Old Dec 10, 2012, 10:12 AM
Renfield is offline
Find More Posts by Renfield
above us only sky
Renfield's Avatar
United States, SC, Greenville
Joined Jan 2006
Boating
Another tribute to my obsession, for your consideration.
Renfield is offline Find More Posts by Renfield
Old Dec 14, 2012, 11:32 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
Originally Posted by Firehawk989 View Post
Yea, it may not necessarily be epoxy, I just assumed it was because there was a tube labeled A and another one labeled B. The rest was in Chinese, so I didn't actually use the stuff.
Mine is clearly labeled "epoxy" in English on both tubes. Maybe it's a special EPO epoxy.
Old Dec 14, 2012, 03:52 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Yea, before hearing the "don't use epoxy on EPO" advice, I used some 5 minute epoxy to attach the tail and sponsons. Both of them seem to be held on very securely, and I don't hear any weird cracking/separating noises when I apply force to either part.
Also, last night I took some HD clear packing tape and covered the servo wire trenches and flap cutouts. I figured it's better to have the smoothest possible airflow on the underside of the wings to avoid the dreaded stall.
Firehawk989 is offline Find More Posts by Firehawk989
Old Dec 16, 2012, 05:50 PM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
It's worth a try with epoxy then. Maybe even foam safe CA? I'm all set to maiden this week, weather permitting. Mine lost some bits of gloss with the sticker removal. Still an improvement.
I'm considering not doing the flaps as well. Covering the gaps seems like a good idea. And I will smooth the leading edge. Though in general flight I've noticed no difference on the park zone model since sanding it.
This little one is a cutie. Can't wait!
Old Dec 16, 2012, 06:53 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
If you keep flying off of water they will get bigger and cost more lol joe
cracksmeup is offline Find More Posts by cracksmeup
Old Dec 17, 2012, 08:57 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
Trust me, if I could find a way to buy the full sized Icon I would. Karen has started a change jar for it.
The biggest foamie Icon with all the trimmings is already on order!!
And I haven't even maidened the little one yet.
Old Dec 17, 2012, 09:48 AM
cracksmeup's Avatar
Joined Jun 2009
I started fling small nitro stuff of of water 12 years ago and now building seaplanes from 84 inch wing spans and up . I attend around 14 waterfunflys a year and have alot of fun at them all. joe
Old Dec 17, 2012, 11:49 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
It's worth a try with epoxy then. Maybe even foam safe CA?.....
Actually, REGULAR CA works fine with most EPO type foams. Foam safe CA was formulated for EPS foam and actually does not work as well on EPO as regular CA does.
Epoxy does not work well on EPO parts that are shiny and unsanded. Tons of stories on line here about epoxy failures on EPO.
If you rough up the EPO parts with sandpaper, epoxy works fairly well.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 18, 2012, 10:15 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
I'll bet you don't get there driving my Miata! LOL. We're already going to need a bigger boat for the 72 inch Icon.
Old Dec 18, 2012, 10:41 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
Thanks, Thomas. For good or ill, the little one is assembled. Mostly in CA.
Regarding the HK small Icon:
I used the aileron linkages from my now retired PZ Icon, as the ones included are dreck. Brass couplings on aileron horns? Seriously?!? Prop holder is not the right size either. It will have to be drilled to fit the motor shaft. Alas, no drill press was included.
Crappy half baked stuff all around, really. It's making me nervous about the 72 inch model that's enroute from the same mfg.
So far, no flying, just hassles!
Old Dec 18, 2012, 11:15 AM
cracksmeup's Avatar
Joined Jun 2009
Naaa iam a die hard flyer and bought me a 2005 - 2500 express van to haul my planes with. I have 1/2 inch electrictcal pipes for racks with 1/2 round foam insulation wraped around them so i dont scuff anything up. I told you if you keep going this way its going to get exspensive . This comming year iam installing my new power converter so i can plug my 110 ac charger in for my lipos and the cost keeps going on and on. lol joe
Old Dec 21, 2012, 08:20 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
New kid on the block. All dressed up and no ESC.
Old Dec 31, 2012, 03:27 PM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
She's back! With fresh makeup.
Logos/text still to come.
Old Jan 07, 2013, 06:19 PM
Vancouver, BC
Joined Aug 2009
Add another addict to the list!
Icon A5 Maiden (0 min 0 sec)
Old Jan 29, 2013, 08:42 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
Winter waterland
I've been away from the lake a couple of weeks now for lack of water! Lake management drops lake level by about 4 feet every year for dock maintenance. But they weren't counting on a solid week of rain! So we were back to full pool last Wednesday. Now I have all week to fly from the dock until they can pass the flood downstream!
Got down here late yesterday and managed two flights with the PZ Icon, two with the little HK, and one with the carbon cub (which I always bring out when it's too dark to fly ).
What a fantastic plane! And the carbon cub on floats is not too shabby either.
Help! You know you are an RC Addict when... BulletMaster Australia 17 Sep 03, 2012 09:16 PM
Discussion Confessions of a heli-addict. And how to spot one. jasonjetski Micro Helis 24 Dec 26, 2008 05:34 PM
Discussion i am an addict i am an addict!!! deadstik3 Foamies (Scratchbuilt) 17 Dec 04, 2006 10:00 PM
Confessions of an overpowered brushless addict: BrunswickOH Parkflyers 15 Feb 19, 2004 04:07 PM
