Old Oct 31, 2012, 04:13 PM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Would a KF airfoil bring an improvement? Thanks.
indoor_fr is offline Find More Posts by indoor_fr
Old Oct 31, 2012, 08:49 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
It is hard to say. At this small scale, it flys so well as it is. It might be worth trying, but adding weight will reduce its already stellar performance.
The regular size StingRay benefits well from the KF airfoil, but mass was more of a consideration on the mini and micro versions.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Oct 31, 2012, 09:59 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Ken, What I do for streamers. I use regular crepe paper. Cut about 4" off with scissors then reroll as tight as you can. Then use a bandsaw with fine blade to cut it into 1/4" streamers. we use 6 ft streamers which look like a 25ft on larger planes. Champs can cut the 1/4 ". This may work for you.
JCS
miatamama is offline Find More Posts by miatamama
Old Nov 04, 2012, 03:08 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Firstly, I'd like to thank you for the plans, Ken.
I built my Micro Stingray by scaling down the plans from the original Stingray thread. That was before this thread was started. So my Ray looks a little different then what's on the plans that are here.
OK, here is my entry. I still have to make the control rods and the horns. Hopefully I'll have a vid of it flying soon. I'm just waiting for the Lipo's to arrive.
Foam: Elmer's Foam Board. (5mm)
Wingspan: 18"
Lipo: 200mAh (9g).
Guts: AR6400 and P51 motor.
Current weight is 20.8g without the lipo.
Glue: Fabri-Tac for everything. I'm waiting for the Foam-Tac to arrive.
You may have noticed that I left out the carbon bits. I'm hoping the little ray will fly ok without it. What do you think, Ken?
If not, I'll have to dip into the stock I'm saving for another project and put them in per the plan.
KC
KC is offline Find More Posts by KC
Old Nov 04, 2012, 09:53 AM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Ken, Thanks for the plans. I will maiden next friday at our indoor meet. I couldnt beleive the video. Hope I can pilot mine half that good. I didnt have a champ so had to use an Msr brick turned 180 degrees and mixing with the other 4site brick.
Can you post a link to go directly to your micro stingray kit. If this flys as good in our smaller gym I may be able to send some orders your way.
JCS
Old Nov 04, 2012, 09:57 AM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Ken, Nevermind the link. Today I clicked on the one you gave at the beginning and went straight to the site. Thanks. JCS
Old Nov 04, 2012, 09:08 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
KC,
Yours should be adequately stiff with the paper on, and it does not seem to be too much heavier. The only drawback if any will be the added frontal area of the thicker foam. At 18" wingspan a 5g motor might be quite suitable.
Ken
Old Nov 04, 2012, 09:14 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
This plane was quite a hit at the JR Indoor Festival this weekend, as well as the Mini StingRay.
I even participated in the combat event today (with the regular size one), and probably would have won it had I not lost an elevon servo. There were 7 of us and I had just taken out #3 when I realized on servo was messed up. Tried to keep it in the air, but just did not have enough control. The guy that won was flying a nutball, which I had already taken a bite out of. One of the other two was flying an Ember, and the other a Micro Stryker. They ran out of battery.
Good weekend,
Ken
Old Nov 07, 2012, 03:21 AM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
My after mid night micro StingRay built
Yawn.... well it's yea ......what 0418hrs WOW! I took a whole two hours to build this little thing. Neat and I'm trying different size prop, the standard Champ,GWS 5045, and even a prop from my mosquito. 3 blade 28gr GWS 5045 29gr got it right were as planned good job plans are great thanks. Well better catch a nap and I 'll start on another plane in the late morning. Morning anyone up yet??
Another 4 yrs of let's hope for the best!!!!!
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Nov 07, 2012, 06:53 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Thank you for posting the plans, added to my "to build list"
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Nov 07, 2012, 03:24 PM
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Guys! Im having a memory freeze. I used mixes with a 4site brick and a Msr brick to get the control orientation right. A Friend brought over champ gear and I cant get it right. Can anyone tell me how to program the champ brick to get the stingray to work with a DX6i. Just throwing the mix switch on the 5E makes it work right. Help!!!!!! JCS
Old Nov 07, 2012, 04:02 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
JCS,
I use the preprogrammed elevon mix on my DX7. In fact I copied over from the full size StingRay. Just try the elevon mix with all channels in the normal position if you have not already done so.
Here are my settings;
Servo Reversing: All channels in the normal postion
Subtrims: Adjust to neutral the servos.
Expo on H and L for elevator and ailerons 25%
Rates on H 100% L 50%
Ken
Old Nov 07, 2012, 04:08 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Finally got some paint on it
Got some paint on mine today. Only added .25g
Left the bottom white.
Ken
Old Nov 07, 2012, 04:20 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
looks great!
rcrich is online now Find More Posts by rcrich
Old Nov 07, 2012, 04:59 PM
Crazy Canuck
NEWBEFLYER's Avatar
Joined Apr 2007
I used a Champ brick too. So what I did with my DX6i is : Went to set up and look for Elevon then ACT it , you may need to also go to the Reverse setting and reverse your Aileron and elevator from N to R it depends on it they're opposite to your control throws. That should give you what you want. Hope that works. Here's my StingRay naked along with my Perrytactol. Same settings.
Discussion X-models Stingray AvB Slope 27 May 31, 2012 06:22 PM
For Sale Yellow Aircraft Stingray keithtsr Aircraft - Electric - Jets (FS/W) 4 May 15, 2012 10:08 PM
For Sale Yellow Aircraft Stingray keithtsr Aircraft - Electric - Jets (FS/W) 7 May 03, 2012 12:10 PM
For Sale Aeroworks Stingray RTF (LPU) bouncebk2003 Aircraft - Electric - Airplanes (FS/W) 0 Apr 19, 2012 04:29 PM
Sold Trade: Silverlit IR Booster and misc stingray items for micro r/c gear Hal_The_Hacker Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Aug 21, 2008 05:07 PM
