Retirement time?
When is it time to hang up the foam? It's great that HH makes so many replacement parts available. But when do you just get a whole new bird?
Number One has multiple contusions/repairs to every piece of foam. Thomas B, I read where you sand the leading edge. Cracked me up!! It's amazing that mine still flew. Once, I hit mid-wing on my neighbors dock lamp post. A honking treated, braced 2x6. It left quite an impression! ![]() Yet I've put so many packs through her since May. This last crash was totally my bad. Tried again to keep the wingtip in the water on takeoff. Beautiful, until I overcorrected. As I came alongside her in the boat, the landing/nav lights were flickering, like the Titanic. So sad.I can fix the foam. Again. Motor may be shot. Interior was totally flooded for about 90 seconds, with a fresh pack. After a thorough dry-out ESC was glowing/smoking when I plugged it up. HH shows the original as discontinued. That would be $100 just in electronics for an aging trainer, assuming the receiver and servo survived. So is she an ornament now? Just a crate of spare parts? If the original ESC is discontinued, when will PNP/BNF boxes have the new goods? Wait until Spring? So glad I have a spare.
Dings have less effect, as long as they are more or less evenly distributed on both sides of the wing. I find that a lot of beginners do not see the issues with the aircraft when the wing is compromised and simply do not know how poorly the model is actually flying. They simply assume the model is supposed to drop a wing hard near the stall and that it is normal for the model to stall at higher speed than it should. Try putting a knife slit in your wing LE on one side and the insert a thin card stock strip that sits a little proud of the airfoil at the very front. Take the model up and approach a stall .. could even just use tape.
Hey all,
See my post in the ICON thread on the ESC. New one will be available shortly. http://www.rcgroups.com/forums/showp...postcount=1454 Hope that helps. Matt Andren Parkzone/Hobbyzone Product Development Horizon Hobby |
And my LHS is a kmp distributor, so they're getting a couple of the big ones in. The writing is on the wall... ![]() I just don't know where I can fly from land to water. Yet. |
Vancouver, BC
Joined Aug 2009
Also removed the terrible stickers and went to town with a Sharpie: ![]() ![]() ![]()
The two left float kit probably has a mirror twin version out there somewhere with two right floats, but it is a very rare occurrence, not something that happens regularly.
I never use two part epoxy on EPO type foam. Unless carefully prepped by sanding and the cleaned with alcohol, epoxy adheres poorly...and even then, not as well as the Uhu type contact adhesives. |
Vancouver, BC
Joined Aug 2009
I sanded the wing LE on your advice, but I was wondering about the servo wire channels; would those open slots in the wing also contribute to causing a stall? If so, I'll cover them (and the flap slots) with tape. |
Also, Thomas does your large Icon have pre-set nav lighting locations? It kind of looked that way in close up. I'd like to outfit it with the entire scale lighting. |
| Thread Tools | |
| Help! You know you are an RC Addict when... | BulletMaster | Australia | 17 | Sep 03, 2012 09:16 PM |
| Discussion Confessions of a heli-addict. And how to spot one. | jasonjetski | Micro Helis | 24 | Dec 26, 2008 05:34 PM |
| Discussion i am an addict i am an addict!!! | deadstik3 | Foamies (Scratchbuilt) | 17 | Dec 04, 2006 10:00 PM |
| Confessions of an overpowered brushless addict: | BrunswickOH | Parkflyers | 15 | Feb 19, 2004 04:07 PM |
