Joined Jan 2007
www.rcgroups.com/forums/showthread.php?t=67873
Prandtl's biplane theory from 1911 nicely calculates the wing efficiency of a biplane with any separation and stagger. The advantage of a mono-wing over a biplane isn't that straightforward. If you are span limited, a biplane can get two wings of twice the aspect ratio so they start with twice the span efficiency in a given span length. For slow flight, where induced drag is high, the higher aspect ratio wings could be the more efficient option despite the interference effect. When you also look at the huge structural advantage, a biplane might be the best option in some circumstances. And they look cool! Of course for model sizes, the Re of two smaller wings is a problem. Kevin Edit: "The induced drag of a multiplane is lower than that of a monoplane of equal span and total lift because the nonplanar system can influence a larger mass of air, imparting to this air mass a lower average velocity change, and therefore less energy and drag. For a biplane, if the two wings are separated vertically by a very large distance, each wing carries half of the total lift, so the induced drag of each wing is 1/4 that of the single wing. The inviscid drag of the system is then half that of the monoplane." http://aero.stanford.edu/Reports/VKI_nonplanar_Kroo.pdf |
Thanks Kev, Bruce, Richard. I do have limited span (it's a 16" max span dime scale model) The gap and stagger is pretty standard: gap is 1.1 x the chord and the stagger is 0.4 x chord. I'm not specifically trying to calculate the efficiency, although the effective wing loading is of interest. (It is good for a dimer, even with the 85% fudge) My specific task is to correctly size the tailplane for this model. I use the tail volume coeffoicient widely in monoplane free flight designs but this my first bipe. I normally go for a Vht of around 0.6 which suits most scale models. I was just wondering whether using Vht = (Tail Area * Tail Arm)/ (Wing Area* Wing Average Cord) should I use the actual chord or the span/area? Come to that how do you describe the aspect ratio of a bipe? How do the pitching moments compare between a monoplane and biplane of the same span and area? |
Joined Jan 2007
For biplanes with stagger, u is the ratio of the aft wing span/ front wing span. There is another chart for when the aft wing has more span than the front. And those charts are for elliptical span loadings. Things can be made better using uniform loadings, or even constant chord wings - looks familiar...
Munk's original paper on biplane stagger theory is on-line, and will explain it all better than me. Biplane is also covered in good detail in von Mises "Theory of Flight", which is a book worth having. http://naca.central.cranfield.ac.uk/...report-151.pdf The tandem wing airplanes like the Q2 and Dragonfly are covered by Munk's stagger theory, which is pretty cool! Kevin |
It was slightly surprised it was so low from just eyeballing it. If it were a peanut model a high standard of scale then I would persevere without any enlargement but as dime scale is quite relaxed in it's approach then easy flying comes first. I can sneak it up to about 0.5 before anyone would notice.Here's the little chap: the Avro Baby. It has quite a good tail moment so the dynamic stability should be ok. The little vertical stab might prove interesting though... Jon |
| Thread Tools | |
| Discussion Sharon 3.7 V-tail tail volume coefficient and rudder power | gustabmo | Sailplane Talk | 4 | Oct 19, 2006 01:49 PM |
| Tail boom length and Tail Volume Ratio | Peytr | Hand Launch | 6 | May 10, 2005 10:45 AM |
| Twin Tails and Approximating Tail Volume | SoarNeck | Modeling Science | 0 | Nov 08, 2004 02:40 PM |
| biplane tail volume coefficient | Richard | Modeling Science | 9 | Oct 25, 2002 05:24 PM |
