Old Nov 02, 2012, 12:02 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Landing gear - it's not that far in size from where the E Flite Cub sprung gear may fit. It's around $30 and after watching both my Sig Cubs bouncing around on almost solid wire gear, the next Cub around that size will get the E Flite gear.
http://www.rcgroups.com/forums/showt...1#post19565390 is in the middle of long thread about the E Flite BARF Cub, touches on using its sprung gear on other models.
Hope that helps
D
Dereck is offline Find More Posts by Dereck
Old Nov 02, 2012, 01:44 PM
srt8madness is offline
Find More Posts by srt8madness
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
Originally Posted by mustangherb View Post
First off I ordered the electric motor box sold by Maxford USA that they use for their L-4 electric conversion. This should work fine for the motor that is in the .40-.60 size electric. Secondly I plan on cutting a rectangular opening at the bottom portion of the firewall (to allow for a portion of the battery to protrude). For battery access I plan to build a hatch into the fuselage front bottom panel. The battery will occupy the space just below where the fuel tank was intended to be. I will enclose pictures when I get to this point. I am leaning toward using a 5S-4000 to 5000 mah battery, as this size should fit the space and hatch size.
Just a side note, I had a world models 1/6th cub. I did the same in the firewall. It flew scale on 3s 500watts, and more comfortable on 4s 750 watts. You should be able to run a nice scale prop on 5s.
srt8madness is offline Find More Posts by srt8madness
Old Nov 03, 2012, 10:08 AM
The Violets is offline
Find More Posts by The Violets
Student-Can't Fly Yet
The Violets's Avatar
Canada, QC, Montreal
Joined Apr 2012
Good luck with the build; itís a nice looking plane, that Iíve had my eye on for a couple of months. Glad to follow along.
Michael
The Violets is offline Find More Posts by The Violets
Old Nov 03, 2012, 08:11 PM
mustangherb is online now
Find More Posts by mustangherb
United States, VA, Portsmouth
Joined Apr 2012
Day four or five
Well the new motor box arrived today from Maxford USA, but I soon discovered that I would have to modify it to accommodate the proper size motor. This box is for a smaller motor, but is not a bad design.
I decided to proceed with the fuselage build, but I held off on gluing any formers forward of former 'D'. Everything was glued with CA and all the inside was reinforce with Super Phatic glue from Deluxe Materials. I really need to settle on the motor I will run and place my order. I will hold off on the forward part of the fuse until then. I want going to get the eRC BL46 from Hobby Lobby, but they are out of stock. I think this motor will work perfect with a 4S-4000-5000mAh battery and maybe a 14 x 9 prop, but feel free to chime in with an opinion. Well that is enough for tonight.
Description: The motor box from Maxford USA arrived today, but it will have to be modified. Name: IMG_1646.jpg
Description: Fuselage assembled to check fit and straightness. Tape & rubber bands used to hold into position. Name: IMG_1647.jpg
Description: Fuselage glued up from former G to former D. Name: IMG_1648.jpg
Description: Top formers DT thru GT glued into place along with 3/16" diameter dowels.
mustangherb is online now Find More Posts by mustangherb
Old Nov 05, 2012, 05:28 PM
Joined Apr 2012
Wing rib hole jig
I worked yesterday making a jig that will be used to drill 14mm holes into the wing ribs both in front and aft of the main spars. I will also drill a smaller hole toward the back of the rib. See the picture with the pattern rib for my preliminary location for holes. The jig will hold 4 ribs at a time and the ribs will face downward against a scrap piece of wood when drilling. You will also note the BT-5 Body Tubes that will routed thru the middle hole for routing the wing mounted servo leads. I am still working out the final details for the battery box, motor box, motor before I attempt to do more work on the fuselage.
Description: Cardboard tubes that will be used inside the wings for routing servo wires. Name: IMG_1650.jpg
Description: Jig that I made yesterday to hold 4 ribs at a time to cut holes into the ribs. Name: IMG_1651.jpg
Description: Picture showing 4 #5 ribs in the jig Name: IMG_1652.jpg
Description: Another view of the jig with ribs. The jig will be placed with the ribs facing down to drill holes.
