Old Oct 27, 2012, 05:22 PM
Ibragim is offline
Find More Posts by Ibragim
Joined Oct 2012
AutoCad Printing
Hello,
I want to know how to Print a file in AutoCad, like 1 piece each paper to complete the whole file. Like a Puzzle. I am using AutoCad 2013. Please help me.
Ibragim is offline Find More Posts by Ibragim
Old Oct 28, 2012, 10:36 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Sounds like you want to do tiled printing, which is done with PDF files. One way to do what you want is to get a PDF printing program like CutePDF or the like. Then you'll print your AutoCAD file to a PDF, followed by printing the PDF file in tiles.
potshot is offline Find More Posts by potshot
Old Oct 29, 2012, 02:19 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
acad
try autocad design review it will scale and tile print
dpot is offline Find More Posts by dpot
Old Nov 02, 2012, 06:37 PM
starcad is offline
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
Not sure what you mean there dpot. I use the PDF method converting the drawing to a pdf with Adobe distiller.
starcad is offline Find More Posts by starcad
Old Nov 03, 2012, 05:07 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
autocad tile print
as he is using auto cad if he save as dwf or just open it in design review as a dwg or dxf he can print it from there using tile print with no conversion to pdf or lost of detail
it is good as well for shearing drawings you can password protect then and no changes can be made to the original drawing.
but sum pdf conversions can be Chang back to dwg giving full axis to your drawing.
Old Nov 04, 2012, 04:46 PM
starcad is offline
AMA 667982 KG7NKY
starcad's Avatar
Joined Sep 2000
Thanks, Very interesting. And I thought I knew AutoCad.
Old Nov 05, 2012, 11:47 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
no problem if you look on your install disk of autodisk or your download folder you should have autodisk design review on it if not go to autodisk website and download it i think it is free to acad users.
Old Nov 07, 2012, 08:56 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Here's the direct link...
http://usa.autodesk.com/design-review/
Hemikiller is offline Find More Posts by Hemikiller
Old Dec 02, 2012, 10:02 PM
Batmanwpg is online now
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
You can print directly off your drawing by simply making a box on the defpoints layer. (shown as the white box) Lets assume you are printing letter size paper which is 81/2"x11". The printer uses a 1/2" margin all around so make your box 71/2"x10". Move the box over the area which is to be printed. Select "Print" from the menu. From the CAD print window pick "Window" then select the Defpoints box using object snap settings. This will print the area in that box at full scale. The box being on the Defpoints layer does not print. This works very well for printing small parts or you can add pages together for a larger print.
Batmanwpg is online now Find More Posts by Batmanwpg
Build Log Design Print Fly - 3D Printed Organic Design Mid7night Scratchbuilt Indoor and Micro Models 72 Mar 24, 2013 08:20 PM
Discussion Autocad plans shawn pierce Scale Kit/Scratch Built 4 Apr 19, 2012 02:26 PM
Question how to print a dwg/dxf file from an autocad drawing krisch Hand Launch 4 Dec 07, 2009 05:39 AM
Printing with autocad sarebro Electric Plane Talk 18 Oct 13, 2006 03:28 PM
