Old Dec 21, 2012, 08:13 PM
deckert is offline
Find More Posts by deckert
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
Got the tank installed and the tank mount completed, plus it's removeable. Plenty of room for the throttle linkage to bypass the tank. Worked out better then I had hoped.
Dan
deckert is offline Find More Posts by deckert
Old Dec 21, 2012, 09:30 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
ah yes! you gotta love it when a plan comes together!
whiskykid is offline Find More Posts by whiskykid
Old Dec 22, 2012, 01:22 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Throttle servo & linkage are in. Nothing hitting or binding.
Dan
Throttle (0 min 15 sec)
Old Dec 22, 2012, 07:41 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
It looks like a really nice clean install.
kerwin50 is offline Find More Posts by kerwin50
Old Dec 22, 2012, 03:24 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
I've never encountered this before. Probably be a few days before Sullivan replies. Surely this isn't typical is it? They're Sullivan S889.
Dan
Old Dec 22, 2012, 07:57 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Advice? Pros--Cons?
Good news is the plane will balance. Bad news is the rcvr. & glow driver packs need to be located here to hit CG. I've never had packs under the cowl this close to an engine before. Thoughts?
Dan
Old Dec 22, 2012, 08:51 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
I have stuffed packs on top, under,and all around fuel tanks to get balance, I can't see how that would be a problem!
however I do hope you plan on closeing up the rest of the firwall! no mater how clean your engine runs, it well get nitro all through the airframe!
check out the slick build for reference if you need!
Old Dec 23, 2012, 12:32 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Good point! I have a big cutout on the bottom of the cowl that will also direct airflow down.
Dan
Old Dec 28, 2012, 02:29 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
I'm stuck on a way to get the muffler extended down far enough to exhaust out the bottom of the cowl. Unable to find enough part/pieces to do this. The flex pipes are pieces of $$$ junk(keep breaking/leaking) and the silicon deflectors keep failing so those are out. May be forced to build my own. I have no desire to cut new holes into the cowl to make an exhaust work when I should be able to dump out the bottom in the existing cut out.
Then there's the power to feed the on board glow. Because the glow pack will be located under the cowl, AND the leads are not micro deans, and the leads are not long enough, there's no way to leave it inside the bird, have it connected and still be able to charge the pack. So I'm glad I can solder. WTH Sullivan doesn't have a port in the switch to charge a pack is beyond me. The parts are made & I'm done whining for now....
BTW, Sullivan is sending some new wheel pant mounts. I sure hope they fit.
Dan
Old Dec 28, 2012, 09:03 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Boy thats alot of weight quick.
On my 3D planes I balance them on the wing tube.
Old Dec 28, 2012, 03:34 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
6lbs. 3oz without fuel.
Dan
Old Dec 29, 2012, 09:07 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
just curious deckerd, did you have the onboard glow driver on your last plane?
I know there nice to have in some scale aplications, but did you need it?
I have seen alot of saito's in my time, and none of them really needed onboard glow! maybe some wieght savings would be in order!
Old Dec 29, 2012, 11:24 PM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
No onboard glow ever. I had/have the H9 glow plug adapter in all the birds so I didn't need to get my fingers around the props. Unfortunately, the filthy things are not reliable when plugged in. I have to hold it just right to get contact to the plugin. For some reason, my .82 has quit 3 times in the air, I had fuel, no plugs in the line, fuel filter is installed and the H9 plug is new. I even installed a new plug after the 1st quit. The 3rd dead stick landing was a crash because I was to low in a high bank turn and running maybe 1/2 throttle. I decided I'd try the driver and see what happens. My other 4 Saitos don't just quit. .56, .72, .91, 1.00 unless there's no fuel.
It didn't help with CG by adding the 2nd servo to the elevator. That added 1.3oz on the tail. As the bird sits now, the glow pack and the rcvr. pack allow the plane to balance out. I'm not sure removing the extra servo would be enough to let the plane balance. The glow driver switch is 1.2oz. and is just ahead of the wing tube. The fuel dot is even further in front of the wing tube and weighs .25oz. The driver pack is 5.2oz. and located under the cowl. All told that's 7.95 oz that 'could' go and would drop the weight to 5.7lbs. I could lose more weight if I dropped both packs to 4.8v as well but I already had the 6v.
I have some new Al tube coming in the mail to make a new exhaust setup. Just have to thread/bend it. Rated to +400* F. It's a week+ away.
It'll be interesting to see what happens after all my confobulations..
Dan
Old Dec 29, 2012, 11:33 PM
gjhinshaw is offline
Find More Posts by gjhinshaw
gjhinshaw's Avatar
Lathrop, Missouri, United States
You may want to check where the fuel tank is to the CG.... Might be to low???
gjhinshaw is offline Find More Posts by gjhinshaw
Old Dec 30, 2012, 10:35 AM
deckert is offline
Plowin Dirt
deckert's Avatar
Joined Oct 2007
Dan
Found Goldwing RC 100cc Sbach wing/wings sarlacc Aircraft - Fuel - Airplanes (FS/W) 0 Aug 20, 2012 10:56 AM
Discussion Gold Wing RC SBACH-342 V3 30CC / 73" / 26% eJets Giant Electric Planes 26 Nov 26, 2011 12:43 PM
Discussion Gold Wing RC SBACH-342 50CC Yardbee Giant Electric Planes 47 May 03, 2011 07:06 PM
Discussion Gold wing sbach wing explodes!!!! mytms Giant Scale Airplanes 1 Apr 10, 2011 03:10 PM
