Old Oct 27, 2012, 05:12 PM
padge993 is offline
Find More Posts by padge993
Joined Nov 2010
MJX F45 not binding
hello there I have just received my MJX F45
I cannot seem to bind the transmitter to the helicopter. I have followed the instruction manual but does not seem to work. I plug the battery into the chopper then turn the transmitter on then I slide the throttle stick to full position then back down then the red light stays solid but the chopper does not respond??
Any ideas what I am doing wrong or is this a dud chopper?
padge993 is offline Find More Posts by padge993
Old Oct 27, 2012, 09:44 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Try this:
1. Make sure the outermost sliders on the tx left and right are fully down
2. Make sure the throttle stick is at the bottom
3. Turn on the tx
4. Plug in the battery and set the heli down level
5. Push the tx throttle stick to max and back to min
6. Move the right stick to check for servo movement
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Oct 28, 2012, 01:11 AM
padge993 is offline
Joined Nov 2010
Originally Posted by gordonzo View Post
Try this:
3. Turn on the tx
regards . . . g
Thanks for your reply. Yes i have done all what you have said with no luck.
The servos do not move only time they slightly move is when the power plug is inserted.
Old Nov 07, 2012, 11:50 PM
saintpipo is offline
Find More Posts by saintpipo
Joined Feb 2012
I found if Aileron/Elevator Stick little not center, it will make can't bind. Problem from some Aileron/Elevator spring weak. You should release stick adjust mode of the throttle side and check . If it can easy move to center all direction all time and stable. Then you exchange left and right stick side by turn out 3 screw at the each front side TX. and carefully inner VR plug inside TX change also.
saintpipo is offline Find More Posts by saintpipo
Old Nov 24, 2012, 04:21 PM
padge993 is offline
Joined Nov 2010
Okay so i ordered a new circuit board hoping to solve my binding problem.
Now when i bind the chopper throttle up and down i get a long..... beep that does not stop. Any ideas what my problem is???
MJX F45 Not binding (0 min 13 sec)
Old Nov 29, 2012, 11:34 AM
valere is offline
Find More Posts by valere
Belgium
Joined Nov 2012
hello
I have the same problem with my mjx F45 ..."The servos do not move only time they slightly move is when the power plug is inserted."
Have you found a solution or do you have any idea what 's going wrong ?
valere is offline Find More Posts by valere
Old Dec 16, 2012, 10:34 AM
blayen is offline
Find More Posts by blayen
Czech Republic, Liberec Region, Liberec
Joined Dec 2012
Hi there guys.
I have the similar problem with my f45. Only exception is i don't get any reaction from the copter at all.. When i plug the battery in (fully charged) nothing happens, not even the led light. I measured that the power gets from the battery to the pcb but no juice gets to the diode nor to the motor or servos. Could it be faulty electronics?
Edit: Problem solved, it was in fact manufacturing defect - poorly soldered black cable from battery to pcb. Although it is "fixed" in position by hot glue, mine was a little loose so the copter was out of power. Fixed it again and i'm back in bussines. :-)
blayen is offline Find More Posts by blayen
Old Feb 10, 2013, 09:00 AM
elegance is offline
Find More Posts by elegance
Canada, ON, Toronto
Joined Dec 2012
Hi there, just wondering if you found remedy for transmitter mine is doing the same thing also. wont bind long beep and red light stay on
elegance is offline Find More Posts by elegance
Old May 08, 2013, 11:01 AM
TheLitch is offline
Find More Posts by TheLitch
Joined May 2013
Any news regarding this?
Did it help with a new CB ?
My copter does have power for the "spotlight" and the servo makes a short move when putting the power plug in. But other then that its dead
TheLitch is offline Find More Posts by TheLitch
Old Jun 20, 2013, 08:27 PM
DiegoVieira is offline
Find More Posts by DiegoVieira
Joined Jun 2013
Similar issue, except that the servos respond, but it won't take off.
MJX F45 won't take off (0 min 0 sec)
DiegoVieira is offline Find More Posts by DiegoVieira
Old Jun 27, 2013, 07:11 PM
BMF625 is offline
Find More Posts by BMF625
Joined Jun 2013
I am having similar issues. The TX seems to connect with the helicopter and I am able to actuate servos, but I have no response on either rotor.
Any ideas????
BMF625 is offline Find More Posts by BMF625
Old Jul 14, 2013, 02:21 PM
rontech420 is offline
Find More Posts by rontech420
no borken corters allowed here
United States, CA, El Cajon
Joined Jul 2013
I have the exact same problem with mine and it's brand new out of the box. I plug batt into helo, servos move a little but other than that, nuthin. Seems that replacing pcb is hit or miss. This looks like a well made helo but the electronics are garbage.
rontech420 is offline Find More Posts by rontech420
Old Oct 20, 2013, 08:35 PM
probd350 is offline
Find More Posts by probd350
Joined Oct 2013
Mjx f45 will not fly side to side
Hello, needed to ask if anyone knew why my mjx F45 will not fly side to side??Can it be fixed or does a part need to be replaced? Any help will be great..I am new to this 4 channel Heli also..
probd350 is offline Find More Posts by probd350
Old Oct 26, 2013, 03:41 PM
zidder is offline
Find More Posts by zidder
Joined Oct 2013
You need to set to Mode 4
zidder is offline Find More Posts by zidder
Old Aug 29, 2014, 08:55 PM
Dupage is offline
Find More Posts by Dupage
Joined Aug 2014
I have this same issue. Anyone found a solution?
Dupage is offline Find More Posts by Dupage
Discussion MJX-F45 Single Rotor FP gordonzo Micro Helis 11515 Sep 10, 2016 05:28 PM
Sold Mjx f45 .quietguy Aircraft - Electric - Helis (FS/W) 0 Jun 28, 2012 12:15 PM
Discussion need some advice on buying the MJX-F45 or the G.Tec 9019 alcatres Large Electric Helis 7 May 27, 2012 12:13 PM
Question Solo pro 100 or MJX f45? TonganSojah Micro Helis 6 Apr 30, 2012 04:25 PM
