United States, VA, Portsmouth
Joined Apr 2012
Hobby Lobby has told me that the eRC BL46 motors should be in by next Friday. I certainly hope so, as I really want to get this project completed and in the air! I just want to say that I really appreciate everyone's comments and contributions to this build. Thank you.
Joined Apr 2012
Fuselage front work
The motor finally arrived on Friday, so I got straight to work taking measurements to calculate the motor box size I would need to build. I choose to build a standard type motor box like most modern ARF are using with 6-32 blind nuts installed in the front for securing the X-mount and matching mounting holes in the back of the motor box to fasten to the firewall. After completing the motor box I needed to open a opening in the bottom portion of the firewall for the ESC wires and air to pass through.
Attached firewall/motor box into fuselage and glued, trimmed and shaped top front of fuselage. Checked fit of windshield and laid out line for area behind front windshield, as this area will be black. Also glued in battery tray into fuselage. That is it for today, but I will be working on it ever night this week. |
United States, TX, La Marque
Joined Aug 2012
I used Lazer rods with supports at every bulkhead. made the mistake of using the precut exit for the eleavator. had to put a Z-bend in linkage after exiting fuse to mate with control horn. worked, but flexed under load at Z-bend. Rerouted control linkage last night. nice and straight with no flexing. Now to repair holes I had to cut in covering
Joined Aug 2012
In the first picture, you will see my pen pointing to the original location for the pushrod to exit. But you can see that it is not in the best position. In the second picture you can see where I moved it to. Nice straight shot to the control horn. Only issue was having to drill through the former where the pen is pointing
Joined Apr 2012
Trying to figure out this wing incidence thing. First off there was nothing straight or level about the wing saddle. I first leveled the plane's datum line, mounted the wing and then attached the Robart incidence meter. The meter measure a positive 2.5 degrees and the wing was not setting flat on the uneven wing saddle (wing is flat an true), so I sanded just enough of the wing saddle to somewhat even things out. I then remounted and measured and now it measure about a positive 1.75 degrees. Now according to the build instructions from Carl Goldberg the wing incidence is suppose to be 0 degrees and the tail is positive 2 degrees. I am in need of some experienced advice for this part of the build.
| Thread Tools | |
| Wanted Carl Goldberg Anniversary Cub Cowl | dmarusa | Aircraft - General - Miscellaneous (FS/W) | 2 | Sep 14, 2012 03:42 PM |
| Sold Carl Goldberg Anniversary Edition Piper J-3 Cub | sleepwalker | Aircraft - Fuel - Airplanes (FS/W) | 3 | Aug 13, 2012 07:30 PM |
| Sold Carl Goldberg Models Anniversary Edition PIPER CUB R/C Sport Scale, Kit No. 63 | flyingmanx | Aircraft - Fuel - Airplanes (FS/W) | 4 | Jan 01, 2006 08:05 PM |
| For Sale Carl Goldberg Anniversary Edition Cub | RMD72377 | Aircraft - Fuel - Airplanes (FS/W) | 4 | Aug 09, 2005 07:25 AM |
| F/S: Carl Goldberg Anniversary Piper Cub | Jay C | Aircraft - Fuel - Airplanes (FS/W) | 8 | Jul 17, 2003 10:26 AM |
