Old Nov 02, 2012, 04:15 PM
jsipprell is offline
Find More Posts by jsipprell
Joined Jul 2011
Originally Posted by Elios000 View Post
would seems in theory the best system would use 2 or 3 channels at the same time and leap frog them
ie one channel hops then the other with them hoping all the time
kind of a hybrid DSMX/FASST system with the hopping of FASST and the multichannel of DSMX
DSMX "hops" just like FASST. (Like as in "the same general fashion", not as in "the same dwell and hop timings")
jsipprell is offline Find More Posts by jsipprell
Old Nov 02, 2012, 04:33 PM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
DSMX only hops as needed
think dwell and hop but with 3 channels with only one channel hopping at a time
Elios000 is offline Find More Posts by Elios000
Old Nov 02, 2012, 04:42 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
You may care to clarify that .
It sounds like you mean only 3 channels are involved
richard hanson is offline Find More Posts by richard hanson
Old Nov 02, 2012, 04:54 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I am not exactly sure what you mean by that, but...
Think it through... what would be the advantage of that? Is it actually any different from what FASST does?
And... DSMX hops all the time from what I understand. It doesn't do like some systems and stick on one channel until there's an issue with that channel - it actually can't do that because there's no back-channel to tell the transmitter what is happening out at the receiver.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 02, 2012, 05:01 PM
Joined Oct 2007
You do know that DSMX has various hopping arrangements which are peculiar to a specific tx.
each DSMX tx has a GUID which is it's own and utilizes 23 channels.
I don't know how many different GUID sequences (tx) are used
Old Nov 02, 2012, 05:04 PM
Joined Jul 2011
No, DSMX hops constantly. You can actually prove this by forcing a Spektrum transmitter into DSMX mode (after binding a receiver in DSM2 mode) and noting how you'll have brief moments of "jittery" control whenever the transmitter happens to hop on to one of the two DSM2 frequencies.
Old Nov 02, 2012, 05:07 PM
Rocket Programmer
Joined Jul 2007
I don't remember how many patterns are used - someone must have that number --
Yes, but they should be relatively equal in terms of time spent on each frequency, from one TX to the other. I am still not clear on what Spek means by "Smart" hopping or "adaptive" or whatever they call it... but I'm pretty sure it's not adapting to anything happening at the receiver.
That is - if there's 30 channels, I would expect that ALL transmitters spend 1/30th of their time equally on each of those channels, regardless of differences in the pattern. Like, how many different ways can you write the numbers from 1 to 30 in different order, while only using each number once... 30-factorial? I don't know, but it's a lot.... and they all use each channel one time in the pattern. So, I don't think there should be any difference between one transmitter and the next.
Old Nov 02, 2012, 05:08 PM
Joined Jul 2011
I presumed it was pseudo-random based on a seed of the model's (ModelMatch) uuid or something similar, but I have no real data to back that up.
Old Nov 02, 2012, 05:11 PM
Joined Jul 2011
I think they mean "adaptive" in the same way Hitec means it; analyze the environment at bind time and avoid congested areas of the band but once everything is up and running the channels in use don't change. (Hitec actually requires you to activate a special "mode" for this).
Old Nov 02, 2012, 05:13 PM
Joined Oct 2007
I looked it up It is probably like the old GM key sequences - there were a bunch of em but not an infinite bunch
eventually the same key would open another car
In this case tho - -there would have to be an "impossible" condition of two identical GUID tx operating at exactly the the same instant in time.
Old Nov 02, 2012, 05:20 PM
Joined Jul 2011
A random number between 1 and 2.65*10^32 would give you a unique pattern of 30 channels.
Old Nov 02, 2012, 05:23 PM
Joined Jul 2011
guids are typically implemented as a uuid (universally unique identifier); a 128-bit number between 0 and 5.310^36; so the chances of a collision are practically nil even if every person on earth was given a radio.
(They take the format "21CF2350-3AFC-1F69-B5E3-08222C96418D", and if you look around at various technologies you'll likely recognize that format all over the place)
Old Nov 02, 2012, 05:26 PM
Joined Oct 2007
Ah wuzzunt worried --
Old Nov 02, 2012, 05:31 PM
Rocket Programmer
Joined Jul 2007
GUIDs SUCK! I hate them
A database I work with, for some reason, uses GUIDs as surrogate keys. I basically said "until you change that, I'm not making any performance guarantees"
Old Nov 02, 2012, 05:37 PM
Joined Jul 2011
I have to confess to having used/generated UUIDs on occasion, but not for table indices.
They are particularly useful as a pseudo-random seed, if you generate them from a high entropy (really random) source and save/share them you can reliably reproduce an infinite set of "random" numbers that is always the same sequence.
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 10:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 09:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 04:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 08:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 09:42 PM
