Old Jan 04, 2013, 06:15 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by pondside View Post
It's Worcester, not Worchester.... LOL
Question, where can you get the leads to charge multi batts, these USB chargers take too long.
BD
It's funny, when I was in London on a high school trip I mispronounced Leicester as 'Lie Chester' and some Brit gave me a berating........'You Americans.....blah blah blah'
What is this charging problem you speak of?
Originally Posted by SlyKYFox View Post
I was just thinking the same thing. The plugs in the usb charger are the female end, just like the plug on the quad. You could just un solder them from the charge board and make your own cable. something like the Hyperion parallel charge boards would be nice. I have one of those for my MsrX bats, and I can charge 6 at once in about 45 min. Hey MO, do you have any extra usb chargers for the v202 lying around?
We have another order that we're going to put through right before the Chinese New Year, where we're going to order some V202 chargers, but nothing extra right now Best we can do are the Mini Pet chargers.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Jan 04, 2013, 06:36 PM
SlyKYFox is offline
Find More Posts by SlyKYFox
SlyKYFox's Avatar
United States, KY, Owensboro
Joined Dec 2011
Do the mini pet chargers have the same plug as the V202?
SlyKYFox is offline Find More Posts by SlyKYFox
Old Jan 04, 2013, 07:24 PM
Joined Feb 2011
Just about all the micro quads on 1S use the same Walkera\Micro Losi connector. Some quads like the Helimax 1SQ uses the same connector with the polarity reversed. The Mini Pet chargers charge to about 4.35V vs the WL Toys, which charges to ~4.15V
With the Mini Pet chargers, I haven't experienced any puffing or overheating. but if you're worried about overcharging, time how long it takes for the charging light to go out and subtract 15 minutes. It's usually 45 minutes
Site Sponsor
Old Jan 04, 2013, 10:23 PM
SlyKYFox is offline
SlyKYFox's Avatar
Joined Dec 2011
Thanks MO. I'll try to find those connectors.
Edit:
I just placed and order for this http://www.rc-connectors.com/index.p...roducts_id=410 Should dot the trick for using my accucell 6.
Old Jan 05, 2013, 12:23 AM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Now that is just awesome!
jlcamp7 is offline Find More Posts by jlcamp7
Old Jan 05, 2013, 11:36 AM
pondside is offline
Find More Posts by pondside
pondside
pondside's Avatar
Sutton, Ma.
Joined Aug 2010
I've been using both chargers, the 1SQ charges to 4.17V, the MP to 4.35V but takes an additional 20 min. No puffing, what is, and where did you get the charger, (10 at a time)?
BD
pondside is offline Find More Posts by pondside
Old Jan 05, 2013, 03:33 PM
Joined Feb 2011
Hey BD, I got the charger from Newegg.com. It's a Rosewill, which is Newegg's rebrand, and I got it for like $30-40, but the other ones similar are now over $100:
http://www.newegg.com/Product/Produc...9SIA1JM0FS5171
How about this one?
http://www.newegg.com/Product/Produc...82E16817474012
Site Sponsor
Old Jan 05, 2013, 03:41 PM
pondside is offline
pondside
pondside's Avatar
Sutton, Ma.
Joined Aug 2010
A buddy put in an order last night and ordered my 5 Losi connectors, I'll wire them to my Sky Charger and that should work.
BD
How about this one?
Old Jan 05, 2013, 04:21 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
How about this one?
LOL!!! Uber USB chargers!
I use my Thunderpower AC6 with parallel charge rigs. I got a multi-JST pigtail plug for my AC6 and then I built a bunch of JST to Walkera (Loci) plugs with parts that I got from my LHS and RCConnectors.com
Now I just charge all my 300mAh batteries at the same time. I still need to put them into storage charge one at a time but that'll change when my serial 3-port JST plug gets here and I can use the balance port.
RoboHeli is offline Find More Posts by RoboHeli
Old Jan 05, 2013, 04:53 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Massive, could the USB hub supply 3.0A of total current? That's a lot of ports on one hub! How's the charge time on these when you hook 10 up like that?
Heli Pad is offline Find More Posts by Heli Pad
Old Jan 05, 2013, 05:14 PM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
double charger turned into single and back to double
WLtoy charger issue continued until the right side was totally nonfunctional. This of course caused me to perform exploratory surgery with a complete case-ectomy. I found each of the male connectors were loose and pushed back from the board. One of the male prongs on the right side had slid back in the connector. I re-anastomosed the connectors and the board with a judicious application of hot glue. My problem is solved... at least for now.
gentle ben is offline Find More Posts by gentle ben
Old Jan 05, 2013, 05:39 PM
Joined Feb 2011
HP, that pictured I showed, I actually let all those batteries charge up for today's outing with Bill. All the batteries were charged within the hour and the lights pretty much went out within 5minutes of each other.
The AC adapter and back of the USB hub both show 4.A rating.
Site Sponsor
Old Jan 05, 2013, 05:41 PM
Joined Feb 2011
Sorry Ben, the routine now for RX battery connectors and WL Toys charger is to tweak the male pins towards the open side of the connector, which not only seems to ease battery insertion, but seems to make better contact.
Site Sponsor
Old Jan 05, 2013, 08:58 PM
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
My right charger connector was alway slightly loose in the case. I did that tweak as soon as you posted it. It worked for a few days and then it was off and on. Then completely nonfunctional. I repeated but no help and perhaps I caused the loosening...most likely. I changed the angle and position of the connectors slightly before the hot glue. They are solid and working like a charm.
Old Jan 05, 2013, 10:11 PM
SlyKYFox is offline
SlyKYFox's Avatar
Joined Dec 2011
I had the same problem, except it was the left side. I ended up cutting the heat shrink off the bat. so the plug would snap into the charger. works great now.
Discussion Getting married ? Obama wants your money realtimerecon Life, The Universe, and Politics 29 Jun 24, 2012 03:04 PM
Discussion Higher HEalth Care Taxes If You Are Married Real Ira Life, The Universe, and Politics 18 Jan 10, 2010 10:04 AM
Those of you who are married NewbieX Life, The Universe, and Politics 27 Jul 15, 2003 08:47 PM
Gonna get married: advise/warning wanted!! RookieOne Life, The Universe, and Politics 32 Apr 25, 2002 11:24 AM
Getting Married.....see you all in a few weeks !!! Alan W Life, The Universe, and Politics 25 Jun 11, 2001 04:13 PM
