Old Oct 28, 2012, 09:37 AM
gdimonte is offline
Find More Posts by gdimonte
Canada, ON, Newmarket
Joined Dec 2005
HL/nitroplanes F4 70mm kit build (numerous mods)
Warning, this will be a very slow build.
I currently have one of these planes running on an E-flite delta-v 15, 3600kv motor and 4s 3300 30-40C turnigy lipo producing between 700-800W. The plane is covered with 3/4oz glass and WBPU, aileron servos have been moved to the top of the wing, rudder has been added and exhaust nozzles hot wire cut to get rid of the screwed-up thrust line. I've flow it most of the summer and am very happy with it. I've since purchased another airframe and am planning the following changes:
1 - change fan to lander 68mm 6S (should be good for 700-800W & better sound
2 - run on (2) nano-tech 3S 45-90C batteries in series (this should allow more room to move batteries around to get the proper CoG, common batteries used with alot of my other planes
3 - rudder installation ( going to try and get everything to sit in the fuse this time)
4 - full flying stab (looking for more scale appearance and like the build challenge)
5 - electric retracts, want to try and build half decent gear doors to cover them
6 - build new (bigger & thicker) wings to accommodate extra wing loading and to have landing gear sit within the wing
7 - wings will have separate flaps and ailerons
I've already started on the motor installation and the stabs and will post pictures once my camera batteries are charged.
gdimonte is offline Find More Posts by gdimonte
Old Oct 29, 2012, 08:19 PM
gdimonte is offline
Joined Dec 2005
Progress on pivot for stab.
Will run carbon tube through the fuse and into the stabilizers. I have another brass tube that will be used for the elbows to get the downward angle set.
Old Nov 19, 2012, 01:22 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Cool Mod Gdmonte , I have considered doing that mod with mine . Instead I've been adding aluminum sheeting from pop cans along with alum. tape .(crash repair ) I'll be watching your progress and just might have to do the same thing
pencon is offline Find More Posts by pencon
Old Nov 19, 2012, 07:18 AM
gdimonte is offline
Joined Dec 2005
Been following your progress also.
Old Nov 19, 2012, 07:36 AM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Love it.
Looking good - was wondering how the anhedral angle would be handled in regard to attachment to elevator drive mechanism. How much glue joint length is there between carbon spar and the brass? - if I read right, looks to be 1/2".
Originally had wondered also how larger wings were going to be had......looking at the elev, now I know .
PikeStaff is online now Find More Posts by PikeStaff
Old Nov 19, 2012, 11:24 AM
gdimonte is offline
Joined Dec 2005
1/2" is correct.
Will hot wire the larger wings.
Old Nov 19, 2012, 02:34 PM
pencon is offline
Joined Dec 2008
gdimonte are you going to increase the span or just the thickness ?
Old Nov 19, 2012, 05:27 PM
gdimonte is offline
Joined Dec 2005
I haven't done any of the math yet. The wing will probably be the last piece of this puzzle. It will definately get thicker to accommodate retracts. I expect to have some combination of larger wing span and longer root length at the tip.
Old Dec 13, 2012, 01:52 AM
pencon is offline
Joined Dec 2008
Do you have a link to your exhaust mod for the f4 ?
Old Dec 13, 2012, 11:30 AM
gdimonte is offline
Joined Dec 2005
http://www.rcgroups.com/forums/showt...1519325&page=2
Old Jan 08, 2013, 07:15 PM
gdimonte is offline
Joined Dec 2005
Jan 8/2013 update
- glassed elevators, rudder and upper rear section
- elevator servo and rods dry installed. I'll glue everything once I know it all works
- rudder control installed, nothing showing outside of the airframe. Servo needs a proper mount. It's just taped in place for now
I plan to glue the lower half of the rear section to the rest of the airframe. The upper half with the rudder will be removable so that all the internal parts can be accessed.
Old Jan 08, 2013, 07:30 PM
gdimonte is offline
Joined Dec 2005
More pictures
Old Jan 08, 2013, 07:32 PM
gdimonte is offline
Joined Dec 2005
last set of pictures for now.
Working on wings and trying to decide what to do with the inlet and exhaust from the fan. Inlets are way oversized and I'm thinking about changing to a single oval outlet similar to the Dan Savage F4 kit.
Old Jan 23, 2013, 11:02 PM
pencon is offline
Joined Dec 2008
Awesome mods gdimonte , I was thinking about doing the same mod to the tail on mine but I first have to fly mine with all the metal I've done and see if it can handle more weight . Are you going to do the smaller intakes as well ?
Wanted WTB J-power/HL 70mm A-7 Corsair jdlilfan Aircraft - Electric - Jets (FS/W) 5 Nov 14, 2015 11:24 AM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
Discussion Nitroplanes/HL/? 70mm F4 cog location gdimonte Foamy EDFs 17 Feb 11, 2012 08:56 PM
Discussion f4 70mm kit terrorsound Hobby Express (Formerly Hobby Lobby) 0 Jul 08, 2009 06:31 PM
Discussion building, upgrades and/or mods questions for HL F/A-18 marcusg Foamy EDFs 7 Dec 29, 2007 05:22 PM
