Old Feb 09, 2013, 07:21 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
When I did mine, I used the inner ailerons as flaps, and built barn door ailerons.
I used a Super Cub cowl made for the Sig 1/6 scale kit, by Fiberglass Specialties.
TomCrump is offline Find More Posts by TomCrump
Old Feb 09, 2013, 10:23 PM
mustangherb is offline
Find More Posts by mustangherb
United States, VA, Portsmouth
Joined Apr 2012
Originally Posted by blunight View Post
Does anyone here have experience converting this J3 to a Super Cub?
I'm trying to decide how long the flaps should be...so far all I've been able to come up with is using the Eflite 25e Cub as an example. It's flaps are 60% of the total available control surface area. (ailerons 15 5/8'", flaps 10 3/8")
On my CG Cub the total available control surface area is 28 1/2"...so using 60% gives me -
Ailerons: 17"
Flaps: 11 1/2"
Anyone with any suggestions? Comments?
For my build on this Build Log I made my flaps 9" long and the Ailerons about 19-1/4" long, but I have not yet made my maiden flight. As soon as I make my first few flights I will post a response of my findings. Also, I found that I was not happy with the CG cowl and I might check into the 1/6 scale super cub cowl.
mustangherb is offline Find More Posts by mustangherb
Old Feb 10, 2013, 08:48 AM
uspsjuan is offline
Find More Posts by uspsjuan
mailman
United States, TX, La Marque
Joined Aug 2012
I didn't like the cowl either. when funds become available i plan on buying the Fiberglass Specialities cowl with the molded in cylinder
uspsjuan is offline Find More Posts by uspsjuan
Old Feb 10, 2013, 09:29 AM
blunight is offline
Find More Posts by blunight
Chess club geek with wings
blunight's Avatar
United States, FL, Cape Coral
Joined Aug 2008
That would be fantastic! I have not cut mine yet so I can still make changes. I'm looking for STOL type take offs and landings....
I ordered a Super Cub cowl from FS last week - I can post a photo of it when it arrives if anyone is interested.
blunight is offline Find More Posts by blunight
Old Feb 10, 2013, 06:04 PM
Joined Apr 2012
A good picture of the Super cub cowl would be greatly appreciated!
Old Feb 11, 2013, 12:37 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
http://www.google.com/search?q=piper...w=1360&bih=611
How many do you want???
D
Dereck is offline Find More Posts by Dereck
Old Feb 12, 2013, 06:04 PM
Joined Apr 2012
Sorry, I haven't been on here in the past couple of days, but thanks for the link.
Old Feb 12, 2013, 08:14 PM
blunight is offline
blunight's Avatar
Joined Aug 2008
Just received the cowl in the mail...here are some photos. It looks very nice but I'll have to figure a way to blend the sides into the fuse on the sides - the top and bottom fit well. It was $25.00 plus $16.00 shipping.
Trent
Old Feb 12, 2013, 09:22 PM
sirzeppu is offline
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, TX, Kilgore
Joined Aug 2011
No need to blend, that looks about right. Check some pics of super cubs...there is a bit of a space between the fuse and the cowl on the real thing.
sirzeppu is offline Find More Posts by sirzeppu
Old Feb 12, 2013, 09:25 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
So, how are you going to join those two different shapes?
Ah. A vent bulge which must accommodate the larger engine.
loNslo is offline Find More Posts by loNslo
Old Feb 13, 2013, 07:41 AM
blunight is offline
blunight's Avatar
Joined Aug 2008
Nice photo - thanks. After viewing it I guess I'll make a small filler block to support the cowl where it's the widest and leave the rest open for cooling.
Anyone have an idea for creating the round gizmo on the front bottom of the cowl?
I'm going to mimic the four fasteners on the bottom side with small drops of carpenters glue.
Old Feb 14, 2013, 04:47 AM
Joined Apr 2012
Round protrusion on cowl
Go to a craft store like Micheals and they should sell small diameter wooden balls. Just buy the appropriate size and then cut and sand to size, then simple glue into place.
Old Feb 24, 2013, 08:15 PM
Joined Apr 2012
Maiden Flight
Well I made my first maiden flight today on the completed Cub. The first few seconds of the flight were quite stressful, wow! The plane required trimming on all three control surfaces. The initial take off revealed a plane that was rolling left, diving and turning left, plus it was the first use of my new Futaba 14SG radio. But after I calmed down and trimmed out the plane, the rest of the flight was quite good. I flew for 6 minutes on 5S 4400 Sky Lipo battery and upon landing the lowest cell was at 3.93 volts. I was only able to get in one flight, but I learned a lot about the plane. The low rates I adjusted per the Goldberg recommendations and made an educated guess at the high rates. The high rates will need to be increased and I also need to mix in some down elevator with the flaps. Once I get the plane fine tuned I will post my finial settings here. By the way, this plane really is quite the floater and the E-Flite Super Cub 25e landing gear that I installed worked flawless (highly recommend).
Old Feb 24, 2013, 09:23 PM
The Violets is offline
Find More Posts by The Violets
Student-Can't Fly Yet
The Violets's Avatar
Canada, QC, Montreal
Joined Apr 2012
Good to hear evrything went well!
Cheers
Michael
The Violets is offline Find More Posts by The Violets
Old Feb 24, 2013, 09:36 PM
sirzeppu is offline
sirzeppu's Avatar
Joined Aug 2011
Big congrats on a successful maiden flight!
Wanted Carl Goldberg Anniversary Cub Cowl dmarusa Aircraft - General - Miscellaneous (FS/W) 2 Sep 14, 2012 03:42 PM
Sold Carl Goldberg Anniversary Edition Piper J-3 Cub sleepwalker Aircraft - Fuel - Airplanes (FS/W) 3 Aug 13, 2012 07:30 PM
Sold Carl Goldberg Models Anniversary Edition PIPER CUB R/C Sport Scale, Kit No. 63 flyingmanx Aircraft - Fuel - Airplanes (FS/W) 4 Jan 01, 2006 08:05 PM
For Sale Carl Goldberg Anniversary Edition Cub RMD72377 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 09, 2005 07:25 AM
F/S: Carl Goldberg Anniversary Piper Cub Jay C Aircraft - Fuel - Airplanes (FS/W) 8 Jul 17, 2003 10:26 AM
