This thread is privately moderated by troynh, who may elect to delete unwanted replies.
Old Nov 18, 2012, 07:31 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Nothing too exciting, it's really hard to tell how windy it was here. You can hear it on camera as well as when the motors have to compensate. I am impressed as to how little the hex is effected considering it's size.
Hexacopter test flight (4 min 25 sec)
power is offline Find More Posts by power
Old Nov 18, 2012, 09:01 AM
lklansingkiter is offline
Find More Posts by lklansingkiter
United States, MI, Haslett
Joined Mar 2010
Quad,Octo,Avrotor
Thanks Power. The latest thing seems to be turning a quad into an Octo http://www.cnchelicopter.com/servlet...V8-X650/Detail
I would think that this would be much less efficient 8 esc's and 8 motors from just an electrical esc and motor efficiency standpoint and I would think that having the props above each other would not be as efficient from an aerodynamic standpoint. It also would have more to go wrong. These are probably just marketing gimmicks . I like the idea of just putting four more powerful motors and bigger props on the Quad. I am thinking of running the RC timer 40a esc's with the avrotor and 11inch props http://www.rctimer.com/index.php?gOo...1&productname=
Larry
lklansingkiter is offline Find More Posts by lklansingkiter
Old Nov 18, 2012, 11:34 AM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Looking good Mike. That was windy!
troynh is offline Find More Posts by troynh
Old Nov 18, 2012, 09:44 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
New frame pattern.
  • 3/4" 15 ply furniture grade birch plywood.
  • sized to accept 11" props
Probably a waste of time but I have to try it. It's been on my mind now for over a year.
Old Nov 19, 2012, 08:48 AM
Joined Mar 2010
Cedar Hexacopter
Hi
I am almost convinced to build a wooden Hexacopter or Quad out of Clear Cedar.
Do you guys have some dimensions. Are the arms square or rectangle and what is the best width, height and length. What size/thickness ply do you make the center section from? Are you attaching the motors with just screws or bolts? If I order some aircraft cedar what is the best size to get. I have a good bandsaw and a jointer so I should be able to make the patterns. Do you have some rough plans I could use.
Larry
Old Nov 19, 2012, 02:44 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Larry,
I kind of make this up as I go along.... My plans are in my head.
Arm length is determined by the max prop size used. (My latest hex designs have been 24" long - 22" between motor centers using 10" props.) Sometimes I use 3/4" square stock for the arms and sometimes 3/4" thick by 1/2" wide to shave some weight off.
1/8" or 1/4" ply can be used for the center disk and my diameters are 7".
Lately I've been building frames out of clear pine 1x stock from the Home Depot. However, this is a great deal on Sitka Spruce which is a little lighter and a whole lot stronger: You'd get enough wood in this grab bag to build around 8-10 frames. http://www.aircraftspruce.com/catalo...bag_spruce.php
Old Nov 19, 2012, 05:20 PM
power is offline
power's Avatar
Joined Apr 2003
Use lumber yard clear cedar decking rails, Rip them down to 3/4 X 3/4.Mine have been run through a jointer to get very good straightness. Laminate 1/32 ply plates on the arm ends top and bottom. This provides a harder mounting surface for the motors. If you use smaller motors (Tiger 2216) use #4 sheet metal screws to mount the motor to the arms. You only need two (see my quad pic) If you use larger motors (Avrotos) I like to use (2) 4-40 screws that pass through the arms and lock nut them on the bottom.
This is just my method, tweak as you wish. Here are a couple pdf files of my Hexacopter frame. You are on your own for landing gear, I uae a single 1/4 20 carriage bolt that passes through and a wing nut to hold my gear on. This allows easy removal...
Originally Posted by lklansingkiter View Post
Hi
Larry
Old Nov 20, 2012, 10:57 AM
Joined Mar 2010
Wood Hexacopter
Thanks Guys that is all great info. I have a good jointer and a bandsaw so I should be all set to make piles of sawdust.
Larry
Old Nov 20, 2012, 08:52 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Making progress....
Old Nov 21, 2012, 05:59 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Wow Tim, no moss growing under your feet! Nice, very cool design.
But are you saving any builds for winter????
u2builder is offline Find More Posts by u2builder
Old Nov 21, 2012, 06:06 AM
power is offline
power's Avatar
Joined Apr 2003
Looks cool Tim! Lights on the underside would look real flying saucer like
Old Nov 21, 2012, 09:40 AM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Should have it up and running by Friday...
Joe, will you be flying this long weekend?
Old Nov 22, 2012, 01:56 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Well, it flies. However, I'm still getting that surging effect after switching over to the Avroto's. Very frustrating! I'm going to take the time and switch back to the plain Jane Protrons.
-Tim
Old Nov 22, 2012, 04:36 PM
power is offline
power's Avatar
Joined Apr 2003
Looks cool Tim!
Sorry to hear about the surging....It is strange. It still sounds like a connection issue somewhere.
Old Nov 22, 2012, 09:52 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
I'm going to rewire everything tomorrow with brand new 16G as well as resetting the throttle range. Then, when that doesn't work, I'm going to order the DJI Opto 30A ESC's...
For Sale FPV Clear out. marzvt FPV Equipment (FS/W) 6 Sep 11, 2012 08:32 PM
Sold Electric & Gas airframes clear out helifree Non R/C Items (FS/W) 8 Aug 03, 2012 08:13 PM
Sold Clearing out some Jemco kits baldguy Aircraft - Electric - Airplanes (FS/W) 0 Jul 07, 2012 08:21 AM
Discussion Building parts out of fiberglass cloth and clear satin water based polycrylic stuff. GreenAce92 Composites Fabrication 8 Apr 02, 2009 08:58 PM
Discussion clear em out we gotta build something pathfinder Life, The Universe, and Politics 66 Jul 29, 2008 08:40 PM
