Old Nov 11, 2012, 03:08 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Shaft removal
Now for the tricky part.
With the socket shaft receivers in place, put the bell assembly in the vice.
You need to get everything square so when the pressure is applied the assembly doesn't start to cock on an angle in the vice jaws. Keep positioning stuff until when slight pressure is applied, the whole mess stays straight. This is important to prevent distorting the bell.
Start applying pressure by tightening the vice. The shaft should start to move fairly easy. Press it out from front to back until the shaft is flush with the front bell shaft boss.
Loosen the vice and insert the pin. Press the shaft the rest of the way out, making certain everything is still straight.
Next, preparing the new shaft.
glewis is offline Find More Posts by glewis
Old Nov 11, 2012, 03:18 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Threaded shaft preparation
The knurled area of the GWS shaft is in the wrong place for our application and it is too large to fit. You could force it into the soft aluminum, but I would caution against doing that. That being said, here's how I resize the shaft.
First measure the diameter of the original shaft. We will need to cut some of the knurl down so it doesn't distort the aluminum and want it the same size as the original shaft.
Chuck the shaft in the drill and while it spins file the knurl down a bit at a time. Measure carefully, we want a precise fit or the bell will wobble on the shaft.
Keep checking the fit by sliding the bell onto the shaft. You want it to just 'catch' on the knurl as it starts to pass into the bell.
The shaft will be too long at the back at this point, we'll address that later.
Next, installing the new shaft.
Old Nov 11, 2012, 03:23 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Installing the new shaft
Slide the new shaft into the bell from back to front.
Slip your shaft receiver socket(s) onto the front of the shaft.
Put the mess in the vice and start pressing the shaft into the bell.
Stop when the knurled part is fully seated into the bell boss.
Hang in there, we're almost done.
Next, final assembly
Old Nov 11, 2012, 04:00 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Final assembly
Now we put the bell assembly back onto the bearing tube. Make sure your tape covering the magnets isn't in your way and preventing the bell from going all the way on.
Measure the shaft protrusion and mark the length.
Remove the bell assembly and chuck the threaded portion in the drill.
Using the cut off disk, spin the bell assembly in the drill and part off the excess shaft. Now while it's still spinning, cut a new E ring groove with the cut off disk.
Remember the tape on the magnets? Now all the grinding dust is stuck to the tape. Carefully remove the tape from the magnets. I like to clean the magnets with the sticky side of the tape to make sure there is no metallic swarf hiding on them.
Slip the bell assembly in, add the spacer and E-ring.
Last thing to do is check the end float of the assembly. You want just a bit of slack. If it's too tight, you will need to press the shaft to the rear just a hair. I've done this by tapping the end of the shaft with a piece of wood. Once satisfied with the end play, install the set screws.
That's it. Done.
Sounds like a lot, but it only takes me 20 or so minutes to install a threaded shaft and it sure makes prop mounting a whole lot easier!
Glenn
Old Nov 11, 2012, 04:25 PM
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Wow! Hmmm. Not having some of the tools is a bit of a drawback. Perhaps you could run a conversion service
I'll have another look at my options: the threaded shaft is definitely the easiest way to mount the spinner, but...
Glenn, many thanks for your time and effort. I'll consult my club-mate TrevorH; he has quite a well-equipped workshop.
On the constructon front, I got the starboard and port wings to the same stage this afternoon and the wing is starting to look like part of an aeroplane.
Sopwith Mike is offline Find More Posts by Sopwith Mike
Old Nov 11, 2012, 04:53 PM
Complete the Illusion!
35Mhz's Avatar
UK South Coast
Joined Oct 2003
Hmm, why not just thread the existing shaft with a 3mm die?
35Mhz is offline Find More Posts by 35Mhz
Old Nov 11, 2012, 04:54 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
The shafts I tried to thread were harder than the die.
Guess you could remove the shaft, anneal, thread then harden.
Old Nov 11, 2012, 08:27 PM
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Glenn,
Thanks for taking the time to do the prop shaft write up. Very helpful info
Dave K is offline Find More Posts by Dave K
Old Nov 12, 2012, 07:54 AM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Glenn, that's a great write-up. Many thanks!
Steve
Steve85 is offline Find More Posts by Steve85
Old Nov 12, 2012, 09:11 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Hope you guys will try it.
The same procedure will work on just about any motor. GWS has 4mm and 2.5mm gearbox shafts too so this wouldn't be limited to just motors with a 3mm shaft.
Of course the listed equipment is just what I recommend.
There are other ways to skin a cat....
Glenn
Old Nov 13, 2012, 09:07 AM
Joined Aug 2004
Where have I got to after all this talk of swapping motor shafts?
I'm still on the wing, which is complete except for the 3/16th soft balsa LE, cutting out and making the ailerons and fixing on the tips. I recall seeing a drawing of one of the H versions (it may have been the prototype) with much rounder tips but all the other drawings I have show the square-cut version.
It's a while since I built as small a model as this and I keep making big-hand mistakes, so far nothing that can't be hidden from casual view. I'm enjoying the journey, and learning a lot from you experienced free-flight converters as you build your own and comment on the other threads.
Old Nov 13, 2012, 12:37 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Sorry to clog your thread, once I started the explanation I couldn't stop...
Nice wing. What size wire will you use? Did you consider using an aluminum tube?
Glenn
Old Nov 13, 2012, 12:56 PM
Joined Aug 2004
Glenn
Hi Glenn,
I'm glad to have such a useful lay-by in the thread! I used the Dubro stuff because I had it in the spares box, no other reason! The wire is just what it comes with: not as hard as piano wire but good enough for a light model with small aerodynamic forces.
I put the LE on since my last post and razor planed and sanded it to shape. Very satisfying!
Old Nov 13, 2012, 06:19 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Wish I could get the hand of using a razor plane.
I've tried and always make a mess of it. Would like to find a plane that uses a single edge razor blade instead of the dull piece of crap that came in the plane I bought.
Glenn
Old Nov 13, 2012, 06:33 PM
Steve85's Avatar
Joined Mar 2004
Mike,
Nothing quite like watching the balsa curlicues come out of a razor plane, is there? I think the plane is my favorite tool just for that, and I could probably turn a sheet of balsa into very expensive kindling just fooling around with it!
Regarding size, everything is relative. A 40" span model would be big for my bench, except for the Lancaster which spans 51" and routinely provokes oos and ahs from the family members because it's "so big". Just the same, as Paul Kohlman (Longhorn) has pointed out on another thread, everything on his bench (and mine) seems to be suffering from size creep. Whereas a 28" Guillows model was once a fair-sized model on my bench, I find myself deciding that the CF-100 Canuck I'm mentally designing as a future build will probably need to be bigger than 36" if I want it to look "right"....
Steve
Build Log #9 West wings Topaz Free Flight to RC Flight Kitbash Contest >>3DDFHobbies<< Keenan smith Balsa Builders 5 Feb 13, 2013 01:26 AM
Contest Guillow's Superfortress #4 Free Flight to RC Flight Kitbash Contest - Smokin' Beaver Smokin' Beaver Scale Electric Planes 80 Jan 27, 2013 11:45 AM
Contest Free Flight to RC Flight Kitbash Contest >> Starts 17 Nov Murocflyer Balsa Builders 153 Dec 06, 2012 08:49 AM
Build Log #2 Free Flight to RC Flight Kitbash Contest >> AndyKunz << AndyKunz Balsa Builders 0 Oct 24, 2012 11:17 AM
