DUP 6x10 and 6.25x11's on 32mm RFM spinner ( giving 5.5" and 5.75" diameters)
6x10 on this spinner is 5.5x9.16 6.25x11 on this spinner is 5.75x10.12 Scorpion 3026-1400 CC125 5 degrees timing in outrunner mode 5S 1800 65C turdigies Tested kV - 1428 6x10 DUP Folders - 25531 rpm (222mph pitch speed )1115W 56.77A 19.5V 6.25x11 Folders - 23255 (223mph pitch speed ![]() )1441W 77.6A 18.58V Freeky how the pitch speeds are the same ![]() Both spin smoothly, nicely balanced, sound good statically. Had some odd issues with the 6.25x11's. Rpm was fluctuating a little while moving throttle around. Dunno what that is, could be timing thing. Its possible the long motor wires are causing the esc a lil trouble. To give you an idea of the loads, APC sport prop comparison - http://www.rcgroups.com/forums/showp...93&postcount=2 The eagletree fits in the fuselage, so Ill add to this with inflight numbers |
| Thread Tools | |
| Discussion 4S 8" props vs 3S 10" props Performance & Flight Times | GuerillaFilm | Multirotor Talk | 12 | Sep 16, 2012 06:50 PM |
| Discussion Prop Balancer for High Performance | TheBlood+ | High Performance | 27 | Apr 04, 2012 03:58 PM |
| Sold NIB Aquacraft GrimRacer High Performance Prop L42x66 | sgil2001 | Boats (FS/W) | 2 | Jul 26, 2010 11:12 PM |
| Sold 2 Graupner CAM high performance props new in original packages -- $7 shipped for both | SPasierb | Aircraft - Electric - Power Systems (FS/W) | 2 | Jan 14, 2009 05:09 PM |
| For Sale High Performance Prodigy wing kits ,with or w/o motor/prop | sylair | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 20, 2008 01:44 PM |
