Old Oct 29, 2012, 11:01 AM
Joined Jan 2011
calculate rounded intake FSA from a square intake
Hi, about to start scratch buliding a jet for a 70mm fan. The jet has two square intakes on either side of the fuesalage and joins to make 1 towards middle of plane. How can I figure out if the 2 square intakes are big enough to get me to 100% fsa of the fan? Each well, i guess its a rectangle not a square intake is 1 inch wide by about 2 inches tall. So overall combined would be 2 x 2 inches.
Edit: Ok I have a 2nd question on fsa. To get 100% of the fsa, you take the inside diameter area and subtract the hub area to get the "open" area squared. So , I did this calculation and came up with about 3044mm squared. So taking the square root of that bring its out to roughly 55mm. That 55mm would be 100% i'm assuming. Now, on a previous build I was reading to do 85% fsa for the thrust tube exit. Now at the time, I didn't know the equations, so I just googled around for the answer and the consensus I got for a 70mm fan at 85% would be 56mm. Now, with the actual math I just did, that 56mm is actually bigger than 100% of my fsa. At 85% based on my numbers it should actually be 46mm. Is this correct, cause I'm super confused now.
Edit 2: Disregard my second question. Was doing the math wrong. You take 85% of the squared open area, then divide by 3.14, and then multiply that by 2.
Edit 3: Ok, trying to figure this out. My 100% FSA is 3044mm squared. So taking my 2x2in combined intake, converted to mm, 50mm x 50mm would be 2500mm squared. So I take it, unless I'm doing something wrong here, my intake is 82% of the FSA of the fan which is in fact too small. Doing some more calculations, if I increase my total intake size to 55mm x 55mm , will give me 3025mm squared, which will be just a tad under the 100%
stingeragents is offline Find More Posts by stingeragents
Old Oct 29, 2012, 01:28 PM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You need to read this!
http://www.rcgroups.com/forums/showt...t=70mm+fan+fsa
CoolerByTheLake is online now Find More Posts by CoolerByTheLake
Old Oct 29, 2012, 03:07 PM
Joined Jan 2011
Cool thanks. Yea as soon as I posted my frustration I found the answer that I was doing the math wrong. I think my math is correct for figuring out the square area of the intakes to where it is what it needs to be so basically a pointless thread I guess.
Old Oct 29, 2012, 04:08 PM
Joined Dec 2008
Perhaps, just a little over thinking? That fan calc in post #9 is a handy tool.
I know you are using a 70mm, but in same post, it was said " (For 90mm fan, motor diameter is usually around 36mm)". A great many are 39mm for the 90.
Good luck on your project. If you want to have some real fun, do a build where you have to do conversions from different scales!!!
Old Oct 29, 2012, 06:59 PM
Joined Jan 2011
I have no clue how to scale so thats out. Lol
Discussion Multirotor Arms: Round vs Square? TheFernMan Multirotor Talk 21 Oct 28, 2012 03:59 PM
Discussion FSA and Intake Size CoolerByTheLake Electric Ducted Fan Jet Talk 9 Jul 25, 2012 11:53 AM
Discussion Question about calculating FSA... marell01 Electric Ducted Fan Jet Talk 5 Apr 19, 2009 06:50 AM
Discussion FSA and intake/exit questions Willmsy Electric Ducted Fan Jet Talk 5 Feb 14, 2008 03:05 AM
Discussion Changing Trainer Plugs from Round to Square tvedit Video Piloting (FPV/RPV) 4 Jan 22, 2007 05:40 PM
