Old Nov 04, 2012, 06:32 AM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Howdy there Turk I know you'll be 1st inline to get one so keep us up to date .Be nice to be 1/2 as rich as you so I could get as many engines as you . Cheers the pope
the pope is offline Find More Posts by the pope
Reply With Quote  (Disabled)
Old Nov 04, 2012, 03:20 PM
The PIPE is online now
Find More Posts by The PIPE
The PIPE's Avatar
USA, MA, Weymouth
Joined Mar 2004
Another quick one...the first Saito FG-40 video I've found...!!
Dear Fellow Four-Stroke GASSER Mill Lovers:
The PIPE Here once again, very quickly, with what I think is the very first video of a Saito FG-40 mill in an aircraft (ground run only)...
SAITO FG-40 Starting up (1 min 11 sec)
...I'd bet that the new OS 40 cm3 gasser mill should run at least as well!!
Yours Sincerely,
The PIPE....!!
The PIPE is online now Find More Posts by The PIPE
Old Nov 09, 2012, 04:53 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Hi ANZAC,I am waiting for a dude to dare to give it a try.(I always believe in childhood problems of a new product)
http://www.himodel.com/engines/NGH_G...ol_Engine.html
turk1 is offline Find More Posts by turk1
Old Nov 09, 2012, 05:15 AM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
That's a low oil content. ... 3%
Does this new engine have "proper" bearings on its connecting rod?
bogbeagle is offline Find More Posts by bogbeagle
Old Nov 09, 2012, 05:29 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
It should be needle bearings on both end.
Old Nov 09, 2012, 10:56 PM
the pope is offline
Joined Sep 2007
Hi there Turk I would love this engine to be a good runner out of the box . This is more than affordable like the 9cc . They just need to bloody run well ! I know Im probably asking too much but here's hopeing. I would be the 1st to give it the thumbs up. I wonder if this engine will be easier to turn it into a winner than the 9cc . I guess if its an off the shelf carb suited to the size of the engine it maybe ok .Cheers and good luck from the pope
Old Feb 01, 2013, 09:53 PM
3D EXTRA is offline
Find More Posts by 3D EXTRA
3D EXTRA's Avatar
Joined Feb 2005
http://budgethobbies.com.au/store/ta...4/default.aspx
OS GF40 GASOLINE FOUR STROKE ENGINE W/F-6040 SILEN
Manufacturer: O S
Model Number: 39400
Price: $669.95
DUE EARLY JAN OUTPUT 39.96CC 1,800-9000 RPM MOTOR 1200 gms IGNITION MODULE 113.0 gms MUIFFLER 95.0 gms PROP/REVS 18X6W 8,800 18X10 7,950 18X12 7,600 20X8 6,750
http://www.youtube.com/watch?feature...&v=rDyJy_N1xi0
3D EXTRA is offline Find More Posts by 3D EXTRA
Old Feb 01, 2013, 11:15 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Really sounds nice!
Kmot is offline Find More Posts by Kmot
Old Mar 19, 2013, 04:22 PM
akouzmit is offline
Find More Posts by akouzmit
Joined Jun 2007
Manufacturer: O S
Model Number: 39400
Price: $669.95
Last weekend I was testing my SAITO FG-36 with Xoar 18x8, 19x8 and APS 18x6W with the next Static thrust results:
(Electronic Fish Scale is very sensitive to elastic rope plane was strapped to. Min/Max measurements for full throttle shown.)
Xoar-19x8 => RPM~6900 => 6.5-6.7kG
Xoar-18x8 => RPM~7500 => 6.3-6.5kG
APC-18x6W => RPM~8200 => 6.7-6.9kG
Look like I will stay with APC-18x6W for my 6.3kG 2+m wingspan RV-8 from SlipStream.
I also did measurement on my other plane with SAITO FG-21 with 16x8 Pattern prop and found out that static thrust is well above my expectations: 5.5-5.9kG
For 4.3kG plane it is awesome static thrust! Should fly like a rocket :-).
My friend at the field is also tested his SlipStream RV-8 with DLE-35R and with Xoar 18x10 he easily got 8.0+kG static thrust (Sorry, I didn't check RPM at that time).
OS GF40 looks so tempting to me as a replacement in my SlipStream RV-8.
My current setup is a bit too heavy 6.3kG +fuel+smoke oil . . . I wish to drop 0.3-0.4kG with OS GF40 and at the same time to gain ~10% more power.
Andrei.
akouzmit is offline Find More Posts by akouzmit
Old Apr 03, 2013, 09:29 PM
akouzmit is offline
Joined Jun 2007
Originally Posted by Kmot View Post
Really sounds nice!
OS GF40 is now available for pre-order from Tower Hobbies.
Hurry Up :-)
Link: http://www3.towerhobbies.com/cgi-bin...?&I=LNCZLF&P=G
Old Apr 03, 2013, 10:21 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think the big detractor on the NGH big gasser is that it does not have a muffler and the short exhaust pipe is too thin to put anything else on it. It is surprising they never took that into consideration with everyone having to reduce engine noise nowadays.
earlwb is offline Find More Posts by earlwb
Old Apr 04, 2013, 10:22 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The biggest detractor of the NGH is questionable engineering, manufacturing, and product support. Saito had issues and stood behind them. I think OS took this long to work out the issues prior to release.
Greg
gkamysz is offline Find More Posts by gkamysz
Old May 01, 2013, 09:10 AM
yser is offline
Find More Posts by yser
Joined Apr 2011
Originally Posted by gkamysz View Post
Finally. http://www.os-engines.co.jp/news/webdir/25.html
I'm going to guess the price will be 799 at Tower.
Greg
You are an excellent guesser
yser is offline Find More Posts by yser
Old May 01, 2013, 09:35 AM
yser is offline
Joined Apr 2011
Never heard of this Chinese manufacturer but their engines look like good quality judging by pictures of the fit/finish of their engine's exterior and internal components. This particular engine appears significantly underpowered based on data. Here are videos of this engine on the Chinese equivalent of youtube,
http://v.youku.com/v_show/id_XNDI4NDEzNDA4.html
It is less than half the price of comparable Japanese made engines. For me, I keep my engines forever and want them to last almost as long. There is a feel good factor and peace of mind by buying Japanese quality engines. And there is also the cool-factor of Japanese made engines because they are beautiful to look at and don't have the Chinese generic communist styling. For these reasons, Japanese engines are well worth the extra money. If Thunder Tiger produces a similar 4-cycle gas engine, then that it is worth serious consideration.
Old May 01, 2013, 09:53 AM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
The O.S. GF40 is now in stock in North America.
Steve
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Sold New In The Box OS Max 40 Four Stroke Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 05, 2012 10:11 PM
Sold New In The Box OS Max 40 Four Stroke Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 05, 2012 08:29 PM
Sold New In The OS 120 GEMINI 120 Twin Cylinder Four Stroke R/C Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 05, 2012 09:47 AM
Sold OS 90 Rear Rocker Four Stroke Engine/New in open box. flyinjrc74 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Aug 18, 2012 08:55 AM
Off Site Four Stroke OS FS-40 CX buggy/car/truck engine Kmot Cars - Cars and Parts (FS/W) 0 Feb 17, 2012 03:11 PM
