Old Dec 11, 2012, 04:24 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
You may want to run a static port for your carb. More than likely there is going to be a large pressure build up in the cowl.
kerwin50 is offline Find More Posts by kerwin50
Old Dec 31, 2012, 06:04 AM
MrRcAddict is offline
Find More Posts by MrRcAddict
Joined Apr 2011
Excuse my ignorance Kerwin, but I'm not familiar with static ports. Could you explain a little more about that? I have the plane completed now but have yet to update the thread. I'm just wondering if this is something for me to be concerned about?
MrRcAddict is offline Find More Posts by MrRcAddict
Old Dec 31, 2012, 09:01 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
There's a hole in your carb cover that keeps the diaphram atomspheric pressure. When you have a cowl that builds up pressure, it changes the mixture, and in lots of cases creates a dead stick.
What people do is solder a tube in the carb cover. The run fuel tubing from the cover to a flat spot on the outside of the fuse. Behind the landing gear is the best,
Other people have ran the tubing to a film canister with a small hole in it, placing it in the fuse as well.
I've done both and the static port works the best.
But now days with my 3D flying I just open the bottom of the cowl for the necessary cooling.
The rule for normal cooling is 3 times the incoming air opening.
These motor can really get hot in a hover.
Old Jan 02, 2013, 12:22 AM
Nicky2times is offline
Find More Posts by Nicky2times
Nicky2times's Avatar
United States, NC, Smithfield
Joined Jul 2011
On my sbach i used a pitts style muffler and what i ended up doing was cutting a hole like 2 1/2" wide and 3"long for the muffler to stick out and also so i could get the cowl on and off easier. This also created a big enough outlet to get air out. Another cleaner way to make the exit holes with your set up would be to use a dremel with the small drum sander and cut some vents in the bottom like for instance 1/2 x 1 1/2" slots, 3 in a row just like an air vent in a house. This allows for proper air exit and looks clean.
Nicky2times is offline Find More Posts by Nicky2times
Old Jan 31, 2013, 06:31 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
How's this build coming along?
I think these are the most beautiful Sbach models available. Nice to see the new scheme on something a little bigger than the UMX. Can't wait to see more.
SD One. is offline Find More Posts by SD One.
Old Feb 12, 2013, 04:56 AM
Joined Apr 2011
I have some vents cut in the cowl that you can sort of see in one of the last pics. I probably need more though. I didn't realize that's what you were talking about.
Old Feb 12, 2013, 05:04 AM
Joined Apr 2011
Some final touches
Old Mar 05, 2013, 04:40 PM
saios is offline
Find More Posts by saios
United States, AR, Jacksonville
Joined Apr 2012
What prop are you using?
saios is offline Find More Posts by saios
Old Mar 05, 2013, 06:58 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Your build looks so good. I can't wait to hear about your maiden
Old Jul 12, 2013, 05:05 AM
foamedflyer is offline
Find More Posts by foamedflyer
Australia, SA, Goolwa
Joined May 2013
Originally Posted by MrRcAddict View Post
Horizontal stab install
These pics have helped me out heaps with my build thanks mate
foamedflyer is offline Find More Posts by foamedflyer
Old Jul 12, 2013, 09:15 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I would change that quick link on that throttle. gassers don't fair while with the quick links.
Old Mar 03, 2014, 07:51 PM
turboflier is offline
Find More Posts by turboflier
Joined Feb 2014
How is this bird holding up?
turboflier is offline Find More Posts by turboflier
Old Mar 03, 2014, 10:10 PM
ant1 is offline
Find More Posts by ant1
United States, RI, Providence
Joined Sep 2009
My Redwing Sbach is going into it's 3rd season and 150+ flights with no sign of fatigue anywhere. Really a nice plane
ant1 is offline Find More Posts by ant1
Old Mar 04, 2014, 10:46 PM
Joined Feb 2014
Great to hear!!
Build Log Pilot RC Sbach 342 30cc build thread jhasrac1 3D / Fun Fly Fuel Planes 335 Jun 23, 2016 12:55 PM
Discussion Gold Wing RC SBACH-342 V3 30CC / 73" / 26% eJets Giant Electric Planes 26 Nov 26, 2011 12:43 PM
New Product Pilot RC's SBach 342 30cc!! FlattyFlier Scale Fuel Planes 28 Dec 29, 2010 08:28 PM
Discussion New SBach 342 and MX2 - by Redwing RC Redwing RC 3D Flying 27 Sep 02, 2010 05:25 PM
