Old Oct 29, 2012, 08:18 PM
mustangherb is offline
Find More Posts by mustangherb
United States, VA, Portsmouth
Joined Apr 2012
Build Log
Carl Goldberg Anniversary Cub
I officially started my first kit build yesterday. I intend on building this as an electric powered plane. I first had to make a trip to Lowes to purchase a 24" hollow core door and a half sheet 3/4" plywood to make a build table. .
Description: My completed build table with 1/2" blue board on top. Name: IMG_1634.jpg
Description: A few of the items that I purchased for this build. Name: IMG_1635.jpg
Description: The unstarted kit
I finally settle down to begin the actual build at 1:30 in the afternoon. I started by assemblying the sanding tools.
Description: The glued up sanding tools
Next I laid out the fuse/tail drawing on the table, followed by covering the plans with wax paper. Finally the actual build begins! I removed, cut, and sanded all parts for the tail feathers. This actually takes longer than you think, plus I am moving carefully due to my inexperience. All parts were pinned down to the drawing (great matchup) and then all joints were glue with thin CA and allowed to dry for 30 minutes as I took a break. Next everything was unpinned and the joints on the opposite side were glue with thin CA also. Now came the first part that took some care, sanding the the 1/4" concave portion into the two halfs of the elevator. I started out by cutting a shallow V-notch followed up by sanding as prescribed in the instructions. After I was satisfied with the fit the elevator halfs were pinned back to the drawing and the 1/4 x 4-1/2" dowel was glued to the elevator halfs with epoxy and cross pinned into place
Description: The stab/elevator halfs pinned and glued. Name: IMG_1641.jpg
Description: The fin/rudder pinned and glued.
mustangherb is offline Find More Posts by mustangherb
Old Oct 30, 2012, 03:58 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Always like a good Cub. I will follow along for this one.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Oct 30, 2012, 05:29 AM
Joined Apr 2012
Day Two
I spent yesterday removing and sanding all the parts for the fuselage. This took alot longer than I thought, as most of the parts displayed alot of rough edges. I guess the dies were not that sharp when this kit was cut. I probably spent the better part of 3 hours performing this task. Called it a day, so I will start the fuselage assembly tonight after work. I will include some pictures then.
Old Oct 30, 2012, 08:18 AM
Mrj3cub is offline
Find More Posts by Mrj3cub
Mrj3cub's Avatar
Joined Nov 2011
Subscribed !
Mrj3cub is offline Find More Posts by Mrj3cub
Old Oct 30, 2012, 08:47 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
After two larger Cubs - Sig's 1/5th and 1/16th scale kits - a real good idea is to figure out battery access well before you're looking at a built fuselage thinking 'howineck do I get the battery in?' The Sig kits both had working pilot access doors on the right hand side, which when opened, allowed my to access the battery packs. In both sizes, the packs were as far forward in the bottom of the fuselage as they'd go.
Taking the wing off a high winger to fish around for a battery pack in the depths is not a lot of fun on a nice Sunday!
The larger Cub is so far back, it had NiMh packs, so I'd usually just recharge the pack in the model - not bright with a LiPo but quite feasible and safe with A123 packs.
Suggest a look around - this kit has been electrocuted in the past. Could save you some screaming fits late on a Saturday night
Good luck
Dereck
Dereck is offline Find More Posts by Dereck
Old Oct 30, 2012, 10:36 AM
campbelltf is online now
Find More Posts by campbelltf
campbelltf's Avatar
United States, NH, Bedford
Joined Jan 2012
Subscribed. Sounds like this will be lots to learn from your approach. If you can squeeze it in, I'd really appreciate hearing how you determined which sanding tools to build and how they're used as you go along.
campbelltf is online now Find More Posts by campbelltf
Old Oct 30, 2012, 10:51 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I have one of these NIB that I won at a club contest a few years back. Boy that box sure seems heavy. ;-) Will be watching with interest as I do plan on electrifying it when I get around to building it.
rcav8r2 is offline Find More Posts by rcav8r2
Old Oct 30, 2012, 11:57 AM
Joined Apr 2012
First off I ordered the electric motor box sold by Maxford USA that they use for their L-4 electric conversion. This should work fine for the motor that is in the .40-.60 size electric. Secondly I plan on cutting a rectangular opening at the bottom portion of the firewall (to allow for a portion of the battery to protrude). For battery access I plan to build a hatch into the fuselage front bottom panel. The battery will occupy the space just below where the fuel tank was intended to be. I will enclose pictures when I get to this point. I am leaning toward using a 5S-4000 to 5000 mah battery, as this size should fit the space and hatch size.
