Old Nov 22, 2012, 01:23 AM
Ozvooky is offline
Find More Posts by Ozvooky
Concorde :D
Joined Jan 2012
Can someone help me?
Ozvooky is offline Find More Posts by Ozvooky
Old Nov 22, 2012, 08:20 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
This is a scan of them, hopefully you can enlarge or decrease the size in your printer. Exact measurements aren't necessary almost anything will work within reason. Check the Ember thread and you'll see mine aren't anything like the stock ones and another member has a couple different designs.
TODD
http://www.rcgroups.com/forums/showt...7#post22458025
I R Irv is offline Find More Posts by I R Irv
Old Nov 22, 2012, 02:15 PM
Ozvooky is offline
Concorde :D
Joined Jan 2012
Oh my god!!! Thank you soooo much
Old Nov 24, 2012, 09:00 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Made some changes to the Mini Vapor.
Removed the "bread tie" used to secure the motor and battery wires to the fuselage stick. Removed all the velcro from the battery and battery tray. Removed pull tab from the battery leaving only the top label. There was a bit of extra adhesive here and there that got scraped off the air frame.
Installed a set of nice "indoor" wheels. Made a battery sleeve from heat shrink and secured it to the stock battery tray with UHU Por. The battery is much easier to get in and out and stays put. No dangling battery half way through a flight. Moved the rudder push rod to the inner hole (I kept finding myself at full stick flying in the basement).
No change in flying weight. Still 9.2g
Tim Wolff is offline Find More Posts by Tim Wolff
Old Nov 24, 2012, 09:18 AM
JohnC is offline
Find More Posts by JohnC
Senior Moments...I forgot
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
I would strongly urge you to secure the battery wires with some thread. reason if you keep on flexing the wires near the attach point on the receiver that will break the wires inside the insulation.
I found out the hard way. I had resolder the wires back on to the board and used a small glob of silcone adhesive. I then use thread to tie the wires to the fuslage frame.
I used the shrink tubing on the battery tray on my original vapor for the same reason.
John F. Clarke
JohnC is offline Find More Posts by JohnC
Old Nov 24, 2012, 09:48 AM
Tim Wolff's Avatar
Joined Sep 2002
I may have to tie off the wires as you suggest. But having the wires break would force me to shorten the battery leads to a more reasonable length.
Any significant weight savings on this model is going to have to come from the sum of numerous small savings. But how far to go and how much to spend? It is already quite capable of the mission that I purchased it to fulfill. Flying an airplane in the house w/o damaging the plane or the environment (walls, furniture etc).
Old Nov 24, 2012, 09:58 AM
JohnC is offline
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
Good point on the length of the battery wires. I to want to fly in the house. I have a mini Bapor but have not flown it yet Ehrn I can get to my usual flying site I will fly it. I want to feel it out first. It is hard to not try it. I have been try to build a 3.75 gram biplane but so far the second build is 4 grams. I may try again to get it lighter.
John f. Clarke
Old Nov 24, 2012, 11:14 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Tim,
I suspect the main way to lighten the plane would be to recover it with WES clear film. I removed the film from a Vapor wing once and weighed it and calculated weight per square inch. It was substantially heavier than WES film. I can't find my records on that, but I think the WES film was less than 1/5 the weight of the Vapor covering.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 24, 2012, 12:37 PM
Tim Wolff's Avatar
Joined Sep 2002
Originally Posted by Gordon Johnson View Post
Tim,
Gordon
How strong is the WES film?
So far the Mini Vapor can bounce off the floor lamp and go down inverted behind the TV w/o issue
And I'd lose that wonderful factory paint job LOL
Old Nov 24, 2012, 01:18 PM
JohnC is offline
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
I have the "WES" film from Homefly and it not as tough as the Vapor film. I used the flim on my Dave Roeblem "Walker".
My two cents
John F. Clarke
Old Nov 24, 2012, 09:06 PM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
I like the wheels, Tim.
Dont get to do much RC stuff these days, but when I saw this one, I had to carve out some time. Fun little plane, slows down well or zips along, very maneuverable. I used its box to make a ramp for super short take offs, making a U turn and trying to land on the ramp is a fun game, as is buzzing the ceiling fan, or loops or attempted inverted flying.
I've got the push rods in the lowest hole for both the elevator and rudder, swapped out the connectors so I could use the batch of 5 30mah lipos I got from bidproducts a while back. They weigh .1g more than the stock one, but I can get a ten minute flight if I stay off the throttle.
The covering art leaves a bit to be desired IMO, I've got some esaki tissue, but dont know if that'll end up being lighter or not. A fourth channel could make things interesting. Great plane, perfect for LRF'ing...time to make some floats, or find some SMD LEDs.
Nick
Parkzone Mini Vapor fun (5 min 42 sec)
micro_builder is offline Find More Posts by micro_builder
Old Nov 25, 2012, 06:47 PM
Tim Wolff's Avatar
Joined Sep 2002
Some video of the Mini Vapor in the basement.
http://www.rcgroups.com/forums/showt...9#post23361578
Old Nov 25, 2012, 07:05 PM
Boston, Mass
Joined May 2001
The WES film is "strong enough." I've covered my Aileron Vapor, Air Bender, and others with it. When a plane hits a wall the covering doesn't shatter. That's not the direction that impacts would harm covering. What's more likely is that WES covering won't hold up as well in mid-air impacts, particularly with a prop. But, I built my Aileron Vapor from a Vapor I got my daughter for Christmas, and the first time she flew it someone with a Sukhoi was out of control and shredded the covering off pretty much just about the entire Vapor. So, I wouldn't worry about the strength of the WES covering. Anything that shreds it is likely to also shred the standard covering.
Very nice video of the Mini Vapor in your basement. Mine arrives in a couple of days and I'm guessing my boys will be all over it flying it in our house. I also have two spare wings coming with it.
Gordon
Old Nov 26, 2012, 04:29 PM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
Got mine today- It's marvelous!
Removed .2g worth of stickers and some plastic.
Flies well, even with a 70mAh cell!!
Pete P is offline Find More Posts by Pete P
Old Nov 26, 2012, 08:10 PM
Boston, Mass
Joined May 2001
Mine came today. Here is its first ever flight, right out of the box, in our family room. What a great plane.
Gordon
Mini Vapor 1st Flight (0 min 52 sec)
New Product Parkzone Mini Vapor Flyboy70 Micro Ready-to-Fly 1772 Jan 16, 2016 01:53 PM
Discussion New ParkZone Vapor Mini- 8 inch ws Vapor Trails Atlanta Area RC 4 Oct 25, 2012 08:19 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 03, 2012 01:25 PM
