Espritmodel.com Heli Air
Old Oct 27, 2012, 06:09 PM
Fly long, Life is Hard
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
12x tip aileron question
Hi Guys,
I have a friend who has a sailplane set up with a 12X and he has the tip aileron function selected.
Problems is, the aileron trim does not trim the tip aileron. I have looked all through the menu's, I have asked Horizon and nobody can tell me why. I find it hard to believe this has not been talked about before. Are we missing something?
Thanks guys
LEN
www.RcAerotowing.com
Lbuff1 is offline Find More Posts by Lbuff1
Old Oct 28, 2012, 11:43 AM
R.M. Gellart's Avatar
Joined Nov 2005
Ask Tom Kallevang, he is the only guy I know that has messed with it since 99.9% of J/B models do not have a third section on a TE. I used a 12X for a while and never even knew it had the option.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 28, 2012, 11:50 AM
Billymac's Avatar
Albq, NM
Joined Sep 2005
Len,
Have you gone to the balance function to tie the 2 servos together?
Or you can try this
See attached
All the best
Bill
Billymac is offline Find More Posts by Billymac
Old Oct 28, 2012, 01:16 PM
Lincoln, NE
Joined May 2005
The attached PDF file is for ACRO and not GLID programming. If we are speaking of the GLID mode, the normal tip action acts as if there were a hidden program mix of AILE -> TIPA. This mix will tie the tip movement to the aileron movements except it excludes the trim. So what can be done is to set up two program mixes.
The first mix of AILE -> TIPA using -100% POS0 rates will neutralize the internal mix that is causing the problem. A second mix of AIL+ -> TIPA will tie the tip moment to the main aileron movement and also include the main aileron's trim.
If one only needs separate tip aileron trim, this can easily be set up by mixing an unused aux channel into the tip.
Allan
AWorrest is online now Find More Posts by AWorrest
Old Oct 28, 2012, 09:23 PM
so. cal.
Joined Jan 2006
Larry Jolly knows how to fix this, because he helped set up the program for my ASH-31, I'll let him know he needs to chime in here. I can easily adjust the outer ailerons on my 31, I also use the samerogram on my Lunak since it also has a triple trailing edge.
s2000 is offline Find More Posts by s2000
Discussion To Aileron, Or Not to Aileron?...that is the question. DocMac Electric Sailplanes 28 Oct 16, 2012 11:01 PM
Discussion Tips for preventing Hangar Rash on foamy EDFs- and FG questions bsbauman Foamy EDFs 3 Aug 08, 2012 12:53 AM
Discussion influence of aileron gap on tip stall phil alvirez Modeling Science 30 May 20, 2012 06:24 AM
Discussion Quick question: GCP servo aileron/elevator andrewho83 Micro Helis 2 Mar 08, 2012 12:34 PM
Question JR 12X Aileron to Flap Mix bitzerj Sailplane Talk 3 Jul 13, 2010 03:55 PM
