the airfoil is always flying at a small positive angle of attack and this airfoil could be low drag in that range.
I can probably come up with a 70mm fan, but I'll have to make a new plane for it. If I can't find something around here, I might take you up on that filter housing though!
Your little plane looks cool Lee. Will the big one have the motor in front of the fan like you were planning before?
Steve C is offline Find More Posts by Steve C
Old Dec 05, 2012, 11:19 AM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
The Spear handles well at 190mph,I think the airfoil that it has is will do just fine....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Dec 05, 2012, 11:22 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Steve, do you bond the aluminum can to the composite weave, making it a permanent part of the shroud? Or is it removed once the epoxy has cured?
I have visions of laying up the full Fosters can, and then enjoying the carbon-fiber wrapped brew before cutting it to size
Old Dec 05, 2012, 11:30 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Handling well, absolutely. The thick, lifting airfoil and significant washout will have a positive impact on its low speed handling. But all that lift gets in the way at high speeds, creating drag that will have to be overcome with more power.
More power. Aww, shucks!
It's not a deal breaker by any means. I know there are compromises with any production airframe.
Just making my list if I ever decide to get really crazy on an airframe...
Old Dec 05, 2012, 11:33 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Maybe, may try it both ways.
Old Dec 05, 2012, 12:23 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
The only time I've seen a flying wing win in a speed event is when the challenge was limited to flying wings.
pdawg is offline Find More Posts by pdawg
Discussion $99 200MPH radar gun. Koo Hot Online Deals 3 Sep 21, 2012 10:19 PM
Build Log Quest for 200mph EDF carbon dart kingkyle Scratchbuilt EDFs 23 Jul 07, 2012 06:30 AM
Cool HD Video: 200mph DS Acro with Wizard at Weldon Daemon Slope 71 Feb 22, 2011 12:13 PM
Discussion My first 200mph FPV plane with video! gundamnitpete FPV Aircraft 29 Oct 14, 2009 08:44 PM
Discussion 200MPH with 200W possible? 1atlas Pusher Prop Jet Models 15 Aug 16, 2007 12:21 PM
