Old Oct 30, 2012, 08:23 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Aye. And we can generally count that wi-fi devices are being used facing a certain direction (right-side-up), and WiFi routers don't have big space or power limitations. We can't count as much with our planes.
acetech09 is offline Find More Posts by acetech09
Old Oct 30, 2012, 08:27 PM
Elios000 is offline
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
wi-fi has very tight power limits at lest on phones and laptops
and i dont think what why up the model is means much at lest with Spektrums sat style setup
Elios000 is offline Find More Posts by Elios000
Old Oct 30, 2012, 08:46 PM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Originally Posted by MattyB View Post
I suspect that is highly unlikely as 5.8 has only half the penetration of 2.4, so range will be reduced and it will be even more important to do a very careful install without masking the aerials. Not a receipe for a successful consumer product!
Originally Posted by Elios000 View Post
wi-fi is moving to it
Maybe so, but wifi routers only need very short range (a few tens of metres max for consumer products) compared to our RC aircraft which need hundreds of metres minimum for anything but a small parkflyer. Plus the implications of losing connectivity to your router are somewhat less dire than losing control of you latest RC masterpiece...
MattyB is online now Find More Posts by MattyB
Old Oct 30, 2012, 08:52 PM
acetech09's Avatar
Joined Apr 2012
Those are wi-fi receivers. WiFi transmitters don't have nearly the stringent requirements. Yeah, they do have hotspots now, but see how much range you get with one of those.
Old Oct 30, 2012, 08:54 PM
Elios000 is offline
Joined Jul 2010
range is mostly based on power out put a 200mW RC TX is going to go a lot farther then 5mW wi-fi router
also you can get some FPV systems that use 5.8 already and they do fine out to a few miles
Old Oct 30, 2012, 08:55 PM
Elios000 is offline
Joined Jul 2010
laptop and cell phone have to transmit as well wi-fi has to have a TX and RX in both ends
so really your power reqs are much much tighter with a say a cell phone that needs to TX and RX + run the phone on effectively a 2S lipo
Old Oct 30, 2012, 09:02 PM
acetech09's Avatar
Joined Apr 2012
Yes, they do transmit as well. I was talking about the function of the device. Effective power on receiving devices, as far as I know, is much less than most Wi-fi transmitters. Ever wondered why your cell phone isn't picking up the wi-fi signal that your laptop is, and your laptop isn't picking up the signal that your desktop's wifi card is? Routers have to be able to cope with the biggest devices, while receiving devices have to only cope with themselves.
Our cellphones run off of 1S Li-Ions mostly, these days, and only have to broadcast much shorter range signals than our RC uses.
Old Oct 30, 2012, 10:02 PM
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
  1. In the UK we are limited to 100mw of power for 2.4GHz TXs (http://www.ukrcc.org/35mhz.html);
  2. As far as I can tell any 5.8GHz transmitter over 25mw requires an amateur radio licence in the UK - a major issue since you need much more power to get the same range for 5.8GHz according to this: http://www.fpvuk.org/things-explaine...wer-and-range/
Based on that I can't see the RC manufacturers coming up with 5.8GHz TXs anytime soon; they wouldn't be a legal, marketable consumer product here and I suspect many other markets are similar.
Old Oct 31, 2012, 06:15 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
900 MHZ may be the best solution.
RC Man is online now Find More Posts by RC Man
Old Oct 31, 2012, 08:56 AM
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Sadly not over here - 900MHz is used exclusively for 3G mobile phones. TBH I don't believe there is actually a problem to be solved at this point though; in the real world a well installed, well powered full hopping 2.4 system seems to be as near to bullet proof as you can get, at least here in the UK. If further congestion of the 2.4 band were to occur that may not hold true forever, but for now I feel 100% confident in using the band.
Old Oct 31, 2012, 03:40 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
+1000
It doesn't matter what frequency we fly on, some people will crash their planes and blame it on "interference" or "brown-out" or "jamming" or even "triple triple secret agencies"... It's always been that way and always will be. Admitting we screwed up and crashed our plane and it was all our fault is really hard sometimes.
for example.. I'm teaching a flying buddy to fly. Twice this weekend gone I had to save the plane when "the radio stopped responding".. Soon at I touched the Tx it mysteriously started working fine Truth was he just got too slow and was flying on the verge of a stall and so the plane didn't respond to aileron input.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Oct 31, 2012, 04:47 PM
Elios000 is offline
Joined Jul 2010
you know you could do DSMX on 72Mhz if you wanted to really
2.4 is nice because you dont need big long antennas
other then the antenna issue i wonder why they didnt do spread spectrum on the 72Mhz band? i guess it could cause issues with the older stuff
Old Oct 31, 2012, 04:58 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I don't think you can send enough data fast enough. You could with PWM, basically analog... but with digital signals I don't think it's fast enough to include all the data AND spread it.
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 31, 2012, 10:47 PM
Warningshot is offline
Find More Posts by Warningshot
Freedom Isn't Free
Warningshot's Avatar
SE Okla
Joined Mar 2006
Originally Posted by gwinhh View Post
Hate to sound like an Old Phart, but in the '80's, we had 6 frequencies (there were a couple
reserved for licensed Ham radio guys), lots of interferance, and only 2 or 3 folks (depending on frequency) could fly at one time (cross-channel interferance).
We have come a long way and AMA deserves a lot of credit for getting us the 72 band and lately the 2.4 frequencies. Whatever the problems in the current situation, it's not as bad as it was, and IT IS UP TO US to live with the situation. AMA is making sure we aren't screwed or forgotten in the RPV field.
I think my point is that we owe AMA a lot and this is a reminder of just how much.
howell
AMA had nothing to do with getting 2.4.. All they did was bless it. The radio makers did it on their own. Thank them not AMA.
Warningshot is offline Find More Posts by Warningshot
Old Oct 31, 2012, 11:43 PM
Elios000 is offline
Joined Jul 2010
the spread part is purely about using more then one channel ether at the same time or hoping or both
you can packetise 72 just fine ask the HAM packet radio guys about it
2.4 has a few things going for it a. its unregulated for the most part (only power restrictions) b. smaller antennas c.RC could jump right on it with spread spectrum and not interfere with older 72 gear
thinking about it wile it would work on 72Mhz it would mean stopping all use of older non spread spectrum gear as that would get shot down but the new stuff
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 11:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 10:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 05:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 09:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 10:42 PM
