Old Jan 27, 2013, 02:19 PM
deckert is offline
Find More Posts by deckert
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
Wheel Pants
Decided I may as well get them on. There has GOT to be a better way to do this. I decided to take a different approach. The way I did it is in the images. No lock collars are used & the tires turn freely. The inside spacer is a cut down servo horn and the outside grey spacer is from the parts included in the kit. I think it's for the axles. The metal bracket is from the Sullivan wheel pant bracket. I got lucky because the spacers made for a perfect fit with no slop for the tire to turn.
Dan
deckert is offline Find More Posts by deckert
Old Jan 31, 2013, 08:32 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Aww Cr*p
Back to the drawing board. We made and ruined 3 pieces of tube trying to make the exhaust. Had to mill the OD on the tube in order to thread it. Also milled the OD on the tube before bending. Milled down to .456? full length.
Spring bender= failure - kinked
Tubing bender=failure - kinked
heated tube=failure - snapped in half
I'm just going to slap a muffler on and see if a silicone adapter will hold for a few flights. Maybe this weekend I can get it into the air if the weather holds..
Dan
Old Feb 12, 2013, 02:12 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
so whats the verdict?
almost got one this last wk end in monroe!
whiskykid is offline Find More Posts by whiskykid
Old Feb 13, 2013, 12:57 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
The muffler extension issue went south.. I should have just went with steel tube and been done with it. Optimism does have it's downfalls. I have an old silicon extension to put on. Unknown if it will hang on because the muffler is the old style with just the straight tube coming out. But.. We're hoping this Thurs. or Friday to get it into the air. Stinking winds and lousy weather reports.
I heard two stories about Monroe, good/ok for buyers but the vendors were unhappy. Not sure which to believe because I know both of them pretty well.
On a side note, I put my Pilot1 electric 18% SBach up on Sunday. It was ugly. The bird was tail heavy, took 8 passes and 400' of runway to get it down in one piece. I'll have to drag it along and put up some pics of side by side at the field. Colorwise, the Pilot beats the GW hands down IMHO. I'll either be writing a big hoorah or whining in the next few days if the weather will co-operate.
Dan
Old Feb 15, 2013, 06:19 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Report
It looks as though this bird is going to be a KEEPER!!!!
Put 7.5 minutes air time on it plus some ground time and used 1/2 tank of fuel. Take off was straight down the RW and lifted off nicely. I'm using less then 50% throws for testing. Prop was 13x6 on the Saito. On board glow worked perfect. Did a few loops. Axial rolls are really really quick. I think loops are rolling out to the right. Hard to say as my hands were kind of cold. Pretty much a floater for landing. I carried a bit of speed though until I can gain some seat time. About 50% of the flight I used WOT. It may not be unlimited vertical but if not, it may as well be. It was getting to small to see. I tried 1 knife edge but I was to far out to keep it under control. Unsure about any hammerheads with limited throws set. Took 4 clicks up elevator & 4 clicks right aileron down for straight and level. Fuel tank isn't bubbling and is setting rock solid.
Bad news being, I blew the silicon muffler extension off during engine run up in the stand. I was PO'd but flew anyway.
Dan
Old Feb 15, 2013, 09:02 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
sounds great deckert! ya I probably should have spent the extra 50 bucks and got the SBACH, but I was looking for an airframe for my 20cc gas engine!
so I bought a 100 chinnise version of the GP 64" EXTRA 330! it's almost identical to my extra 300s, except it has bigger ailerons, and exstensions on the elevator! I.E. more throw! like my GP extra 300s on steriods!
you'll get that exuast fig'd out! good thing bout a 4 stroker, they don't slob oil like a 2 stroker! (unless there old like the 20 I have in my eflite 260 )
Old Feb 15, 2013, 09:31 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
I hear ya. We gotta make choices sometimes.. I'm pretty sure I'll like this more as I get better aquainted with it. I already like it better then the SeaGull Edge 540 I had. It flies lighter and is a whole lot easier to see in the air. I'll be trying some different props to see what else happens.
Dan
Old Feb 16, 2013, 08:28 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Yeah Dan the sea gull is kind of a lumber wagon speaking from experience.
I'm glad to hear you got your bird up an flying. Keep us post
kerwin50 is offline Find More Posts by kerwin50
Old Mar 13, 2013, 08:24 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
so hows it been going deckert?
hope all is well! and the plane is flying great, as I put my Monroe wonder in last week! flew great till lost power, then there was not enough elevator to even keep it level! yet alone airborn!
shoulda got the SBACH!
Old Mar 14, 2013, 12:31 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Dang! That's sad to hear. Maybe use the gear on the SBach?
Going good on my end. Still gently feeling mine out. I wound up bolting brass tubing onto the old style muffler. It sure is a floater. Wheel pants are still on & working. I'm just doing baby steps on mine to get the feel of it. The Sullivan on board glow is working great. No flame outs. Let us know what you change into.
Dan
Old Apr 01, 2013, 12:18 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Sullivan onboard glow failed. Muffler fell apart. Pressure tap blew out. But the bird sure flies nice. This build is just near perfect for size & power.
Dan
Old Apr 01, 2013, 02:55 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
that is great news deckert! cuase I am on the hunt for an 80 ta 90 four stroker, too put in the same size plane, if not the same plane!
Old Apr 19, 2013, 07:46 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
Originally Posted by gjhinshaw View Post
well couldn't do it, take it anymore, with my B-day coming up, the Mrs. let me order the MX2!
not sure what going in it yet, I have a new OS 61fx with pitts muffler, or there is a guy in our club that might have a magnum 80fs!
well keep you guys informed!
Old Apr 20, 2013, 01:31 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Stuff the max in. The GW's aren't as 'heavy' as the SeaGull models but... I'm just saying. I'm "still" pissing around getting an exhaust into my SBach and am REALLY po'd over it. Not the bird but with Saito parts. The bird is damn stable but this Saito stuff has my rearend bound up like a cork in a wine bottle. My last 2 options are a Slimline pitts muffler or a remod on the Saito components. I'm going to try a remod 1st and if that fails..then on to Slimline.
My backside is on fire..
Dan
Old Apr 20, 2013, 06:44 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Yeah I've dealt alot with GMP. I've always gotten good service. I'm looking at the 20cc SBach
Found Goldwing RC 100cc Sbach wing/wings sarlacc Aircraft - Fuel - Airplanes (FS/W) 0 Aug 20, 2012 10:56 AM
Discussion Gold Wing RC SBACH-342 V3 30CC / 73" / 26% eJets Giant Electric Planes 26 Nov 26, 2011 12:43 PM
Discussion Gold Wing RC SBACH-342 50CC Yardbee Giant Electric Planes 47 May 03, 2011 07:06 PM
Discussion Gold wing sbach wing explodes!!!! mytms Giant Scale Airplanes 1 Apr 10, 2011 03:10 PM