Old Oct 30, 2012, 03:36 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Originally Posted by mustangherb View Post
I guess the dies were not that sharp when this kit was cut. .
Ah yes, The joy of die smashed, er, ah, I mean die cut parts parts.
You're not the first nor will you be the last to experience this facet of the hobby. Hopefully as the dies get dull the kit MFG's will convert to laser cut parts.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: I looked and I looked and I...
Old Oct 30, 2012, 04:18 PM
Joined Apr 2012
Day Three
Started on fuselage assembly by trial fitting the "cabin sides" and "cabin doubler" to fuse sides. I took measurements on both fuse sides from wing surface to the bottom in the same point to ensure both sides would be the same. There was some sanding involved to achieve the same dimensions in the previous step. The cabin sides were then glue in place using thin CA and then the cabin & LG doublers were glue in place with Titebond II glue. The glue up was held/pressed in place utilizing to granite blocks. This took about 25-30 minutes per side.
I thought that I should add the build from the UK that gave me alot of my inspiration on this build.
http://www.modelflying.co.uk/forums/...p?th=55984&p=1
Sorry, I had to fix the link!
Old Oct 31, 2012, 03:17 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
GB Cubs are great flying airplanes! You're gonna love it! Think ahead about adding a rear strut to the LG. It's a 'weak' point. As designed the gear will gradually splay outward and the wheel axles will torque so that the right wheel turns to the right and the left to the left. You can shorten the ailerons to a scale length without any adverse effects, too.
ARUP is offline Find More Posts by ARUP
Old Oct 31, 2012, 06:02 PM
uspsjuan is offline
Find More Posts by uspsjuan
mailman
United States, TX, La Marque
Joined Aug 2012
I am about 3/4 of the way through the airframe build of my Cub. I have the same annivesary cub. I bought mine back in 1992 as per the AMA application in the box. I have been going through the same sanding nightmare as you. Guess the dies were dull back then to. lol. Altered mine to use a servo in each wing panel. Laid each servo on its side under a hatch to hide it. powering mine with a saito .65 4stroke. still trying to decide on a color scheem.will get my daughter to post a pic if you dont mind.
uspsjuan is offline Find More Posts by uspsjuan
Old Oct 31, 2012, 08:42 PM
Joined Apr 2012
Landing gear and flight controls
I had already decided to do something with the LG, but I have not decided yet which route I am going to take yet. I would like to take the stock LG and improve it and make it look more scale.
As far as the flight controls on the wings, I plan on putting the aileron servos in the wing panels, but I also intend to use the center mounted servo setup to operate the flaps that I also intend to install. I was looking at making the ailerons about 18-1/2" long and the flaps extend from the aileron edge to the inboard aileron stopping point prescribed for the clipped wing.
Old Nov 01, 2012, 04:54 PM
sweatybetty is offline
Find More Posts by sweatybetty
sweatybetty's Avatar
United States, OR, Roseburg
Joined Jan 2012
my first kit was the same cub. be sure to check the balsa that the hinges go into. my second flight ended early when the left half of the elevator pulled out of the too-soft balsa and broke off. also, if i had to do over, the aileron servos would go in the wing which it sounds like you are doing.
my kit came with what looks like some mahogany plywood for the fuse that was de-laminating and would not take glue. just some things to check.
good luck!
sweatybetty is offline Find More Posts by sweatybetty
Old Nov 01, 2012, 07:32 PM
Joined Apr 2012
Thanks for the heads up there sweatybetty! I am waiting on the motor box from Maxford USA before I continue, although I did make a battery mockup block, created the battery hatch and the panel. I will take a picture and post later of the drawing I made of the cut details for the front fuse bottom panel.
Description: The block on the left is a mockup of the GensAce 5s-5300 battery. The panel in the middle is the front fuse bottom panel and the battery hatch is to the left.
Wanted Carl Goldberg Anniversary Cub Cowl dmarusa Aircraft - General - Miscellaneous (FS/W) 2 Sep 14, 2012 03:42 PM
Sold Carl Goldberg Anniversary Edition Piper J-3 Cub sleepwalker Aircraft - Fuel - Airplanes (FS/W) 3 Aug 13, 2012 07:30 PM
Sold Carl Goldberg Models Anniversary Edition PIPER CUB R/C Sport Scale, Kit No. 63 flyingmanx Aircraft - Fuel - Airplanes (FS/W) 4 Jan 01, 2006 08:05 PM
For Sale Carl Goldberg Anniversary Edition Cub RMD72377 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 09, 2005 07:25 AM
F/S: Carl Goldberg Anniversary Piper Cub Jay C Aircraft - Fuel - Airplanes (FS/W) 8 Jul 17, 2003 10:26 AM
