This thread is privately moderated by troynh, who may elect to delete unwanted replies.
Old Oct 29, 2012, 08:36 PM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Hex build out of clear pine
Started a hex frame this afternoon out of clear pine.
22" between motors. 12 oz AUW so far.
-Tim
troynh is offline Find More Posts by troynh
Old Oct 30, 2012, 10:02 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Subscribed. Nice joinery in the center.
u2builder is online now Find More Posts by u2builder
Old Oct 30, 2012, 08:56 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Thanks Joe.
Updated shots of the landing gear made this evening...
Old Oct 30, 2012, 09:24 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Very nice Tim, I do like the landing gear. I am kind of at a stand still on my build. I ran out of aircraft ply and had to place an order with aircraft spruce. I hate running out of supplies
What motors are you going with??
power is offline Find More Posts by power
Old Oct 30, 2012, 10:07 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Thanks Mike. I know what you mean about running out. I thought I had enough ply for the legs but had to scrounge in the rafters for what you see. (I realized this after I went into town for the dowels. Doh!)
I'm sticking the Avroto's on it with the SimonK Rapid Drive ESC's. WAY overkill for the GoPro 3 but that's okay. It's AUW as it sits is 31 ounces. I've flown 10 lbs with six Avrotos before. So, 5 lbs should be a lot of fun.
-Tim
Old Oct 30, 2012, 10:11 PM
power is offline
power's Avatar
Joined Apr 2003
-Tim
I am staying with the Avrotos as well, they rock!
Old Oct 31, 2012, 11:26 AM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Hey Mike,
How long are your skids on the landing gear? I'm picking them up with the GoPro set to R5. I'm going to have to shorten them up for it to work.... Just concerned with landing stability.
-Tim
Old Oct 31, 2012, 03:54 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Hey Tim, the ones on my Hex are about 10" long and 8 " below the bottom center frame board if that helps. You saw it land. Requires a little care to land on relatively flat ground to avoid tipping, but I very rarely tip it.
Old Oct 31, 2012, 05:17 PM
power is offline
power's Avatar
Joined Apr 2003
Mine are at 7 1/2 inches, I needed to keep them short to fit in my Nanuk case
It land just fine, no stability/tipping issues what so ever. I might be lower than you so things could be a bit different.
Old Oct 31, 2012, 06:46 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Thanks guys. I made mine 6". I can always take them off and add new ones if need be.
Old Oct 31, 2012, 07:24 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I mount my Go Pro such that the back is about even with the frame plate so it is a bit forward. It is mounted upside down so it hangs about midpoint of the height of the gear. I also shoot in the 720 x 60 mode so the picture is wide but not as high which helps miss the arms and the landing gear.
Old Oct 31, 2012, 09:00 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
I'll be mainly using the 1080P setting. Especially with the new GoPro 3 at 60fps in 1080P.
So, it's all glued up and ready for paint. It's very solid and shouldn't have any tippy issues as long as it flys as solid as yours Joe!
Old Nov 01, 2012, 08:58 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
The paint is still drying. I'm holding off to fly my Naza quad one more time before I strip it for motors, RX, etc...
Received the Rapid Drive ESC's today. Wire management will be a challenge on this one as the arms are so short and I'm not going to cut the motor wires again.
Old Nov 01, 2012, 09:36 PM
power is offline
power's Avatar
Joined Apr 2003
Looks great Tim I know what you mean about wire management....I only have about 3 inches of wire on my Avrotos. I solder my ESC's so they are right under the prop tip wash. That way when I move things around all I need to do is extend or reduce my power leads.
Old Nov 01, 2012, 09:41 PM
troynh is offline
troynh's Avatar
Troy, NH
Joined Sep 2006
Mike,
How on earth do you set throttle range on these escs? Or are they just plug and play?
For Sale FPV Clear out. marzvt FPV Equipment (FS/W) 6 Sep 11, 2012 09:32 PM
Sold Electric & Gas airframes clear out helifree Non R/C Items (FS/W) 8 Aug 03, 2012 09:13 PM
Sold Clearing out some Jemco kits baldguy Aircraft - Electric - Airplanes (FS/W) 0 Jul 07, 2012 09:21 AM
Discussion Building parts out of fiberglass cloth and clear satin water based polycrylic stuff. GreenAce92 Composites Fabrication 8 Apr 02, 2009 09:58 PM
Discussion clear em out we gotta build something pathfinder Life, The Universe, and Politics 66 Jul 29, 2008 09:40 PM
