Old Oct 29, 2012, 08:10 PM
TheSelf is offline
Find More Posts by TheSelf
Los Angeles, CA
Joined Jan 2011
Question
Charge cell phone batteries with balance charger?
Hi all
I have a turnigy accucell-6 balance charger:
http://www.hobbyking.com/hobbyking/s...idProduct=7028
I'm trying to figure if it's possible to charge my cellphone Li-ion batteries externally with this charger...Can anyone tell me if this is possible?
If so- how would anyone suggest physically connecting the battery charger to my big new Samsung galaxy note 2 3100 mAh spare Lithium ion battery? The terminals are tiny ( see picture of the battery here: - in the picture you can see there are 3 terminals- the 'positive' and 'negative' terminals are marked- what's the middle one? It would be great if there is a way to connect/ charge my spare batteries and not have to purchase an external cell phone battery charger that only charges at 0.5A when I could charge at 3.1A with this... Am I right in thinking these batteries are all '1cells'/1S'? - on the back it says"3.8V Li-ion" - I take it that means a 1S ( so no balancing required)- the accucel charger is supposed to charge Li-ion batteries but what setting is 3.8V? - that appears as 0.1V higher than even 'Lipos.'.?
Grateful for any feedback.
Thanks in advance!
TheSelf is offline Find More Posts by TheSelf
Old Oct 29, 2012, 10:29 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Careful. That cell may have a circuit inside rated at less than an amp.
I did this last week for a cuz that left charger at home but at
4 amp to be safe.
To connect I used black electrical tape and put a ball of solder on the end of wires but it can be an intermittent connection and IMO not worth it if you have a charger.
rampman is online now Find More Posts by rampman
Old Oct 29, 2012, 11:46 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
4 amp to be safe.
Thanks for your reply- just to confirm we are on the 'same page'- I'm talking about charging the battery externally- ie. outside of the phone- not charging with the battery inside the cell phone- so the circuit of the cell phone I guess isn't important- what wiring/cable did you use to connect your balance charger to the cell battery directly?
Thank you
Old Oct 30, 2012, 12:02 AM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
If you peel the sticker off, you will find a bare cell with a little pcb where those terminals are. It will likely limit your charge and discharge rate to about 1A, maybe a little more. The note might be higher, whatever the charger it comes with will be close to the cut off. I tried it on a galaxy nexus battery. If you connect directly to the cell, you can go faster. But on the exposed terminals, that little pcb will cut the cell out of the circuit if you try to go too fast.
ttabbal is offline Find More Posts by ttabbal
Old Oct 30, 2012, 12:28 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
IMO, spend four bucks and save yourself a LOT of potential grief...
http://www.ebay.com/itm/Desktop-Dock...item4abd0ad7b3
http://www.ebay.com/itm/New-Stand-Do...item2323f21b9a
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 30, 2012, 06:47 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I have done this a couple of times, and there is no problem. Set the charger to less than an amp. The contact in the middle is just a temperature sensor, no need to connect it.
The only problem might be a suitable interface between the battery and your charge cable.
I suggest getting a piece of wood, hammer in 2 nails so that the backside of the battery has something it can rest at, and put two appropriately shaped pieces of music wire at the front, which press themselves on the contacts. Solder your charge cable to these wires.
I have stopped tinkering though, and got a charger with multiple bays for all my non-RC stuff.
http://www.digibuddy.eu/
Julez is offline Find More Posts by Julez
Old Oct 30, 2012, 01:34 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
Thank you- but I already loked at these options- but these only charge at 0.5A or less- will take 10-12 hours to charge- I wanted to try charging with my balance charger to get at least 1Amp or more charging...
Mark
Old Oct 30, 2012, 02:02 PM
ttabbal is offline
ttabbal's Avatar
Joined Jan 2012
One thing I did when I was experimenting was take apart a cheap charger and use its contacts for the battery connection. Makes connecting easy. Then used alligator clip leads from the charger. As mentioned, don't expect more than 1A or so, unless the phone can charge faster. For example, the Kindle Fire can do 2.5A. So if its battery were removable, you could probably use that as a max charge rate without tripping the protection circuit.
Old Oct 30, 2012, 02:05 PM
So. Cal.
You can always modify them with switch and a second set of leads to go to your hobby charger for those times when you're in a hurry. Much simpler, cleaner, and more reliable than a homebrew adapter.
The second one that I linked will charge at up to the current that is provided by the attached USB cable. I have some USB chargers that will provide > 2 amps. These are not hard to find.
Mark
Old Oct 30, 2012, 03:09 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
Mark
I was confused by the tem 'USB charger' - thinking that mean specifically that it charges at a standard reduced 0.5A rate (my samsung phone has a basic charging status showing when charging of 'USB' (which is reduced or 'AC' which is 2A- my samsung galaxy note 2 charger that plugs into my AC wall outlet and has a detachable USB cable that connects to the phone- charges at 2A- so you are saying these 'USB chargers' don't only charge at a reduced rate- in this instance with the second product you listedI can connect my samsung charger to this device & I could charge a spare battery outside the phone at 2A?- if so- this is a great find - thank you!
Old Oct 30, 2012, 03:16 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
my phone (Samsung Galaxy Note 2 can charge at 2A- with its included AC wall outlet charger, with the phone plugged in- I would think that charging the battery externally with my RC balance charger- if a 3100mAh capacity- I could charge at at least 3.1A (1C)..is this incorrect?
Old Oct 30, 2012, 03:17 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
thanks for the tips!
Old Mar 09, 2013, 02:51 PM
alejoc is offline
Find More Posts by alejoc
Joined Mar 2013
Hi, I would like to know if these chargers can estimate a cell phone Li-ion battery's capacity when connected. I am planning to use the iCharger as a battery tester-analyzer for cell phone and camera batteries.
alejoc is offline Find More Posts by alejoc
Old Mar 09, 2013, 03:01 PM
So. Cal.
Most chargers with discharge capability can assess battery capacity. Simply fully charge the battery and then discharge it at the load that the battery sees in its native device and note discharged capacity on the charger display.
Welcome to RCGroups!!
Mark
Old Mar 09, 2013, 04:18 PM
alejoc is offline
Joined Mar 2013
Thanks for the quick reply and the welcome. The thing is, a cell phone's consumption is quite variable, so I wonder if I need some kind of load bank in order to discharge the batteries?
Discussion Best Charger for around $100 that can charge 4 batteries at once up to atleast 6 cell chrisorbics Batteries and Chargers 38 Nov 29, 2012 10:16 PM
Cool Only USD8.9 GT POWER Model 2-3 Cell Parallel Charging System RC LiPo Battery Charger szewang2805 Product Announcements 0 Oct 15, 2012 11:11 PM
Discussion can I charge a 1s lipo with usb charger (used for phone with lipo) MaRcIu Electric Heli Talk 5 Oct 02, 2012 07:03 PM
Sold E-Flite 2-3 cell balance field charger w/battery clips JESC48 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 27, 2012 09:26 PM
Can Kokams be charged with ANY cell phone charger? Paul Penney Parkflyers 11 Dec 11, 2002 03:04 AM
