Old Nov 11, 2012, 11:16 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Sorry, I meant if you figure it out for bottom of wing.
Originally Posted by miatamama View Post
Pete, Before i reconfiger my second one. I put 6400 and motor on top of the black one. Did you leave motor on the bottom of wing?
Razor, 6400 for 6i mounted on top of wing.
act. elevon
mix 1 mix ele to rudder -100 -100
mix 2 mix ail to rudder +100 +100
aile R
JCS
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 12, 2012, 12:27 AM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
@Miatamama- Yes, motor and batt on bottom, RX on top, with motor socket facing rear.
Pete P is offline Find More Posts by Pete P
Old Nov 12, 2012, 07:15 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
mine is almost rtf
question
Does it need reflex?
Old Nov 12, 2012, 08:48 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by Razors edge 29 View Post
mine is almost rtf
question
Nope!
Just get the CG close if not right on.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Nov 12, 2012, 08:54 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Awesome
QUOTE=dz1sfb;23253044]Nope!
Ken [/QUOTE]
Old Nov 14, 2012, 05:52 PM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
Got mine in the air and I was surprised in how well it flies considering it's a wing. She's very durable in construction too. I took her up and at first she would loop and dive into the ground ,with a little down trim and a tweak on the ailerons she flies rather tame. But like I said she is fidgety and hyper but can maintain a level comfortable flight and still be a handful of fun. Might look into the bigger StingRay. Thanks for the plans and a great little wing to fly around
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Nov 14, 2012, 06:15 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Straight motor angle on this?
Old Nov 14, 2012, 11:06 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
I agree, mine was the same at first too.
Burns up space in our indoor area real fast.
I think I may scale up this design.
Maybe with more wing it'll slow it down lol
Old Nov 14, 2012, 11:41 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Mine flew very easy when upsidedown, Better than when right side up. Right side up was a little touchy. I think it may have to do with the low thrustline. I reconfigured mine with the 6400 on top and one with the brick and motor on top. I will know friday if thrust line has to do with the better upside down flying.
I liked the way the small one flew flat and straight out of my hand that I built a 24 incher right away. It is a 24 incher. I will try it friday also.
This is the answer for 1 cell combat. We have been combatting with 14" pi yaks and having a ball. 10g motor and 180 2 cell. The stingrays may obsolete our pie yaks.
JCS
Razor, how slow do you want them? Ours fly as slow as the champs. These were designed to combat and do it well.
miatamama is offline Find More Posts by miatamama
Old Nov 15, 2012, 12:09 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
lol
Mine was fast even at quarter throttle
I had a 5043 prop on mine though which may have influenced it
Also, It may be a suk xp motor
so it really rips hehehe
I wanna take mine outside and try it
I'll definitely be building a bigger one of these for next summer and make it a screamer with k4 airfoil likely
Also
a person could also use the j3 cub motor/gear box/prop on this bird as well for even lighter weight
JCS
Old Nov 15, 2012, 04:45 PM
icsteve is offline
Find More Posts by icsteve
Imlay City, MI
Joined Dec 2006
Hey guys, Do you think an AP05 brushless would be too much for it? Also, what kind of foam is everybody using, MPF, 6mm depron?
icsteve is offline Find More Posts by icsteve
Old Nov 15, 2012, 06:10 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
IC, plans say 3mm depron but one poster used dollar store rediboard. As far as an ao5, if you fly jets maybe you could control it. It only needs about 1/8 inch movement to turn with elevons. The champ motor is roughly 30 g thrust and the 4site motor makes it very fast so I would say too much motor with the brushless unless you go to the 24" and 2cell. Just my opinion.
JCS
Old Nov 15, 2012, 07:05 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
if you made a bigger version on 2S then yes it'd be a blast
but unlikely indoors
mine is fast and its only the suk xp motor
Old Nov 15, 2012, 07:48 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Okay, just for clarification. The 24" model was designed for indoor combat, and while it can go quite fast, it is also capable of very slow flight as well. It was designed for a 10g 2000 kv outrunner, but has been setup with a Park 250, which can be rather ballistic, still well for indoors and out.
Steve, the AP05 would work well. I would go with the 7000 kv one. These motors turn relatively small props (GWS 0302). This model is designed around 3mm Depron, and presents very little frontal area. Going up on thickness, say to 6mm will double the frontal area and impact flight speed as well make it difficult for the brick to move the control surfaces.
Ken
Old Nov 21, 2012, 11:46 AM
Pete P is offline
Pete P's Avatar
Joined Feb 2005
Going to maiden the final version of the Mini-mini Stingray tonight
The 13.5" version, with a AA 6mm motor, Parkzone GB and 3.5" CF prop making 12g thrust at something like 400mAh, with a 160mAh cell and an AUW of 16.5g.Wonderful design, a bit slow at times. Flutters at half throttle cruise- Unsure of cause. Did not bother to paint and finish, just a preliminary model. Flies for ever on a full charge.
The new 12" version, with a 7mm "Red" motor, trimmed white 2.4" x ~1" prop making 11g thrust at 600mAh with a 125mAh cell, 15g AUW, could be a bit lighter with thinner wing sections. Using a "Mosquito" brick for long throws. Should be very nimble!! Also, beautifully silent. I think I'll do a red/blue color on the tail (left/right), and some stripes on the wings.
Discussion X-models Stingray AvB Slope 27 May 31, 2012 07:22 PM
For Sale Yellow Aircraft Stingray keithtsr Aircraft - Electric - Jets (FS/W) 4 May 15, 2012 11:08 PM
For Sale Yellow Aircraft Stingray keithtsr Aircraft - Electric - Jets (FS/W) 7 May 03, 2012 01:10 PM
For Sale Aeroworks Stingray RTF (LPU) bouncebk2003 Aircraft - Electric - Airplanes (FS/W) 0 Apr 19, 2012 05:29 PM
Sold Trade: Silverlit IR Booster and misc stingray items for micro r/c gear Hal_The_Hacker Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Aug 21, 2008 06:07 PM
