Old Oct 27, 2012, 07:12 PM
Tail Saw is offline
Find More Posts by Tail Saw
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Dynamic Soaring with a Horten possible?
Servus,
since a few years concerns me the question if dynamic soaring is possible with a Horten-wing. First I needed a model that is strong enough for the attempts. With my Aris Mini I was hoping to have a good design for for the planned tests, but the construction was so bad, that I was worried about the ability to fly
At last the bad plane flies and with small Flaplets it was possible to do some first tests for the distant goal
Here's the video at 2 Bft:
Soft-DS mit Horten Aris-Mini (2 min 27 sec)
Since this video, I'm waiting for more wind from the right direction.
The fastest speed in the video is about 70 km / h, what do you think is the maximum DS-speed with a wooden Horten-plane with carbon spars?
Continues.......
Regards,
Uwe.
Tail Saw is offline Find More Posts by Tail Saw
Old Oct 28, 2012, 05:55 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Thats a baaad plane!!!!!
Whats the plan,keep increasing speed until it folds?
Seriously,do you have a build log link?
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Oct 29, 2012, 02:27 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
HEy Uwe, nice place, do you have more details?' pics?? plans?? looks great in the air
Regards
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Oct 30, 2012, 06:40 PM
Tail Saw is offline
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
No, I think the first problem with too fast speed is flutter of a flap, and that flutter will decrease the speed. I had a fraction of a second flutter at a flap at the day of virgin flight. The height from the bungee was considerably lower, but no damage to the plane.
This ist the video of the first flights with bungee:
Horten Aris Mini, Erstflugtag (3 min 16 sec)
For more informations please wait till i had better conditions
Regards,
Uwe
Old Oct 31, 2012, 02:56 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Uwe,not enough resolution on iPad to detect any flutter,but I enjoyed the video nonetheless.
Have you made any modifications since this flight?
Regards Stuart
Old Dec 01, 2012, 05:50 AM
Tail Saw is offline
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Hi Stuart,
I had no flutter in this video, flutter was at an other flight without camera.
I'm still waiting for good conditions for DS
Here were the right conditions for one day, but because of a meeting the wrong place for DS.......much fun at the front side .......but with a stubid pilot error at the end of the video
Modifications since maiden: little higher Flaplets and CG a little bit back
Halbhorten "Aris-Mini" Hangflug bei 4-5 Bft (1 min 26 sec)
Regards,
Uwe.
Old Dec 01, 2012, 06:33 PM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
another way to eat the sky
Note that the Möve [click on thumbnail photo below] basically IS a Nurflügel .... but his wings have a different shape, incl. conical camber to utilize spanwise flow for both control AND stability in a much more aerodynamically efficient way that is actually OPPOSITE to the Horten, B-2, etc. It is VORTEX control !
If you could do that with a model the same size as yours it would fly a lot faster with more control and automatically head into green air [lift]. I know this for a FACT and after I discovered it have used this principle in a simple way in some of the mass-mkt toys I created.
Lee
[NOTE: this of course also works as a pure Nürflugel, but I cannot post that unproduced version]
R/C Pterosaur (1 min 6 sec)
TRU Pterodactyl (0 min 22 sec)
xlcrlee is offline Find More Posts by xlcrlee
Old Dec 02, 2012, 12:49 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Uwe,probably an iPad thing but I couldn't play the video.
Not to much damage I trust.
Regards Stuart.
Old Dec 02, 2012, 02:40 PM
Tail Saw is offline
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Hi Stuart, the only demage was to my ego
....but today it was a little bit faster at 2-3 Bft
Horten-Winter-DS bei 2-3 Bft mit Aris-Mini (1 min 41 sec)
Regards,
Uwe.
Old Dec 02, 2012, 03:12 PM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
There are some close up pictures of Uwe's model here
http://www.thermik-board.de/viewtopi...t=227&start=50
Very unusual - fins on the elevons.
HerkS is offline Find More Posts by HerkS
Old Dec 02, 2012, 04:11 PM
Tail Saw is offline
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Peter Wick named it "Flaplets"
The Aris-Mini is a nearly usual Horten with bell shaped lift distribution.
It flies with high measure of stability without winglets and with a little bit lower measure of stability with the Flaplets.
The side-surface of the Flaplets is mainly against the turbulence when slope soaring and DS.
The profiles from Peter Wick and Michael Selig are modified and adapted to the installation situation. The plane also flies well with 3 linear twisted trapezoids, ideal for foam building.
Regards,
Uwe.
Old Dec 02, 2012, 04:22 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Herks,thanks for the link.
Uwe,nice flying,love the roll!What your estimate of the speed?
Any chance you could give a brief outline of the thinking behind the tips.
Regards Stuart
Old Dec 20, 2012, 05:47 PM
Tail Saw is offline
a wing is enough
Tail Saw's Avatar
Germany
Joined Aug 2010
Hi Stuart, I have some more rolls for you, but I have a problem: I´m too slow at elevator:
Horten-DS bei 4 Bft mit Einschlag (0 min 58 sec)
I appreciate the fastes speed in the video was ~ 100 km/h / 60 mph, at this day perhaps ~120 km/h / 75 mph
I think the Aris-Mini will have 2 followers:
- I have foam cores for a new 2 m- plane, made by Norbert and I like to build a new glider out of the cores
- I develop a new 2,8 m-version for slope and DS for variable construction
I think I have shown that DS with a Horten-type flying wing is possible, now it is time for the next steps in Horten development, whatever that will be
Regards,
Uwe
Old Dec 21, 2012, 04:56 AM
ohmite is offline
Find More Posts by ohmite
ohmite's Avatar
Eden NY
Joined Sep 2001
Uwe,
Ouch!
Definitely answered your own question about DS, yes you can. Great speed. Looking forward to the follow-on planes.
Regards,
-Eric
ohmite is offline Find More Posts by ohmite
Old Dec 21, 2012, 05:01 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Ouch indeed! Touch of cold hands?
Stuart
Alert New dynamic soaring speed record!! Tappet Sailplane Talk 4 Mar 08, 2012 11:17 AM
Dynamic soaring with foamies Vector Foamies (Kits) 16 Mar 09, 2010 08:31 PM
Idea Urban dynamic soaring..... Possible? Magnum9 Australia 13 Oct 11, 2006 07:55 PM
Dynamic soaring with foamies Vector Electric Sailplanes 1 Feb 02, 2002 01:08 PM
