Old Oct 29, 2012, 05:40 PM
neosunrise is offline
Find More Posts by neosunrise
neosunrise's Avatar
United States, IL, Chgo
Joined Jul 2012
Is it safe to use this glue on EPO foam?
Hey guys, I jut got my HobbyKing Atom mini glider (EPO foam) Since it does not come with glue, I wonder if I can use the glue I have.
Here is the one that I have:
3M Plastic Emblem and Trim Adhesive
http://www.amazon.com/3M-03601-Plast.../dp/B000CCM3J2
I wonder if I can use it safely. btw, I have another Cessna 182 which is made of EPS foam. Can I use this glue on that?
Thank you!
neosunrise is offline Find More Posts by neosunrise
Old Oct 29, 2012, 09:26 PM
Johnny Five is offline
Find More Posts by Johnny Five
Johnny Five's Avatar
Canada, AB, Fort MacLeod
Joined Aug 2011
Test it on an area that you don't mind melting or you could get something designed for gluing foam.
http://www.amazon.com/Beacon-Foam-Ta...s=foamtac+glue
Johnny Five is offline Find More Posts by Johnny Five
Old Oct 29, 2012, 09:53 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
You should read the back of the package and see what it says about using on foam.
The glue you would want to use is a CA glue, does not need to be foam safe as you plane is made of EPO foam.
Lou is offline Find More Posts by Lou
Old Oct 29, 2012, 10:53 PM
David Hogue is online now
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
The reg ca is great for the epo plane. Get the foam tac mentioned in the other post for your eps 182
David Hogue is online now Find More Posts by David Hogue
Old Oct 29, 2012, 11:25 PM
neosunrise's Avatar
Joined Jul 2012
Thank you guys, I have bought a foam glue.
Discussion EPO Foam glue: gorilla vs this other stuff gsgleason Beginner Training Area (Aircraft-Electric) 71 Jan 08, 2016 10:17 AM
Discussion Glue Advice for EPO Foam PeteSchug Scratchbuilt Indoor and Micro Models 40 Nov 02, 2014 11:30 AM
Help! Looking for flexible EPO-safe glue wolfv Foamies (Kits) 6 Sep 10, 2012 09:28 PM
Discussion Question on using Foam SAfe Ca on EEP Foam. DanT 3D Flying 2 Nov 27, 2006 10:16 PM