Old Nov 05, 2012, 07:08 PM
uspsjuan is offline
Find More Posts by uspsjuan
mailman
United States, TX, La Marque
Joined Aug 2012
nice work dude! i'm at a standstill till i get funds for raido gear and monocoat. airframe is done.
uspsjuan is offline Find More Posts by uspsjuan
Old Nov 05, 2012, 08:50 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
The cardboard tubes look like a good idea. I was thinking of making some out of kraft paper, to keep the weight down on my Great Planes Cub build:
http://www.rcgroups.com/forums/showthread.php?t=1742597
Can you tell me the weight of these?
loNslo is offline Find More Posts by loNslo
Old Nov 06, 2012, 06:54 AM
Joined Apr 2012
I will let you know when I get home today. Oh, I like your choice of motor as I am a big Hacker fan. Estes just sent me an email about the tubes, they weigh .21oz for each 18" tube or 5.9g. So these tubes are extremely lite.
Old Nov 06, 2012, 07:30 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Just curious what the jig is for. When I drill holes in ribs and such, I stack them and drill on a drill press.
Also for servo lead tubes, I take a piece of paper, and cut it so the width is a little longer than about 3x the perimeter of the hole. (don't need to be exact on this). Then I wrap it around a small dowel, or pencil. Place it in the holes, and pull the dowel/pencil out. The paper unwinds and you have a perfect wiring tube that costs nothing, and weights next to nothing.
Just be sure to put the tubes in BEFORE you joint the wing.
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 06, 2012, 07:57 AM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
Huh! That is EXACTLY what I thought to do. Although I was thinking that I'd have to tape the seam with Magic Mending tape before removing the dowel. My other concern is, because I intend to run floats, at times, that the kraft paper might not stand up to moisture.
Old Nov 06, 2012, 08:30 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
No need for the tape. The holes keep the shape. When it unravels it will be nice and tight against the holes, and won't move around. I hit it with a dot of glue if it doesn't seem as tight as I would like. Some are tighter than others for some odd reason.
As far as moisture and floats. It should be fine... If you get a lot of water in the wing, you may have more serious problems
Old Nov 06, 2012, 08:45 AM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
...As far as moisture and floats. It should be fine...
Maybe wax paper?
Old Nov 06, 2012, 08:59 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Maybe wax paper?
May not be ridged enough.... but worth a try.
Old Nov 06, 2012, 12:21 PM
Joined Apr 2012
It is always great to listen to all the good ideas and you guys have presented a number of them. Thank you all for taking the time to contribute to this build log.
Old Nov 06, 2012, 04:58 PM
Joined Apr 2012
More on holes in ribs
I received my 14mm forstner bit today and completed drilling the two forward guide holes along with the 3/8" guide hole at the back. I then drilled the holes in rib numbers 3 thru 6. Ribs number 2,plus the innermost ribs will also have to be drilled to allow the servo leads to be routed into the cabin area o fthe plane. Still working on which motor to purchase.
Description: Wing jig with guide holes for proper location of holes in wing ribs. Name: IMG_1655.jpg
Description: Another picture of jig with guide holes.
Wanted Carl Goldberg Anniversary Cub Cowl dmarusa Aircraft - General - Miscellaneous (FS/W) 2 Sep 14, 2012 03:42 PM
Sold Carl Goldberg Anniversary Edition Piper J-3 Cub sleepwalker Aircraft - Fuel - Airplanes (FS/W) 3 Aug 13, 2012 07:30 PM
Sold Carl Goldberg Models Anniversary Edition PIPER CUB R/C Sport Scale, Kit No. 63 flyingmanx Aircraft - Fuel - Airplanes (FS/W) 4 Jan 01, 2006 08:05 PM
For Sale Carl Goldberg Anniversary Edition Cub RMD72377 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 09, 2005 07:25 AM
F/S: Carl Goldberg Anniversary Piper Cub Jay C Aircraft - Fuel - Airplanes (FS/W) 8 Jul 17, 2003 10:26 AM
