Old Oct 29, 2012, 07:46 PM
poomwah is offline
Find More Posts by poomwah
United States, OH, West Unity
Joined Oct 2007
Build Log
Welcome to my nightmare, my first bike build
I've been building rc cars and trucks since the 80's. Been working on and building real bikes since before then. I've had some back problems for several years now and I've finally accepted the fact that I'll probably never throw my leg over another bike.
I usually have little money to work with, more often its NO money. So this build will involve a LOT of fabrication and recycling.
I made a trade deal online for a bike, I wound up with this
poomwah is offline Find More Posts by poomwah
Old Oct 29, 2012, 07:49 PM
poomwah is offline
Joined Oct 2007
Old Oct 29, 2012, 08:04 PM
poomwah is offline
Joined Oct 2007
It's looking like I have enough to put one complete bike (minus rider) together with ball bearings in the wheels and gearbox. I'll have to cobble pieces together to make a fairing.
I could almost build another fairingless and riderless bike. I say ALMOST because I only have one MK1 swingarm and don't have enough hardware, and I don't have a set of bushings or bearings for the second set of wheels.
I'm thinking of selling the futaba rx/esc to fund some other small parts, and then trying to use one of my spare 1/10 esc's so I can try to run a bigger motor.
Guess we'll see :]
Old Oct 30, 2012, 11:01 AM
Manuspain is offline
Find More Posts by Manuspain
Manuspain's Avatar
Joined Feb 2007
You ve got a MK1, so forget to use 300 size motors on it, except if you make another gearbox, the plastic of the original one doesn't resist the temperature of the gears and the bearings.
Manuspain is offline Find More Posts by Manuspain
Old Oct 30, 2012, 01:19 PM
z_dad is offline
Find More Posts by z_dad
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
You can make a "Mr Light Venoman" to put on the mk1.
The description is somewhere in the gpv-1 thread (PDF)
I made one from filter foam for my mk1. It's softer than the original Venom rider and easier to fit the kyosho. The venom rider is ofcourse an alternative too.
z_dad is offline Find More Posts by z_dad
Old Oct 30, 2012, 02:34 PM
poomwah is offline
Joined Oct 2007
thanks manuspain, that will save me some headaches :] Unfortunately the stock motors are shot, so I'll have to figure something out for that.
thanks for the tip z dad. could you post a pic of your filter foam project.
Old Oct 30, 2012, 03:14 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Originally Posted by poomwah View Post
...could you post a pic of your filter foam project.
Here's my family. The one with the "full afro" is made from some filter foam I found. The white guys are made from packaging foam. The coloured one is finished off with a regular household iron to sculpt the crude cut piece.
They stay on the bikes by sitting on servo tape or shoe goo.
I plan to make a smaller rider for the mini z moto racer too. He will weigh in at, less, than 0,5 grams
If you dig up the pdf, you can make the printout in different sizes to get the pefect size for any bike. As I remember, the 1:12 goes at 80%
Old Oct 30, 2012, 05:16 PM
poomwah is offline
Joined Oct 2007
how about using ball bearings and using an aluminum plate for the gearbox?
Old Oct 30, 2012, 05:48 PM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
what size motor does he need ???
rcphreak is offline Find More Posts by rcphreak
Old Oct 30, 2012, 07:12 PM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
You have some good parts there to work with...
And some good parts I would be interested in trading if you're keen...
I'm trying to get some particular parts for a couple of replica builds I've got goin...
And I have quite alot of stock parts for both the MK-1 and the HOR spare that could possibly get you running...
The parts I see in your bunch of bits I'm keen on would be the single sided swingarm, and the Suzuki fairings...
I have stock motors and lots of odd bits and peices...
If you're interested just let me know, and we might be able to sort something out...
Lukey B is offline Find More Posts by Lukey B
Old Oct 30, 2012, 07:18 PM
poomwah is offline
Joined Oct 2007
was going through the packing material before I threw it out, and I found this
Lukey....
which ones are the zuke fairings ?
and I have a single sided swingarm?
Old Oct 30, 2012, 10:31 PM
Lukey B is offline
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Wow... Check that tin out... There's a piece of history there...
The swingarm is next to the tub of screws and stuff, in the third pic... There is quite alot small parts required for that, and of course a wheel to suit...
And the busted white fairings, and the seat unit on the right in the pic belong to the Suzuki...
Old Oct 31, 2012, 11:35 AM
poomwah is offline
Joined Oct 2007
I could happily get rid of a few parts if it helped me out in the long run
Old Oct 31, 2012, 01:42 PM
poomwah is offline
Joined Oct 2007
Ok,
I think I've got things figured out.
For the silver chassis, I need to make a windscreen, make a patch for the front of the fairing, the only thing missing is misc screws and the front fender mounts.
I've got the electronics to run that with stock motor, ball bearings in wheels and gearbox.
Black chassis needs :
upper and lower fairing, wheel bearings, front axle, axle nuts, front fender and mounts, crash bars, left hand grip, and LOTS of misc screws and pins.
No electronics for this one yet.
And, HOR on the way,
as far as I know so far, needs handlebars, lower fairing and tank/seat section.
No electronics for it either.
So the PLAN is,
single sided swing arm and zuke fairings are going to Luke
Going to build the silver chassis stock and use it as a "trainer"
then build the black chassis as a static display model/spare parts stash
and finally build the HOR as heavily customized as I can afford, and hopefully brushless (LOTS of time, work , and research on that one)
Gotta go raid my paint stash and see what i've got to work with .
Old Nov 01, 2012, 09:51 PM
poomwah is offline
Joined Oct 2007
ok, got the silver chassis together. don't have any of the details on it yet, just the necessities for now. Unfortunately, it will only turn right :[
I also really don't like the way the servo fits, I guess it would help if I had a mini servo, but all I've got is a micro and full size.
Discussion Complete noob to sailplanes. About to buy my first one, help and suggestion welcome Koo Sailplane Talk 55 Oct 02, 2012 09:02 PM
Discussion building my first bike... few questions? aqua_scummm Motorcycles 5 Aug 01, 2006 10:35 AM
Question My First F5B Nightmare Last Night Kenny Sharp High Performance 5 Apr 20, 2006 04:18 AM
my first bit plane build (ideas welcome) charlieuk Scratchbuilt Indoor and Micro Models 80 Dec 12, 2004 11:39 AM
